This thread is privately moderated by magnetman, who may elect to delete unwanted replies.
Old Apr 16, 2011, 02:20 PM
magnetman is offline
Find More Posts by magnetman
Fly the Discombooberator!
magnetman's Avatar
Joined Nov 2003
Gallery
XB 70 Valkyrie Bomber by Nicesky
Originally bought from BRC Hobbies, full retracts (non Std) 4S Power, fantastic flyer, fast or slow, very stable, ROGrass and near vertical performance
magnetman is offline Find More Posts by magnetman
Old Apr 16, 2011, 06:23 PM
dLdV is offline
Find More Posts by dLdV
On the Edge of Space
dLdV's Avatar
Exit 4, South Jersey, USA
Joined Dec 2007
Very cool model. Have fun with that.
dLdV is offline Find More Posts by dLdV
Old Apr 18, 2011, 03:17 AM
magnetman's Avatar
Joined Nov 2003
Thanks - is that a model SR 71?? I have a BP hobbies one still in the box I keep meaning to put together. Do you reckon it might need a gyro for roll stability??
Richard
Old Apr 18, 2011, 09:01 AM
dLdV is offline
dLdV's Avatar
Joined Dec 2007
I fooled around with some on mine but only kept them a few flights. They did not seem to help much, but that may have been incompetence with gyros on my part. The part that helped most was to mix for more elevator travel than aileron travel.
I found the plane slow to respond to pitch control but quick to respond to roll control. I mixed to compensate for that.
My best advice for success would be to set it up for power to weight similar to the final stock version. It won't be a speed demon, but it will be a solid reliable model.
Old Apr 18, 2011, 09:32 AM
magnetman's Avatar
Joined Nov 2003
Pitch response
Ah, OK. so lots of elevator but small aileron. Similar on the Valkyrie, need lots of elevator. Did you get down - pitching with increased throttle?? I have this on my GWS F15 , but compensated for that by mixing in some up elevator with throttle
Old Apr 18, 2011, 09:54 AM
dLdV is offline
dLdV's Avatar
Joined Dec 2007
There were two issues in pitch. At normal flying speed it was fine in straight level flight.
During turns it would drop the nose, more so than a more conventional layout. Mixing so that it kept more reflex on the elevons through the turns solved that.
The other problem was at low speeds. The tail can stall and sink, and there will be more lift under the long, wide flat bottom nose than under the tail, resulting in an unrecoverable stall. The cure was simply to stay above that stall speed and avoid nose high attitudes.
I smashed mine to smithereens, so I may not be the best advisor. That said, I have one in the box to replace the old one. If you get going on your project, you could drop me a line and I'll start mine too. I like to compare notes on this plane.
The end came for mine while flying straight and level at altitude and cruising speed, it suddenly went sideways and fell from the sky. I couldn't determine the exact cause.
Old Apr 18, 2011, 02:24 PM
magnetman's Avatar
Joined Nov 2003
Hey that's a shame. Was it the BP hobbies one?? Must look up on here I think there is probably a build thread.
Maybe it may be better to modify it with the rear of the centre section as the (huge) elevator, with separate ailerons, dunno.
I think the Multiplex Sonic Liner will be next, already started to build, will start a build log. Will let you know when I start the '71
Old Apr 23, 2011, 11:49 AM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
I've been flying the heck out of mine. The first weakness was the soft wire material used in the front strut. It folds so easily, I upgraded mine with better material and it has been holding well. Ditto on the dropping of the nose in tighter turns. Wide sweeping turns and/or reflex cures the problem.
XB-70 Ducted fan jet (3 min 3 sec)
Joe 1320 is offline Find More Posts by Joe 1320
Old Apr 26, 2011, 12:31 PM
magnetman's Avatar
Joined Nov 2003
http://www.youtube.com/watch?v=di05t_BTQ_E
Same here - I changed my nosewheel retract for an E Flite electric one - I don't have the luxury of a hard strip, short grass instead so the U/C gets a bit more stress.
In fact, the only stock parts left on mine are the fan unit and main retracts
Old Apr 04, 2013, 10:40 AM
Turbobearcat is offline
Find More Posts by Turbobearcat
Turbobearcat's Avatar
Joined Aug 2011
Joe
How much travel are you using on both Aileron and Elevator?
Turbobearcat is offline Find More Posts by Turbobearcat
Old Dec 17, 2014, 11:17 AM
Joined Aug 2011
Wow this thread totally died off..
Old Dec 18, 2014, 10:13 AM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Makes me wonder why.... It is a great flyer.
Old Jun 20, 2015, 09:46 PM
Joined Aug 2011
I have been upgrading one of mine as of lately
changed over from the stock 5 blade to 6 blade on a 3500Kv motor.. then found out that FMS sells a 8 blade fan and I ran it on my Turnigy 2800Kv setup - sounds good but not as fast as the 6 blade setup so I now ordered the FMS 3000Kv motor which should help.
I'm trying to keep the weight down and balance the performance to more a scale like.. but everybody thinks it should hit 100MPH... not so , 70 yes but not 100mph
Old Jul 06, 2015, 08:02 AM
Joined Aug 2011
Not happy with the collett on the shaft for the 3000kv motor, will talk to somebody in the hobby near me and get their opinion to what to do next or if I am over reacting since I see a slight wobble on the fan at low speed but wow does it sound good at hi-speed..
Old Jul 06, 2015, 09:00 AM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Wobble is not good.
Discussion Chris Golds XB-70 Valkyrie 6 Vasa 55 fans Robert May Electric Ducted Fan Jet Talk 69 Dec 22, 2009 12:07 PM
Discussion XB-70 xb 70 Valkyrie Ted61 Giant Electric Planes 1 Jul 23, 2008 01:48 PM
Build Log XB-70 Valkyrie Build Log KFC Pusher Prop Jet Models 29 Jun 26, 2008 11:25 AM
Build Log XB-70 valkyrie gykairlines Pusher Prop Jet Models 9 Dec 26, 2007 01:25 PM
Video XB-70 Valkyrie Wingtip Movement Short video clip Steven Wong Electric Plane Talk 0 Feb 23, 2006 09:53 AM
