Old Aug 03, 2011, 10:00 PM
tande is offline
Find More Posts by tande
Joined Feb 2004
Originally Posted by JimDrew View Post
Most people I know just remove the labels and stick velcro to the PCB. We have to include the label - it has the FCC/IC/CE information.
Jim, is there any "no/no" with using "C/A" to reattach the label?
tande is offline Find More Posts by tande
Old Aug 03, 2011, 11:06 PM
JimDrew is online now
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
The label is not required, except for FCC identification. The only thing you can NEVER do is put anything (except the label) over the space between the two antenna wires. If you put glue, epoxy, rubber, etc. over this area the range falls on its face. The parasitic loads induced by certain materials can cause a real problem. It took awhile to find a vinyl (label) that didn't cause an issue.
JimDrew is online now Find More Posts by JimDrew
Old Aug 05, 2011, 12:55 AM
G-Forse is offline
Find More Posts by G-Forse
Denver, CO
Joined Nov 2007
--I wrapped mine in clear packing tape with the label installed. Is that good or bad?
G-Forse is offline Find More Posts by G-Forse
Old Aug 05, 2011, 01:00 AM
bruff is online now
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Here is what I'm using a couple of Nano in.
Bob
bruff is online now Find More Posts by bruff
Old Aug 05, 2011, 10:27 AM
FlyingW is offline
Find More Posts by FlyingW
Build more, websurf less
FlyingW's Avatar
Long Valley, NJ, USA
Joined Dec 2001
"...The label is not required, except for FCC identification. The only thing you can NEVER do is put anything (except the label) over the space between the two antenna wires. If you put glue, epoxy, rubber, etc. over this area the range falls on its face. The parasitic loads induced by certain materials can cause a real problem. It took awhile to find a vinyl (label) that didn't cause an issue..."
Jim,
That caught my eye. I understand what you are saying about materials over the space between the antenna wires. How about velcro on on the bottom of the unit across that space?
The picture shows an example where the velcro does not quite reach that area, but what if it did cover it?
Please advise. Thanks,
Paul
FlyingW is offline Find More Posts by FlyingW
Old Aug 05, 2011, 11:29 AM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
That's how I secure all my Nano's in my planes, and often times the velcro extends past the end on the RX. Nary a problem so far.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Aug 05, 2011, 01:16 PM
Lake Havasu, AZ
Joined Jun 2005
That's fine. It's the FRONT side of the board that I am concerned with (between the two coils). If you put anything between those, you would be better off cutting the antenna wires off.
Old Aug 05, 2011, 01:34 PM
FlyingW is offline
FlyingW's Avatar
Joined Dec 2001
Understood. Thanks, Paul
Old Sep 30, 2011, 03:38 PM
GoFaster is offline
Find More Posts by GoFaster
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
Setting up a Nano for another model.
According the manual, the LED (how come it's not blingy blue?!) blinks when a reboot has occurred.
Is there an option to make it blink at another rate to indicate that failsafe (signal loss) has occurred? I know I can do this with a Tattletale but can the Nano indicate that a loss of signal condition has happened?
GoFaster is offline Find More Posts by GoFaster
Old Sep 30, 2011, 04:31 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
cut the antenna wires off if I put anything between the coils... gotcha, will do!
theKM is offline Find More Posts by theKM
Old Sep 30, 2011, 05:16 PM
Lake Havasu, AZ
Joined Jun 2005
No, there is no special blinking for signal loss.
Old Mar 16, 2012, 12:33 AM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
completed a little project I've wanted to do for a while... "powersafed" my nano with a deans plug pigtail... pretty simple idea, just solder up to the servo bus. I also bolstered the bus with an extra run across the bottom of the pins... not all that needed (Jim's said the bus of the Nano is good for 30 amps or something if memory serves), but done for giggles.
...Nano now ready for plugging in giant scale servos... no regular servo plugs from the battery to be overloaded, etc etc. woot.
Old Mar 23, 2012, 10:07 PM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
Now THAT'S a mod!
Serious question about installation: most of my installs have the RX on it's "back" velcroed or double side taped to the bottom of the fuse at a 45 deg angle. But Jim's comment about not covering up the front area between the antennae have me wondering if this is best. Rationale for bottom of fuse is that this is least obstructed path through wood / covering to TX when the plane is in the air. Would I get better range with the front of the RX facing outward from the plane?
I am of course careful to locate the RX away from batteries, metal objects, wires, and all servo wires are secured and kept away from the RX as much as possible. Thx.
TTRotary is offline Find More Posts by TTRotary
Old Mar 24, 2012, 11:19 AM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
I keep looking at the picture above and getting worried about a failure. I think I would hot glue the power wires to the circuit board to prevent flexing at the edge of the board. I just have a feeling it is going to pull the pins away from the board traces because of the extra leverage and a blob of glue should move that flex point away from the first solder joint.
village_idiot is offline Find More Posts by village_idiot
Old Mar 24, 2012, 11:26 AM
vapor54 is offline
Find More Posts by vapor54
Joined Feb 2008
I think KM said and the pic shows he re-enforced the whole buss bar all the way thru ----- rick
vapor54 is offline Find More Posts by vapor54
Wanted AR6300 nano RX flyinjrc74 Aircraft - General - Radio Equipment (FS/W) 3 Apr 02, 2011 05:59 PM
Discussion A truly SLICK product (for hunters) realtimerecon Life, The Universe, and Politics 15 Dec 12, 2010 09:13 PM
Discussion Blue Arrow 5ch Nano Rx & Esky 8g Nano Servos daniirwan Radios 6 May 03, 2007 12:07 PM
Just picked up a PHX-Link, Cool Product DavidJ Castle Creations 2 Apr 29, 2004 04:38 PM
