Old Oct 16, 2001, 02:06 PM
Joe Elston is offline
Find More Posts by Joe Elston
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
Help I need to press a pinion on my Speed 400
I am installing the motor in my SR X250 and need to press the pinion from the gearbox on the speed 400 motor. I have the New Creations Pinion Press and Pinion Puller. However they look to large to the job. Has anyone used this equipment on S400 and if so can you tell me how to do it.
Thanks Joe
Joe Elston is offline Find More Posts by Joe Elston
Old Oct 16, 2001, 03:59 PM
Sligh is offline
Find More Posts by Sligh
Madison Ms. USA
Joined Jan 2000
Joe,
I'm sure you have one, just use your drill press without a drill bit.
Sligh is offline Find More Posts by Sligh
Old Oct 16, 2001, 04:02 PM
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
Speed 400 pinion
HI Sligh, that is the one tool I dont own, that is why I bought this press.
Thanks Joe
Old Oct 16, 2001, 04:16 PM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Hi Joe,
I've used it, use the smallest hole on the small inside plate with 3 holes, adjust the nuts so the motor is suspended between the two plates and center the rear of the shaft on the bolt in the rear plate, turn the bolt slowly keeping everything aligned. It takes three hands at first, but once the pinion gets started it goes on easily.
Azarr
www.azarr.com
Azarr is offline Find More Posts by Azarr
Old Oct 16, 2001, 04:19 PM
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
thanks Azarr I will try it.
Thanks for the help Joe
Old Oct 16, 2001, 05:18 PM
Red Baron 47 is offline
Find More Posts by Red Baron 47
Most Exalted Windbag
Newark, DE USA
Joined May 2001
Don't forget to use the green locking compound in the tiny tube.
RB
Red Baron 47 is offline Find More Posts by Red Baron 47
Old Oct 16, 2001, 05:25 PM
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
Pinion
Thanks Azarr I got the pinion on and the motor is ready to be soldered up. I do need to reverse polarity on the motor correct?
Thanks Guys.
Joe
Old Oct 17, 2001, 03:56 AM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
I used a vice ("vise" in American? ) for pressing the pinion onto my 600. This worked fine ... you do need to make sure everything is square, but assuming the shaft stands proud of the rear of the motor this is a pretty good way of doing it (there's no stress at all on the motor case or bearings).
Bill Glover is offline Find More Posts by Bill Glover
Old Oct 17, 2001, 04:43 AM
Azarr is offline
Azarr's Avatar
Joined Jan 2000
You need to reverse polarity unless you're using a planetary gearbox which does not change the direction of prop rotation
Azarr
www.azarr.com
I need help with Mosfet identification on my Jeti esc WickedFunRC Power Systems 35 Sep 24, 2013 02:13 PM
Need help deciding what to do on my T-38 Branjo Electric Ducted Fan Jet Talk 1 Nov 06, 2005 11:51 PM
Whoops! Help!! Need a little push on whether to sell my slimer stuff!! sirdirk007 Electric Plane Talk 21 Mar 30, 2005 12:48 AM
need to replace a pinion on my hornet, help! boxed Electric Heli Talk 9 May 21, 2002 05:39 PM
Fastest plane on stock speed 400 setup? g00bd0g High Performance 9 Jul 13, 2001 04:43 PM
