Old Apr 18, 2011, 02:11 PM
rotorkilla's Avatar
Stoke-on-Trent, UK
Joined Nov 2010
Suppo ESC help???
Hey guys, i'm after some help of anyone with some Suppo ESC experience or knowledge. I have a 32" Pursuit as some of you know from Astec Models, UK which was supplied with the 120amp Suppo ESC, link to manual below.
The problem is when i try to put it programming mode as described in the instructions it dosen't seem to go into program mode and just throttles the motor.
Any ideas???
http://www.suppomodel.com/ESC/Boat%20ESC.pdf
1. Connect your motor and receiver to the speed controller, but do not connect the
battery yet.
2. Turn on your transmitter and move the throttle stick to the full throttle position (full
up). Please Note: Most Futaba transmitters have the throttle channel reversed by
default.
3. Connect your battery and the controller will initialize with a musical tone. Then the motor spins full throttle
rotorkilla is offline Find More Posts by rotorkilla
Old Apr 18, 2011, 03:08 PM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
Does it have a BEC, or separate RX pack?
If it doesn't go to program mode, it might not be getting a WOT signal, but I would think it would take whatever throttle input at that time as WOT?
wparsons is offline Find More Posts by wparsons
Old Apr 18, 2011, 03:24 PM
rotorkilla's Avatar
Stoke-on-Trent, UK
Joined Nov 2010
It does have a BEC, no seperate battery pack is required to power it up
Old Apr 18, 2011, 03:38 PM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
That's bizarre, it should do something besides just spin if you have it at WOT when you plug in the battery.
Discussion Suppo Shuttering kuczy Power Systems 4 Apr 12, 2011 07:42 PM
Help! Looking for Suppo motor GuyP Power Systems 6 Mar 05, 2011 05:34 PM
Help! Need esc set up instructions for Suppo ESC jcis4me Racing Boats - Electric 1 Aug 08, 2010 08:32 PM
Sold REDUCED - ESC's - NEW Suppo 60a Opto - Suppo 70a Opto+BEC - $17.50 each shipped. Wingwrecker Aircraft - Electric - Power Systems (FS/W) 4 Aug 26, 2009 06:41 PM
Question Suppo 40 amp ESC or Turnigy 40 amp Plush ESC? cjbucher Power Systems 10 Mar 30, 2009 10:36 AM
