Old Feb 09, 2012, 08:59 PM
bigroger is offline
Find More Posts by bigroger
Just flitting about!!
bigroger's Avatar
Joined Aug 2011
Originally Posted by H2SO4 View Post
Thanks Roger. I did get a tube of it from Max, to test, but I haven't gotten round to it yet. If I ever manage to get my paws on some of that Welders stuff as well (know anybody who stocks it in .au?), I'd like to do a little shootout between the "boutique" foam glues:
- Uhu Por (electricwingman @ $2.50 / 40g)
- The HK "jiao shui" stuff ($2.50 / 100g)
- 3M Scotch 6225n (BVRC @ $7.86 / 30g)
- Welders ( ? )
Cost is not as important as performance, given the miniscule quantities and the consequences of a glue join splitting open
Mate that stuff from MAx is actually $7.86 for 70g tube. Not bad value I think in hindsight.
I've been searching high and low for welders everywhere in Aus to no avail. Must be another thing only available in the USA.
The stuff from Max also dries white rather than yellow like the UHU por does once it gets any kind of UV on it. Good for repairs to white epp that doesn't look that great with big gobs of yellow UHU repairs.
bigroger is offline Find More Posts by bigroger
Old Feb 09, 2012, 10:22 PM
feda is offline
Find More Posts by feda
EP 3D Flyer
feda's Avatar
Hamilton, Canada
Joined Nov 2005
Originally Posted by Tieto View Post
But at the moment they are released, I am ready!!
Do you have a date Feda?
(PS. Are you Max from the mail?)
Thanks, Tieto.
I don't have a date yet.
Yes, I am that Max.
feda is offline Find More Posts by feda
Old Feb 09, 2012, 10:43 PM
feda is offline
EP 3D Flyer
feda's Avatar
Hamilton, Canada
Joined Nov 2005
Thank you guys, for all your inputs. I'll pass them to SkyWing.
SkyWing did want to improve the tail gear. Here's an image from SkyWing showing the new design.
Old Feb 09, 2012, 11:03 PM
bigroger is offline
bigroger's Avatar
Joined Aug 2011
max, that would be perfect. It would be even better if they could get a loop in the wire below the attach bracket to give it some spring, like in the photos above that Nac and Bleary posted.
Otherwise a great step up from the rudder imbedded design.
See the spring section in this page.
http://www.hobbyking.com/hobbyking/s...idProduct=8004
Or take a look at the EF design tail wheel setup. Its very strong and zero load on the rudder assembly.
The carbon brace that the wire is attached to takes the load.
Or something like this: http://www.adchobbystore.com/3DHS-Me...RFs_p_127.html
feda is offline
EP 3D Flyer
feda's Avatar
Hamilton, Canada
Joined Nov 2005
Originally Posted by bleary View Post
Like this:
I find the collar's placement is odd:
With this tail gear, there seems to be nothing much to prevent the impact from getting to the rudder during landing?
feda
Old Feb 09, 2012, 11:32 PM
nac is offline
nac
Find More Posts by nac
nac
nac's Avatar
Melbourne, Australia
I have had some minor issues with the EF design in that they keep coming loose and turning. I like using the coil approach which allows for lots of flex on hard landings.
The one I used was from HK, just had to bend the wire to suit.
http://www.hobbyking.com/hobbycity/s...idProduct=8004
Scotch glue is fantastic! Sticks very well, blends nicely with the EPP and doesn't go yellow. I have tried UHU por, but I don't like it much. Not as sticky and takes longer to dry.
nac is offline Find More Posts by nac
Old Feb 10, 2012, 12:28 AM
groovejet is offline
Find More Posts by groovejet
How many planes is too many?
groovejet's Avatar
Australia, VIC, Melbourne
Joined Aug 2007
Wow; the updated fuselage construction looks great! It looks like the best are getting better .
I personally haven't had any issues that I can think of with Skywing's current tail wheel setup. You guys must be abusing your planes more I suppose . Feda, I like Skywing's proposed new design for the tailwheel, but could you please ask them to use a round wheel rather than an octagonal one?
Yep, 3M Scotch 6225N glue is really good .
groovejet is offline Find More Posts by groovejet
Old Feb 10, 2012, 01:13 AM
bleary is offline
Find More Posts by bleary
Cookie Monster
Australia, QLD, Diddillibah
Joined Aug 2005
feda
That is probably not a great example Feda,but you get what I mean about isolating landing and even hanger abuse shock from the rudder servo.A collar or similar below the right angle would stop the shock loads.
I also second GJ's comments on the BV Scotch,the stuff is fantastic.
EDIT: that doesn't make sense sorry,it needs a collar at the bottom or similar,anyway,you guys know what I mean.....I hope.
bleary is offline Find More Posts by bleary
Old Feb 10, 2012, 01:35 AM
Dchimmi is offline
Find More Posts by Dchimmi
Landing!!
Norge, Møre og Romsdal, Kristiansund
Joined Apr 2008
At least I do, bigrogers picture illustrate it a bit better maybe. =)
Regarding modifications, agree with making/keeping the battery tray accessible.
Maybe make an opening so it's possible to have a velcro around the battery?
(Not that mine has flown out yet.)
The only thing I've broken (so far) is the landing gear, which was done the first landing. A very quick fix with my hot glue gun, and has not been damaged in the 20+ flights after.
The carbon reinforcements looks really good, and I'm impressed with all the good ideas that people have here! If the price stays in the same range, I would be surprised if this avoids being hit of the year in 2012!
Ohh... the waiting...
Dchimmi is offline Find More Posts by Dchimmi
Old Feb 10, 2012, 01:38 AM
luke352 is offline
Find More Posts by luke352
Australia, QLD, Ipswich
Joined Sep 2008
I think I saw Welders at the new Masters Hardware stores, next time i'm there i'll check.
I could probably send you a couple tubes if they do.
luke352 is offline Find More Posts by luke352
Old Feb 10, 2012, 02:21 AM
H2SO4 is online now
Find More Posts by H2SO4
christian theme park operator
H2SO4's Avatar
Australia, New South Wales, Sydney
Joined Jan 2011
Originally Posted by Rick662u View Post
Be very interested in that glue test
I'll see what I can do. The most demoralizing obstacle is that I can't yet think of a way to deal with the fact that foam is weaker than the glue join. Hence, attempts to destructively test the yield strength in various orientations - longitudinal, transverse, yadda yadda - will presumably cause the foam around the glue join to break long before the glue does. Testing with hardwood or metal blocks would be much easier to rig up, but it wouldnt necessarily provide an accurate indication of each glue's ability to bond with foam.
If anybody's got suggestions, I'm all ears.
H2SO4 is online now Find More Posts by H2SO4
Old Feb 10, 2012, 06:00 AM
Motrolflyer is offline
Find More Posts by Motrolflyer
My Son, My Hero, My Marine
Motrolflyer's Avatar
United States, GA, Rincon
Joined May 2011
Welders adhesive
- Welders ( ? )
[QUOTE=bigroger;20697737]I've been searching high and low for welders everywhere in Aus to no avail. Must be another thing only available in the USA.
Originally Posted by luke352 View Post
I think I saw Welders at the new Masters Hardware stores, next time i'm there i'll check. I could probably send you a couple tubes if they do.
Guys, I would also like to see the results of the glue test. If for any reason you can't find the Welder's, drop me an e-mail with an address and I will send a couple of tubes FREE OF CHARGE. We buy it here on this side of the pond at one of the big hardware stores in a 2 pack. I used it to retain the l/g on 3 of our SW's and no problems there. I also used it to attach the motor close out and the wing to body fairing wedges.One caveat though, it eats Depron. Don't ask me how I know, it was too embarrasing to tell.
Hi Max, I agree with all the suggestions to improve the Skywings. Let me add one. For guys like me who are just getting on board with building these wonderful planes I would add a warning to the build manual about using a foam safe CA to attach the hinges instead of regular CA. I found out the hard way what Groovejet, I think it was him, mentioned in a previous post about there being Depron in close proximity to the hinges. I could definitely see the melted Depron around the aileron hinges. In fact I almost sent you an e-mail to see if I could buy a replacement set of wings. But after a 24 hour cure time the ailerons survived a couple of pull tests and I haven't had any pull out in flight.
Or you could have the factory cut out the Depron to form a pocket around each hinge. Say about 2-3mm clearance on all three sides.
Cheers and good flying to everyone,
Alec
Motrolflyer is offline Find More Posts by Motrolflyer
Old Feb 10, 2012, 04:01 PM
bigroger is offline
bigroger's Avatar
Joined Aug 2011
Alec, Groove, Nac and myself are now installing the hinges with UHU por in my case and the 3M scotch adhesive mentioned above by H2SO4.
Seems to hold up very well so far and I have really pounded the MXS hard many, many times and its surviving wonderfully.
Old Feb 10, 2012, 09:16 PM
nac is offline
nac
nac
nac's Avatar
Hey Guys, I had a longer think about the mods.
I am thinking now that I would rather keep the price the same and only change a few minor things.
1. Fix up the firewall from de-laminating. As it is a bugger to fix.
2. Strengthen the landing gear mount and change the wire to a more resilient type that returns back to shape better. I am forever re-bending the wire back into shape.
3. Not recommend CA for the build but Scotch instead, perhaps even offer a kit bundle with a tube of Scotch.
For me the tail wheel has not been a problem, and I don't mind having the fuse break on a crash. I think that if it is made too strong other areas are going to break which are harder to fix eg wing tubes etc.
Old Feb 10, 2012, 09:24 PM
bigroger is offline
bigroger's Avatar
Joined Aug 2011
Nac, nobody said there was going to be any change to the price. The question was asked but we haven't heard back from Max on that.
I'm very happy with the landing gear wire as is. Firewall fix yes, cabin wall strengthen most definitely, tail wheel not too fussed. I don't know if that carbon box tube they are adding to the cabin needs to go all the way to the tail but just to the ends of the cabin would be enough.
The firewall is strange, I've nose smashed my yak dozens of times (just ask Max how many motor shafts I've purchased for the 3715 motor) and not once has that fire wall even moved. Both the extra and MXS firewall delaminated very early in the planes life, so what even it is in the Yak they could duplicate in the MXS and extra. I suspect its the shear length of the firewall. The Yak is another 25mm or so taller in that area.
Don't really care about the glue bundle as its pretty cheap anyway.
Discussion What's a good all-in-one lipo battery analyzer? flynfish67 Batteries and Chargers 2 Mar 18, 2011 05:28 AM
Discussion Skywing 48" YAK 54 rmgmag 3D Foamies 4 Jan 17, 2011 04:26 AM
