Old Sep 05, 2012, 05:29 PM
rmr24 is offline
Find More Posts by rmr24
rmr24's Avatar
Joined Jul 2006
Thanks for the answers guys.
rmr24 is offline Find More Posts by rmr24
Old Sep 05, 2012, 10:49 PM
INDIZA is offline
Find More Posts by INDIZA
South Africa, LP, Polokwane
Joined Jan 2012
Thank you will give it a go.
INDIZA is offline Find More Posts by INDIZA
Old Sep 06, 2012, 09:50 AM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
due to the receiver not being able to drive a servo while being programmed, other servo matching devices are quicker and easier to use, and will also allow you to set the end-points. JR Matchbox and Futaba MSA-10 are what I've used, work pretty well. Obviously they're also around $60-70 each... JR's can be bought in pairs. Match up to four servos on a channel.
...but this is just to tide us over until the XPS's auto-matching receivers and break-out board arrive. The world will get turned on its head for ease of setup of giant scale planes. I seriously can't wait, will be so nice. I look forward to selling my matchboxen...
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Sep 16, 2012, 10:33 AM
INDIZA is offline
Joined Jan 2012
If I use two nanos as master slave and have for example two elevator servos where I use channel 2 for one servo and say channel 8 on the slave receiver mapped as channel 2 but I want to reverse one of the channel 2 outputs.
Can anyone help, I dont see anywhere on the XDP a servo reverse?
Old Sep 16, 2012, 10:50 PM
bruff is offline
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
click on failsafe
Bob
bruff is offline Find More Posts by bruff
Old Sep 17, 2012, 12:09 AM
INDIZA is offline
Joined Jan 2012
Thanks Bob, found it but even when I click in reverse it does not reverse I still have one elevator moving up and the other down have also tried hold, user and off and no go.
Old Sep 17, 2012, 11:03 AM
INDIZA is offline
Joined Jan 2012
My mistake, all working 100%
Old Sep 20, 2012, 12:28 PM
rcfan450 is offline
Find More Posts by rcfan450
United States, UT
Joined Nov 2009
How close can i install two nanos? Do i have to follow the 2" rule?
rcfan450 is offline Find More Posts by rcfan450
Old Sep 21, 2012, 10:00 AM
RyanNX211 is offline
Find More Posts by RyanNX211
Thermals, Tom
RyanNX211's Avatar
Upper Arlington, Ohio
Joined Dec 2007
It is truly remarkable. I was a little skeptical about installing something that small in my glow ship but it works great.
How is it that XPS is able to get away with two antennae so close to each other without the concerns that they be perpendicular and in different planes?
RyanNX211 is offline Find More Posts by RyanNX211
Old Sep 21, 2012, 11:50 AM
JuanRodriguez is online now
Find More Posts by JuanRodriguez
The Villages, Florida
Joined May 2003
Are you talking about the two "whiskers" coming out of ONE receiver ??
If so, those two whiskers is actually make up ONE antenna, not two.....
JuanRodriguez is online now Find More Posts by JuanRodriguez
Old Sep 21, 2012, 11:43 PM
Thermals, Tom
RyanNX211's Avatar
Joined Dec 2007
That is even more remarkable. How is this possible? Most manufacturers use two or more.
Old Sep 21, 2012, 11:52 PM
Thermals, Tom
RyanNX211's Avatar
Joined Dec 2007
Old Sep 22, 2012, 05:48 AM
Joined May 2003
In layman's terms, it's "magic"......
But I'm sure someone will provide a technical explanation neither one of us is going to understand anyway.....
Old Sep 22, 2012, 07:16 AM
GoFaster is offline
Find More Posts by GoFaster
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
I think it's a dipole design
http://en.wikipedia.org/wiki/Dipole_antenna
GoFaster is offline Find More Posts by GoFaster
Old Sep 26, 2012, 10:26 AM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Our 'ears' are far more sensitive than any others. Our Nano receivers have a sensitivity of -102dBm. Compare that to the Spektrum receivers using the 6934 at -90dBm. Every 6dB doubles the range. So 12dBm difference is 4 times the range. That is real range too, so if your -90dBm receiver is getting 2000 feet, you get 8000 feet if it was -102dBm. Our new receivers using the DivBee module are -107dBm in diversity mode, and -109dBm in single antenna mode. Our original receivers are -100dBm. Outputting higher power is not the answer to increasing range. First of all, the FCC does not like 'remote' devices to have more than 100mw of power, and you are required to warn people that you must be no less than 8" away from the tip of the antenna. It takes 4 times the power to double the range. That is a LOT of power for very little gain, so I focused on receiver sensitivity (combined of course with signal rejection) to increase the range. The Nano was my first attempt at designing 2.4GHz RF hardware, and the results are quite incredible. The DivBee is an even bigger jump.
JimDrew is offline Find More Posts by JimDrew
Wanted AR6300 nano RX flyinjrc74 Aircraft - General - Radio Equipment (FS/W) 3 Apr 02, 2011 04:59 PM
Discussion A truly SLICK product (for hunters) realtimerecon Life, The Universe, and Politics 15 Dec 12, 2010 08:13 PM
Discussion Blue Arrow 5ch Nano Rx & Esky 8g Nano Servos daniirwan Radios 6 May 03, 2007 11:07 AM
Just picked up a PHX-Link, Cool Product DavidJ Castle Creations 2 Apr 29, 2004 03:38 PM
