Old Apr 18, 2011, 09:32 AM
ivgarcia is offline
Find More Posts by ivgarcia
Joined Oct 2008
Very Simple Motor Test Bench
Hi guys,
I have come up with a very simple design for testing motor thrust and I would like to know your opinions.
The idea is to have two scales with a heavy weight connected with an square tube and place the motor in the middle. When the motor is on, the weight that will be substraed from both scales will be the real thrust.
I attach a picture of the design.
Cheers
ivgarcia is offline Find More Posts by ivgarcia
Old Apr 18, 2011, 09:45 AM
crypto666 is offline
Find More Posts by crypto666
USA, NV, Caliente
Joined Mar 2009
Intersting concept, I think it would work. However, the ones I have seen Dr. Kiwi et al use are pretty simple and require only one scale and less math. Check them out, they are probably about as simple as it gets.
crypto666 is offline Find More Posts by crypto666
Old Apr 18, 2011, 09:54 AM
Ken Myers is offline
Find More Posts by Ken Myers
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
Originally Posted by ivgarcia View Post
Hi guys,
Simply put:
Motors create torque. Props create thrust.
Ken Myers is offline Find More Posts by Ken Myers
Old Apr 18, 2011, 10:14 AM
yomgui is offline
Find More Posts by yomgui
Joined Feb 2011
In fact there is no axis, so...
You might have a part of the weight you are measuring that in fact comes from the torque, in a way that you can hardly know.
Vibrations might cause mistakes too...
So it may not be very close to reality, but it might be enough.
yomgui is offline Find More Posts by yomgui
Reply With Quote  (Disabled)
Old Apr 18, 2011, 11:33 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Concept is okay...pusher configuration (pushing down on the scales) would obviate the need for math.
One serious issue is the fact that you are standing in the way of a dangerous object (the prop) spinning horizontally at high rpm.... if a blade lets go, it will scythe its way at you or someone else... that why I moved on from my original "vertical thrust" stand, to a far safer "horizontal thrust" stand, so that I can be safely behind the prop when it is spinning, not directly in its path.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Jun 06, 2011, 01:05 AM
mark_q is online now
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
Here is my latest (this is gen 3). It's a pusher type, was easy and cheap to build and does a very consistent job for motors of up to 2000 watts and prop thrust measures up to 176 oz. It's also safe as I run it remotely.
Happy Testing! - Mark
mark_q is online now Find More Posts by mark_q
Latest blog entry: X-UAV Mini Talon #2
Old Jun 06, 2011, 12:04 PM
z-matrix is offline
Find More Posts by z-matrix
just look at it smokin'
z-matrix's Avatar
Joined Dec 2005
i use a frame on top of the scale, EDF upside down, zero scale, then start testing.
What is your opinion simple enough?
z-matrix is offline Find More Posts by z-matrix
Old Oct 10, 2011, 04:42 PM
djdavies83 is offline
Find More Posts by djdavies83
We can rebuild it!
djdavies83's Avatar
United Kingdom, Wales, Swffryd
Joined Apr 2010
I'm going to subscribe to this, I'm really curious about how much thrust comes out of these coaxial toy helicopters, other than what seams to be the standard method of securing the heli to a weight on the scales and then working out weight difference with the throttle up, any ideas on how I could get it more accurate?
I think the method I mentioned would be inaccurate as with the heli so colse to the ground it would give a higher reading by pushing against the ground.
djdavies83 is offline Find More Posts by djdavies83
Old Oct 10, 2011, 05:17 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Hey Mark,
If I am seeing it correctly... in your "set up for a test photo" you need to reverse the prop (convex face facing the motor) to get the pusher effect. As it is, with the motor running in reverse as it needs to be, you are using the "back" of the prop to push air.
That is a nice solid set-up you have made... mine is probably limited to 2kg thrust.
Cheers, Phil
For Sale 90mm HET fan with HET 700-68-1485kv motor very very powerful have video sherlockshah Aircraft - Electric - Jets (FS/W) 16 Apr 14, 2011 12:49 AM
Discussion Safe bench testing an brushed electric motor arukum17 Power Systems 8 Mar 21, 2011 06:14 PM
Discussion Harbor Models Sound Module Bench/Field Test Capt.Crash Dock Talk 0 Mar 21, 2011 10:29 AM
Discussion Simple test bench set up oneofsharp Electric Motor Design and Construction 205 Aug 26, 2010 03:55 PM
