Old May 02, 2011, 05:47 PM
subsonic is online now
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
Ha ha. "Sky Wimg" on the SFG's. It will be like coin collecting. Those with typos are worth far more than those without.
The MXS has the same landing gear as the yak. I have 92 flights on that one, and the gear is still fine. I've had quite a few bigish hits to the gear, and it just bends back a bit and you just straighten it by hand. IMO, this is how all gear should be.
sub
subsonic is online now Find More Posts by subsonic
Old May 02, 2011, 06:31 PM
stevelmaa is online now
Find More Posts by stevelmaa
Renton, Wa.
Joined Feb 2006
Good to hear.
stevelmaa is online now Find More Posts by stevelmaa
Old May 02, 2011, 08:04 PM
blxpy is offline
Find More Posts by blxpy
Glue-it-again-Ben!
blxpy's Avatar
Adelaide, Australia
Joined Apr 2008
Mine just landed... Woot!
blxpy is offline Find More Posts by blxpy
Old May 02, 2011, 08:26 PM
IMK is offline
IMK
Find More Posts by IMK
IMK
Australia, VIC, Melbourne
Joined Aug 2005
Nice work Nac.
How much of a gap do you think is required between the ailerons and the SFG's?
I noticed that part of the SFG's have some flex in them (where there is no CF).
IMK is offline Find More Posts by IMK
Old May 02, 2011, 08:28 PM
blxpy is offline
Glue-it-again-Ben!
blxpy's Avatar
Adelaide, Australia
Joined Apr 2008
sub
LOL. Didn't spot that.
I agree with your take on the LG. Looks very strong up top and has the potential to give down the bottom 1/2 where it's needed.
Are you all planning on using the supplies push-rods as per the pictured set-up?
Love the quality of this kit!
Old May 02, 2011, 09:13 PM
nac is offline
nac
Find More Posts by nac
nac
nac's Avatar
Melbourne, Australia
Originally Posted by IMK View Post
Nice work Nac.
I think I left about 1mm, but you could leave a bit more.
I used all of the supplied push rods and connectors. All seems fine to me.
One thing that I would have liked is fibreglass control arms instead of wood on the ailerons. I am sure that the wood ones won't last very long and get a bit sloppy, and I'll have to add some plastic doublers.
[updated some pics]
http://www.rcgroups.com/forums/showp...0&postcount=74
nac is offline Find More Posts by nac
Old May 03, 2011, 12:56 AM
IMK is offline
IMK
IMK
Joined Aug 2005
Nac, thanks for taking the time to post the build pics and tips.
Old May 03, 2011, 04:11 AM
biznitch is offline
Find More Posts by biznitch
Wantirna Sth Vic,Australia
Joined Jul 2006
Have you guys used the HXT MG14's before? HK reviews paint a dubious picture of their reliability.
biznitch is offline Find More Posts by biznitch
Old May 03, 2011, 04:24 AM
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
I've used a few. The four in my yak have been perfectly reliable. Used them in plenty of other places too. A good budget option.
Old May 03, 2011, 04:39 AM
groovejet is offline
Find More Posts by groovejet
How many planes is too many?
groovejet's Avatar
Joined Aug 2007
I have used lots of MG14 servos and have found them to be very good. I've never personally had a faulty one out of perhaps 40 of these servos. I've eventually killed a few after far too many crashes with my foamies but honestly, I would've killed anything in this size range with the abuse I put some of my foamies through.
groovejet is offline Find More Posts by groovejet
Old May 03, 2011, 04:40 AM
groovejet's Avatar
Joined Aug 2007
Originally Posted by stevelmaa View Post
Groove, does the motor sit behind the firewall or in front?
Steve, the motor sits in front of the firewall.
Old May 03, 2011, 04:45 AM
groovejet's Avatar
Joined Aug 2007
Originally Posted by blxpy View Post
Looking good Groove.
Any thoughts on the LG? Up to rough grass fields?
Have you made and mods yet mate? C'mon you can tell us...
Hey Ben,
No real mods yet, though I did soak the wood aileron horns in thin CA on both sides to strengthen them a bit and hopefully reduce wear over time. I'll be hand launching this plane and harrier landing it, so the landing gear will be fine for my needs . If you're gonna actually roll around on the ground using the landing gear then I'd suggest a CF rod cross brace tied on with cotton and soaked in thin CA to stop the legs sagging over time. I've done that on a few planes and it works well, though you could add that down the track.
EDIT: I'm still slowly working on my MXS. The kit arrived when I was partway through building a Goldwing Raven 49" balsa plane kit that I bought from bestvaluerc.com. This photo gives you guys an idea of how cramped my build room currently is due to having 2 large planes under build right now.
Old May 03, 2011, 06:32 AM
nac is offline
nac
nac
nac's Avatar
Hey guys, I just finished setting up my radio.
The MG14's are working fine with the supplied largest arms. I drilled the second hole in and attached the connector without washers as there wasn't enough thread with them. I used the inner hole on the elevator horn and the second inner on the rudder horn. This is giving me full throws by adjusting my end points.
I did have some binding on the elevator but I fixed that by scrapping away some of the dried CA.
My only concern now is that I may not have the power. I measured 1.9kg thrust on the bench and the plane weighs 1.1kg. I'll find out tomorrow
Old May 03, 2011, 09:49 AM
rmgmag is offline
Find More Posts by rmgmag
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
Originally Posted by groovejet View Post
..... partway through building a Goldwing Raven 49" balsa plane kit that I bought from bestvaluerc.com. .....
I'd really like to hear about that Raven when you get a chance. I've been looking for one for ages.
Bob
rmgmag is offline Find More Posts by rmgmag
Old May 03, 2011, 01:25 PM
Renton, Wa.
Joined Feb 2006
Mine made it in. Looks great except it looks like someone took a screwdriver and poked a hole all the way through both wings. No big thing, I can patch them. Will look closer after work. Looks very well built though.
Discussion What's a good all-in-one lipo battery analyzer? flynfish67 Batteries and Chargers 2 Mar 18, 2011 05:28 AM
Discussion Skywing 48" YAK 54 rmgmag 3D Foamies 4 Jan 17, 2011 04:26 AM
