Old May 02, 2011, 12:12 AM
unlvace is offline
Find More Posts by unlvace
Las Vegas
Joined May 2008
Servos
Nac Groovejet, what servos are you using.
thanks
unlvace is offline Find More Posts by unlvace
Old May 02, 2011, 02:18 AM
nac is offline
nac
Find More Posts by nac
nac
nac's Avatar
Melbourne, Australia
I am going to use MG14's...
nac is offline Find More Posts by nac
Old May 02, 2011, 02:44 AM
groovejet is offline
Find More Posts by groovejet
How many planes is too many?
groovejet's Avatar
Australia, VIC, Melbourne
Joined Aug 2007
Hextronik MG14s for me .
groovejet is offline Find More Posts by groovejet
Old May 02, 2011, 03:50 AM
nac is offline
nac
nac
nac's Avatar
Got mine.
I just unpacked and inspected the parts. Very nice
No damage, all the parts are very well made and fit together nicely.
I'll probably start my build tonight or tomorrow, i'll take a few pics as I build and post them all together.
Old May 02, 2011, 04:13 AM
unlvace is offline
Las Vegas
Joined May 2008
Nac, looks good. Should receive mine in the mail any day.
This is my second Skywing. I love the easy of the build. I would say I am not a very good builder, but with Skywing airplanes majority of the work is done .
Would T-Pro MG90 9G Metal Gear Servo be a good choice.
http://www.hobbypartz.com/servo-mg90.html
thanks
Old May 02, 2011, 04:27 AM
blxpy is offline
Find More Posts by blxpy
Glue-it-again-Ben!
blxpy's Avatar
Adelaide, Australia
Joined Apr 2008
I don't mind the MG14s, but they're so fork and bloody loud!
I've got two D933MGs and are pretty happy with them. And nice and quiet! http://www.hobbyking.com/hobbyking/s...dProduct=10977 Might go these I think. Or MG14s.
Tried the 929MG: http://www.hobbyking.com/hobbyking/s...dProduct=11856... SHITE! LOST of flutter. Don't seem to hold as much as they are rated to. Too much slop. Apart that they're great and almost as new! Anyone want to buy them from me?
blxpy is offline Find More Posts by blxpy
Old May 02, 2011, 04:30 AM
blxpy is offline
Glue-it-again-Ben!
blxpy's Avatar
Adelaide, Australia
Joined Apr 2008
Still waiting for my kits though - hopefully tomorrow!
Old May 02, 2011, 05:02 AM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
Is the wing on this plane a solid piece of EPP, or is it built up?
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old May 02, 2011, 06:16 AM
IMK is offline
IMK
Find More Posts by IMK
IMK
Joined Aug 2005
Mine just arrived today.
The wing construction looks like a solid EPS or EPO foam core with a 4mm EPP sheet skin.
There also looks to be a full length spar in addition to a CF wing tube.
The wing appears to be very stiff. The ailerons match the aerofoil (i.e. not a flat plate)....if that makes sense.
The ailerons are also quite stiff.
The wing uses a similar construction method to my Winners Model Extra (except for the wing tube) which IMHO has produced a stiff and accurate wing.
You can tell by looking at this model that a lot of thought has gone into the design and construction.
The quality looks to be outstanding. I think Skywing have set a new benchmark for foamie design with this one.
IMK is offline Find More Posts by IMK
Old May 02, 2011, 07:24 AM
subsonic is online now
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
This is the same construction used on my Winners Model Extra (except for the wing tube) which IMHO has produced a stiff and accurate wing.
Things have changed since the 48" yak then. That wing is hollow with EPP ribs and skin with CF and ply spars.
As for servo choice, I used the MG14s in my yak. When set up for 40 degree throws on the ailerons, they are not man enough for full deflection at full speed. It's not a high speed plane though...
sub.
subsonic is online now Find More Posts by subsonic
Old May 02, 2011, 08:47 AM
groovejet's Avatar
Joined Aug 2007
I've more or less finished building the airframe. Here's a photo to show how it looks.
Old May 02, 2011, 10:20 AM
stevelmaa is offline
Find More Posts by stevelmaa
Renton, Wa.
Joined Feb 2006
Groove, does the motor sit behind the firewall or in front?
stevelmaa is offline Find More Posts by stevelmaa
Old May 02, 2011, 10:30 AM
blxpy is offline
Glue-it-again-Ben!
blxpy's Avatar
Adelaide, Australia
Joined Apr 2008
Looking good Groove.
Any thoughts on the LG? Up to rough grass fields?
Have you made and mods yet mate? C'mon you can tell us...
Old May 02, 2011, 04:33 PM
nac is offline
nac
nac
nac's Avatar
Build Pics and notes
Here are some pics and notes of my build.
- All of my previous EPP builds have been with Scotch glue but for this kit I used only CA (thin and Med).
- MG14's fit fine, but you may need to file one end of the holes to allow the servo to pop in without damaging the wires.
- I used two servo extension cables for the rear servos. I taped a small lead weight to the end of the cable and dropped it down.
- The wood servo aileron mounts seemed a little loose so I added CA around the wood/EPP.
- My horizontal stab hole was a bit out and caused the stab to not line up with the wings. So i used a some wedges to keep it in place until the glue dried.
- I added some Blenderm tape to both the elevator and rudder.
- The screws for the SFG's in my kit were too short, so I just found some long ones in my spare parts boxes.
- The plane without lipo ended up weighing 906g, so with my 2200 lipo the all up weight is 1100g
I still need to setup the throws and might find that I need servo extensions. Also I think my lipo will be all the way up the front of the box.
So I am very pleased with the build quality of the kit, being V1 there are a few minor things that may need updating but nothing major.
The only issue that you should pay extra attention too is the horizontal stab alignment with the wings. I would suggest that you test fit and trim the slot if required.
Old May 02, 2011, 04:48 PM
Renton, Wa.
Joined Feb 2006
Everything looks great. I am wondering about the landing gear also though. Hope it holds up to grass.
Discussion What's a good all-in-one lipo battery analyzer? flynfish67 Batteries and Chargers 2 Mar 18, 2011 05:28 AM
Discussion Skywing 48" YAK 54 rmgmag 3D Foamies 4 Jan 17, 2011 04:26 AM
