Hobby king new micro cessna 4 ch EPO 555mm WS with VIDEO
http://www.hobbyking.com/hobbyking/s...dProduct=16285
Specification: Material: EPO Wing Span: 555mm Length: 480mm Flying Weight: 175g Motor: 1826 Brushless outrunner 2600kv ESC: 6A w/BEC Battery: 7.4v 500mAh 2S1P (Not included) Servos: 1 x 8g, 2 x speed micro 4 Channel Required. 4ch Tx & Rx 500mAh 2s Lipoly Battery |
United States, VA, Fluvanna
Joined Jan 2011
As far as space goes, it's so crammed that you really have to have the battery in mind when you build the thing. Put the servos to far forward and there's no room for the tiny battery. Watch out for the 5A ESC and wiring too. The battery on this one looks about the same size as the batteries I got for mine. SB |
Joined Jan 2011
This is what I thought at first, but as it turns out the champ Tx is a very capable radio. I use the stock Champ Tx to control a Champ, a UM P51, a Slow Stick, 2 HBZ Mini Super Cubs, 3 HobbyKing micros, a Flyzone Playmate (with a Champ brick installed), a T-34 Mentor, and a GWS E-starter. All without rebinding or re-trimming. 3 planes use PZ bricks and the rest use DSM2 compatible receivers. Of course, I had to bind each receiver to the Champ Tx the first time. After that every receiver remembers the Tx and does not have to be bound again. It's true that the Tx doesn't remember the plane ("Model Memory") but it doesn't have to. I've accidentally had 2 planes on at once and both responded to the Champ Tx stick movement simultaneously. To avoid having to re-trim each plane at every flight takes some patience. I have a lot of patience and enjoy making minute changes to the trim by hand. When flying the planes I take note of any necessary trim changes and make them later. Some can be made on the spot (the Champ has the curve in the pushrods to adjust trim, the Mini super Cub has thumb screws on the control horns for quick adjustments). If you do a lot of the trim work by hand there isn't that much of a problem with the Champ Tx not having "Model Memory", especially if you don't have to bind the Tx - Rx each time. Quote:
SB |
| Thread Tools | |
| Build Log Hobby King Micro Yak-54 Build log | tallflyer | Foamies (Kits) | 13 | Jul 05, 2012 04:56 AM |
| New Product New Hobby King micro linear servo (New version $4.29!) | MegaTesla | Indoor and Micro Models | 407 | Nov 25, 2011 03:22 PM |
| Build Log Hobby King 1.5 meter Cessna 182 w/ Floats | WAFlyer15 | Foamies (Kits) | 5 | Jul 01, 2011 08:07 PM |
| Help! What radio gear from Hobby King for a 20 inch (40 cm) Cessna 180 type model? | knlever | Indoor and Micro Models | 7 | Mar 26, 2011 06:48 PM |
| For Sale Grayson Hobby/ Hobby King Speed controllers + Motor | Rooster433 | Aircraft - Electric - Power Systems (FS/W) | 6 | Mar 17, 2011 11:48 AM |
