Old Apr 18, 2011, 06:14 AM
tadejpolajnar is offline
Find More Posts by tadejpolajnar
Joined Apr 2011
Question
Hobbyking SS Series 15-18A ESC programing-please help
how to programming this esc!
-What i must do?
-please somebody make video "how to programing" ( send link here )
link: http://www.hobbyking.com/hobbyking/s...idProduct=6456
thanks
tadejpolajnar is offline Find More Posts by tadejpolajnar
Old Apr 18, 2011, 02:17 PM
Joined Apr 2011
please help
Old Apr 18, 2011, 02:46 PM
Dr Kiwi is online now
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
It may be the same as a Dynam. http://www.dynam-rc.com/download/diantiao.pdf
Here is an HK Video clip for a larger HK SS ESC: http://www.hobbyking.com/hobbyking/s...f598858402f441
Here are instructions as posted by someone on the HK website:
Very good controller, specially for this money.
With 16A it becomes a little bit warm, no problem.
One disadvantage: there is no manual included. (5 Stars with manual!)
So I have searched in web an i found that the controller is programmable.
Possible options:
- LIPO-mode (auto selection 2/3 cells)
- NIMH-mode
- Break on / off
To program this controller you have to move transmitter throttle to full position.
Now connect battery to controller.
Wait some seconds, than you hear:
*peep* - *short pause* - *peep*
*pause*
*peep*peep* - *short pause* -*peep*peep*
*pause*
*peep*peep*peep* - *short pause* -*peep*peep*peep*
*pause*
this sequence will repeat...
When you want to use NIHM cells, you have to move throttle to off position when you hear the first *beep*beep*. Than you have to wait for a longer *beeep* and a short *beep*. That's all. You can disconnect battery now.
When you want to select LIPO mode, start from the beginning (throttle full, connect battery, listen to the beeps)
At the time when you hear the first single *beep* move throttle to off and wait for
*beeep* and *beep*.
When you want to switch Brake On or Off, start from the beginning, then wait for the first *peep*peep*peep* within one sequence and put throttle to off. Wait for *beeep* and *beep*.
Note: When you connect battery and throttle is in off position you will hear a long *beeeep* when LIPO-mode ist selected or a short *beep* when NIMH-mode is active.
Maybe you can buy a program card.
Dr Kiwi is online now Find More Posts by Dr Kiwi
Old Apr 19, 2011, 07:14 AM
Joined Apr 2011
realy thanks
Old Jul 07, 2011, 09:44 PM
juz70 is offline
Find More Posts by juz70
Lumenier team pilot
juz70's Avatar
Australia, VIC
Joined Dec 2009
Thanks, now all 4 ESCs on my quadcopter are programmed correctly...awesome
juz
juz70 is offline Find More Posts by juz70
Question Hobbyking SS Heli Series 50-65A ESC jp.electrik Power Systems 2 Oct 03, 2013 03:33 PM
Sold Electri-Fly Silver Series SS-45 amp ESC ryan_m Aircraft - Electric - Power Systems (FS/W) 0 Apr 14, 2011 08:03 AM
Discussion Now with data: Hobbyking SS 25A esc works great it was my fault for not testing first handyfella Power Systems 40 Mar 26, 2011 09:29 AM
Sold Hobbyking SS Series 40-50A ESC brand new jamesrini Aircraft - Electric - Power Systems (FS/W) 4 Oct 31, 2009 06:42 PM
Sold NEW- Hobbyking SS Series 50-60A ESC Geaux4it Aircraft - Electric - Power Systems (FS/W) 6 Oct 16, 2009 09:25 PM
