Joined Apr 2006
If you like speed try the motor in the link, you'll be easy flying at more the 120mhp a real challenge to control
, use a 4.75 / 4.25 apc prop and 60 amps esc.http://www.hobbyking.com/hobbyking/s...idproduct=7993 |
Hey Frank, truth be told, the e-power stuff doesn't do much for me - I just did it so I could say that the designed flew on both power types. The original was by far the funnest on the Norvel .061 AME!
There's no reason you couldn't use the hummer wing plan to build a flying wing, but it'll probably have too much additional structure. If you would like some pointers on flying wings in general, check out the thread that started my foray into flying wings: http://www.rcuniverse.com/forum/m_93...tm.htm#9304054 |
Ahhh... righteo. I've never heard of a foam wing with balsa before. What prop are you running on that setup? It'd need to be fairly pitchy to be fast. The 'fast' setup for me at the moment is a Hextronik 3000kv outrunner with 4.75x4.75 prop on 3-cell. It really rips up the skies in my foamboard F-22. 120mph pitch speed and probably 80~90mph real life.
Anywho I'm gonna try and get this wing working. I'm thinking of using electric power before going nitro to work out any bugs it has, partly because I'll be able to maiden it in town, too. Cheers - boingk |
Righteo guys, made a fair bit of progress and decided to go electric after all. It suits my regular flying locales a lot better as they're in town in large, quiet parks. Heres the maiden flight:
I start getting into a groove at about 1:20 and realise there is something wrong at around 2:45, then land as best I can. The 'something wrong' turned out to be a dead servo, leaving me with very skewed handling indeed! The resulting poor landing cracked the motor box a bit and I reglued and reinforced with scrap balsa strips. Following the flight above I've flown about half a dozen packs through it and also added some more detailing to help with orientation. Heres how it looks now: ![]() The black parts are just drawn on with a permenant marker and the white stripes on the wing and square on the motor box are done using an automotive oil-paint pen. Since replacing the dead servo, I've started trying to trim mechanically for neutral flying without transmitter trim. This has proven to be somewhat of an effort and may require fitting a matching servo to replace the one still remaining from the original build - although the new one is equivalently specified, I think it may differ in speed and throw slightly and is causing some trimming problems. Anywho, thats it! Its flying! I'll post another video once the bugs are worked out. Cheers - boingk |
Whoa, do ya think you have a enough elevon area on that thing? Just kidding, I like it - she's a beauty! Looks like you have a bit of "reserve power" there as the launch was pretty authoritative even at part throttle! I'm curious, what are you using for a power system? I understand why you went with the e-power, I'm just afraid that if you ever stick that Sure Start on there, you're going to be a bit disappointed unless you hop up that SureStart a bit or swap it out for a TD.
Oh yea, you may find it a bit easier to launch with the underhand technique - palm up and thumb on top of wing. (You can see me do that here http://www.youtube.com/watch?v=gI0OVT-gNxE ) Anyway, it's good to see you're having fun with it and congrats! I'll be looking forward to the next installment! -Joe |
Thanks for the kind words Joe, means a lot as this is both my first scratchbuild and first flying wing. I've also changed my launch technique to holding the underside of the motor box and throwing forwards in a pitching motion, seems to work well.
The power system is all low budget Hobbyking gear. Motor is a Hextronic 24g 1700kv outrunner, ESC a 15A HK Super Simple, and prop a GWS HD 8x4 cut down to 6x4. It only draws around 8.5A on 3-cell but is a good combo for both thrust and reasonable speed. The maiden video was using an undoctored 8x4 and I've got some 8x6's on order to cut down to 6x6 for some more speed. I really like the GWS HD series because they are easy to cut down without having to mess with tip profiles or airfoils and so on. Video of a crash coming soon, got it on wingtip cam so should be interesting. Cheers - boingk |
She's still alive and kicking! After the dual-electric conversion I did I decided to go nitro with the engine this wing was originally designed for - the Cox .049 'SureStart'. 1oz Sullivan tank, APC 6x4 prop doctored to about 4.75x4 and an 18% nitro mix with plenty of castor sees her flying around pretty well.
![]() Cheers - boingk |
| Thread Tools | |
| Discussion Combat flying wing plans | Swoopdown | Control Line | 7 | Mar 12, 2011 07:51 AM |
| Elexico (1/2A Texico) plans/kits | rht0930 | Electric Plane Talk | 3 | Apr 07, 2009 06:07 PM |
| Discussion Looking for blasa kits (1-2m wing span) or plans | PetruSoroaga | Electric Plane Talk | 9 | Apr 28, 2007 03:29 PM |
| 1/2A Blazer re-kits or plans? | ZXWerke | Free Flight | 3 | Dec 12, 2004 10:02 AM |
| Question Free 1/2A plans & prices for 1/2A engines? | t_predator90 | 1/2A Planes | 4 | Dec 14, 2003 05:59 PM |
