Old Jan 01, 2012, 08:20 PM
groovejet is offline
Find More Posts by groovejet
How many planes is too many?
groovejet's Avatar
Australia, VIC, Melbourne
Joined Aug 2007
I use HS65MG, HS85MG and HS5085MG in my balsa planes and in a bad crash I have stripped a few of those. I've also had a few eventually get twitchy.
I use MG14 servos in large foamies because I crash foamies a lot more than my balsa and I expect servos do die occasionally from a combination of crash damage and in-flight stress. MG14 servos are a little over $6 USD with a buddy code and HS65MG servos are about $25 AUD at the best of times and usually closer to say $30. The spare gears for HS65MG servos are about $8-9 USD too, which is more than an entire MG14 servo. I prefer to just rip out a faulty MG14 servo and install a new one rather than mess around changing broken gears. I've done it enough times on my balsa planes that I don't enjoy doing it and sometimes the HS65MG servo is damaged in a way that a spare gear set cannot fix. There are too many servos for me to try, so once I find one that works for me I tend to stick with it. For very small foamies I like HXT500, for larger but still small foamies I like HXT900, for larger foamies I like MG14 and for balsas up to about 49" wingspan I like HS65MG and HS85MG. There are advantages in standardising gear, such as the ability to steal parts from another plane as need be. BTW I have pretty much standardised on Turnigy Plush ESCs since I have found them to be very reliable and the amp ratings are very honest.
Bleary, if you're seeing blowback, it might actually be caused by tightness in the ez connector on the servo arm, the z bend hole on the control horn or the hinge line itself. Make sure all of those are nice and loose. ON one of Nac's planes he was getting poor strength and deflection on his elevator and it turned out to be some CA that was cured with kicker clogging up the hingeline. Once he cleared that he was good to go.
groovejet is offline Find More Posts by groovejet
Old Jan 01, 2012, 08:37 PM
Ziggytzag is offline
Find More Posts by Ziggytzag
Glue is my friend
Canada, ON, Burlington
Joined Nov 2011
How about Ball and roller links
Hey Guys I vaguely remember someone talking about ball and roller links
in some posts long ago.
Would they help in reducing some of the stress on these servos
and can someone recommend a size or type that would probably work best on these planes, preferably one available at HK
Z
Ziggytzag is offline Find More Posts by Ziggytzag
Old Jan 01, 2012, 08:48 PM
bigroger is offline
Find More Posts by bigroger
Just flitting about!!
bigroger's Avatar
Joined Aug 2011
Thanks GJ and Bleary.
I too have pretty much standardised on the same servo list for the same reasons you stated. As I fly the SW Yak almost daily and have had some carnage its probably from that. The epp telink type planes are a lot more flexible on the surfaces on impact so most likely not as damaging to the servo.
Its funny though as the jitters are not stripped gears as such just seems to be a centering issue when connected up.
Like you I'd rather toss in a new MG14 than muck around pulling the servo down for repair.
I've had a pretty good run I think with the MG14's compared to some others, I've had HXT500's strip after one tail touch as with HXT900's as well but usually from more aggressive impacts. Never stripped an MG14 or a HS65MG until my 42" slick went down on new years eve, destroying the fuse and stripping on aileron servo pretty bad.
Frees up 3 HS65MG's for another plane now. I simply can be bothered rebuilding a box of tooth picks.
bigroger is offline Find More Posts by bigroger
Old Jan 01, 2012, 08:51 PM
groovejet's Avatar
Joined Aug 2007
Z,
Personally I don't think that ball links are necessary, since the plastic control horn is flexible enough, the pushrod is flexible enough and if you use a nice thin long CF arm like the ones that bestvaluerc.com sell then even the servo arm is flexible enough.
If you take care when assembling to ensure that your pushrods are on the right side of the control horn and the servo arm, and also make sure that your ez connector spins easily and that your control horn hole is large enough for the pushrod to rotate easily without the hole being so large that there is slop, then you're good to go.
BTW Put your ez connectors on the inside of all servo arms for the best geometry and use the right holes on your servo arms and control horns to get the right geometry and servo end point adjustment (greater than 100% if possible) then it'll all work very well.
If you wish to experiment with ball links, then get some 2mm diameter bolts, washers and nuts from Hobby King as well as their ball links in a suitably small size that matches the size used by EF and 3DHS in their 48" balsa kits. I've used these ball links at times on my balsa planes, particularly to replace faulty ones out of the box! http://www.hobbyking.com/hobbyking/s...idproduct=8855 You could epoxy some CF rods into them or if you find the right metal threaded rods they will screw right in like EF 48" EXP kits; don't use CA glue if you glue CF rods in the holes! Personally I don't think it's worth the hassle. Feel free to post some pics of your setup and we can recommend some changes if necessary to improve their effectiveness.
Old Jan 01, 2012, 09:39 PM
Glue is my friend
Joined Nov 2011
Thanks GJ
sounds like I'll use the CF arms from bestvalue
I think I understand that I should check and make sure I have free movement
for 100% or better of travel but I'm not sure what you meant here
are you refering to a specific hole or orientation or do you mean
test to see which holes on the servo arm and control horn works best?
I haven't started the build yet still waiting on parts ordered and have a few pieces still to order
We are just getting into the heart of our winter here ( so far so good) so I plan on taking my time on this build.
Again Thanks
Z
Old Jan 01, 2012, 09:46 PM
bleary is offline
Find More Posts by bleary
Cookie Monster
Australia, QLD, Diddillibah
Joined Aug 2005
[QUOTE=groovejet;20292951
Bleary, if you're seeing blowback, it might actually be caused by tightness in the ez connector on the servo arm, the z bend hole on the control horn or the hinge line itself. Make sure all of those are nice and loose. ON one of Nac's planes he was getting poor strength and deflection on his elevator and it turned out to be some CA that was cured with kicker clogging up the hingeline. Once he cleared that he was good to go.[/QUOTE]
Thanks for the detailed info GJ,the linkage is fine and works well on the ground,it's just when under some stress (downlines/speed etc),I don't seem to have the same deflection.It's a bit hard to tell,so I will check with the camera.
It may well be that my home made servo horn extensions are bending,or even the wire,but I suspect deflection of the EPP is probably the case.
Not a major problem and I think a comparison with my MXS with new servos may be interesting(plus I have some CF long arms coming as well)
bleary is offline Find More Posts by bleary
Old Jan 02, 2012, 05:07 AM
groovejet's Avatar
Joined Aug 2007
Originally Posted by Ziggytzag View Post
Thanks GJ
Again Thanks
Z
Z,
Sorry, I was making a quick statement that covers quite a few things.
Mount the ez connectors upside down on the servo arms so that the pushrods pass underneath the servo arms. Run the aileron pushrods between the control horn and the servo as this generally gives a better geometry when the servo deflects, but sometime the z bends on the pushrod are so far off being a right angle that it can actually work better with the pushrod on the other side. The idea here is to reduce the stress on the control horn when the servo is close to fully deflected and changes the angle that the pushrod is at relative to the control horn. Try to use the highest hole on the control horn that you can get away with based on the length of your servo arms. Use the closest hole that you can on the servo arms that still allows you to get somewhere over 100% end point travel if you can.
Using higher holes on the control horns will give better pushrod geometry but only use a higher hole if your servo arm gives sufficient surface deflection.
As a rough guide, using the long CF arms sold by bestvaluerc.com and using the 2nd last hole on those arms, I use the following control horn holes:
2nd hole from the bottom on the ailerons
4th hole from the bottom on the rudder
3rd hole from the bottom on the elevator
The rudder easily gets the desired deflection on the 4th hole, the elevator didn't quite deflect far enough on the 4th hole so it is on the 3rd hole and the ailerons needed to be on the 2nd hole to get the desired deflection as when they were on the 3rd hole the plane didn't quite have enough aileron deflection to stop it torque rolling when hovering.
Old Jan 02, 2012, 05:25 AM
rcguy1958 is offline
Find More Posts by rcguy1958
USA, NY, Poughkeepsie
Joined Mar 2010
Groove Jet I 've got a slightly off topic question for you, was wondering if you have any experience with the Hokusei models sold on Best Value RC ? and if you do, how do they compare to the skywing products ?
They look to have a very interesting lineup of models that fly fairly well from the videos on the hokusei website ( I do know that a good pilot can make a bad plane look pretty good...hence the questions)
Sorry for going off topic and appreciate any feedback
rcguy1958 is offline Find More Posts by rcguy1958
Old Jan 02, 2012, 01:31 PM
Glue is my friend
Joined Nov 2011
Thanks again GJ
I will give it a try
Z
Old Jan 06, 2012, 02:45 AM
nac is offline
nac
Find More Posts by nac
nac
nac's Avatar
Melbourne, Australia
Pimp my MXS
I decided to pimp my MXS's today.
nac is offline Find More Posts by nac
Old Jan 06, 2012, 04:48 AM
bleary is offline
Cookie Monster
Joined Aug 2005
Very Noice...the red really stands out.Good job
Old Jan 06, 2012, 02:52 PM
3D Peter is offline
Find More Posts by 3D Peter
3D Peter's Avatar
Joined Oct 2011
cool paintshemes, nac
.....how many of them does he actually have
nac seems to develop an addiction
regards
3D Peter is offline Find More Posts by 3D Peter
Old Jan 06, 2012, 03:05 PM
nac is offline
nac
nac
nac's Avatar
Don't mention (PA) "addiction", bad memories.
I have two new MXS's as I sold my first one.
I just had to have two of the best foamie around, in case I loose one in a tree.
Old Jan 06, 2012, 03:40 PM
3D Peter is offline
3D Peter's Avatar
Joined Oct 2011
epp addiction, of course
loosing one in a tree might be one of few ways to loose this plane, I did some unplanned durability testing again today, nothing special happened, as usual, just bent the gear back into correct position and the fun continued
Old Jan 06, 2012, 03:52 PM
nac is offline
nac
nac
nac's Avatar
Yep, a pine tree attacked one of my balsa's last week.
Discussion What's a good all-in-one lipo battery analyzer? flynfish67 Batteries and Chargers 2 Mar 18, 2011 05:28 AM
Discussion Skywing 48" YAK 54 rmgmag 3D Foamies 4 Jan 17, 2011 04:26 AM
