Old Jun 11, 2011, 10:51 AM
stevelmaa is offline
Find More Posts by stevelmaa
Renton, Wa.
Joined Feb 2006
Sounds like a great set up.
stevelmaa is offline Find More Posts by stevelmaa
Old Jun 11, 2011, 07:48 PM
feda is offline
Find More Posts by feda
EP 3D Flyer
feda's Avatar
Hamilton, Canada
Joined Nov 2005
Prop Comparison
Today, I've got the chance to try out a Gemfan 13x6.5e prop, which looks almost identical to the APC 13x6.5e. In the attached 2 photos, the Gemfan one is on the right side, while the APC one is on the left.
Test Set-up:
- AX3715 KV1000 motor, weight with accessaries: 125 grams;
- Hobbywing 40A ESC;
- Gemfan 13x6.5e;
- Hobbyking Zippy Lipo 20C 2200 mAh;
- Spektrum DX7, Spektrum AR6100e
ax3715kv1000gfprop.mp4 (1 min 51 sec)
It seems to me that the Gemfan prop is about 10% less efficient than the APC one. The former draws about 20A to generate 1100 gram thrust while the latter does about 18A. The former peaks roughly at 1650 grams of thrust while the latter does so at 1850 grams. And the amp draws in both cases are about the same -- 44A.
feda is offline Find More Posts by feda
Old Jun 12, 2011, 09:47 AM
feda is offline
EP 3D Flyer
feda's Avatar
Hamilton, Canada
Joined Nov 2005
AX3715 KV870 Motor Test
OK, I tested the recommended KV870 version of the motor.
Test Set-up:
- 13x6.5e propellor;
The first is with an APC 13x6.5e prop, and the second with a Gemfan 13x6.5e prop.
ax3715kv820apcprop.mp4 (2 min 17 sec)
ax3715kv820gfprop.mp4 (2 min 23 sec)
My observations:
- the system reaches its maximum power output at roughly 80% throttle;
- with the APC prop, the system draws about 17A to generate 1100 gram thrust;
- with the APC prop, the system peaks at 25A and 1400 gram thrust;
- with the Gemfan prop, the system draws about 19A to generate 1100 gram thrust; and
- with teh Gemfan prpo, the system peaks at about 27A and 1300 gram thrust.
My conclusion: with a 13-inch prop, the kv is too low to utilize the potential of the battery and probably the motor. Maybe a larger prop will get more power out of the system.
feda
P.s., it is interesting to note that the kv870 version seems to be a more efficient, i.e., drawing less power to genereate a certain amount of thrust, motor than the kv1000 version.
Last edited by feda; Jun 20, 2011 at 09:12 PM. Reason: Adding a postscript. Motor weight revised.
Old Jun 13, 2011, 10:02 AM
Brubache is offline
Find More Posts by Brubache
If it hovers I fly it.
Brubache's Avatar
Canada, BC, Vancouver
Joined Jun 2010
Apparently my kit was a V2 version. Build went well. Maidened yesturday. Few tics of elevator and she was good to go. This was my second plank build. My first being a 33" 3dhs Edge foamy. Over all I was very impressed with how it flies. Straight out of the box I could fly every manouver I could with my 33". I was a bit intimidated at first I have never flown anything that size ( started flying planks in January with my 33' ).
Observations: KE very nice. Hands off hovered well! Snap rolls and tumbles where a joy. Easy to recover from but certainly has some mass behind it. Flies very well in the wind. Can really fly along nice and slow. Unlimited vertical with the 12x6e on my Hacker A30-12l V2. 5min flights took 1200mah out of 2100mah packs.
Overall I am very satisfied with the Skywing MXS. Ill post some pics of my build later on.
Build Notes: The firewall on my unit was incorrectly marked. Was off to the left side of the airframe rather badly. My kit also included revised wings which the manual made no note of. English manual would be very nice. Especially for noobies like me! Not that its hard to figure out but it would certainly help.
My build came in at 38oz with no weight saving measures taken.
Brubache is offline Find More Posts by Brubache
Old Jun 13, 2011, 09:47 PM
IMK is offline
IMK
Find More Posts by IMK
IMK
Australia, VIC, Melbourne
Joined Aug 2005
Brubache, out of curiosity, what's different with the v2 wings?
IMK is offline Find More Posts by IMK
Old Jun 13, 2011, 11:38 PM
Brubache is offline
Brubache's Avatar
Joined Jun 2010
The V2 adds reinforced landing gear area and wings have slightly shorter ailerons and there is a foam block at the inside edge against the fuse. Adds a more scale look I suppose.
Old Jun 13, 2011, 11:51 PM
blxpy is offline
Find More Posts by blxpy
Glue-it-again-Ben!
blxpy's Avatar
Adelaide, Australia
Joined Apr 2008
Very nice pics Brubache!!
Finally started my V1 build last night. Re-enforced the LG assembly with solid EPP blocks glued in under the skin fore and aft and PU'd the gear into plage. Looks nice and solid.
Going to put slightly bigger wheels on as I find this one of the best mods to any plane I fly from rough grass fields.
Might up the heft of the wing tube too - sounds like some V1's have cracked the very light tube supplied.
Any other mods to V1 people recommend?
blxpy is offline Find More Posts by blxpy
Old Jun 14, 2011, 01:28 AM
IMK is offline
IMK
IMK
Joined Aug 2005
Thanks for posting the pics Brubache. You've inspired me to get a hurry on with finishing my V1 build.
Old Jun 14, 2011, 09:32 AM
Brubache is offline
Brubache's Avatar
Joined Jun 2010
Thanks Lads! Glad you enjoyed them. Yes get those birds done! Really nice machine!
Old Jun 14, 2011, 07:26 PM
unlvace is offline
Find More Posts by unlvace
Las Vegas
Joined May 2008
[QUOTE=blxpy;18494997]Very nice pics Brubache!!
Can you post pictures.
unlvace is offline Find More Posts by unlvace
Old Jun 15, 2011, 12:47 AM
blxpy is offline
Glue-it-again-Ben!
blxpy's Avatar
Adelaide, Australia
Joined Apr 2008
Hi Unlvace. The work is all covered up by the outer EPP skin.
I still have to do the mod on my friends kit, and when I do I'll take a few pics.
Cheers!
Old Jun 16, 2011, 04:36 PM
CaptDH is offline
Find More Posts by CaptDH
GET BACK IN THE SHOP!!!!!!
CaptDH's Avatar
United States, CA, Avalon
Joined Oct 2002
New to this thread and aircraft. Appears to be what I have been looking for.
Is the MXS the newest one that is available or the Sbach?
Can someone steer me to the motor packages or setups?
I do have several 2200 25c batts. that are waiting for a new home.
D
CaptDH is offline Find More Posts by CaptDH
Old Jun 16, 2011, 05:04 PM
Brubache is offline
Brubache's Avatar
Joined Jun 2010
MXS is latest.
I use:
4s Hitec HS-65hb
Hacker A30-12L V2
Hacker X55 Esc
12x6e APC Prop
2x 12in servo extensions
1x Y cable
1x Spektrum Receiver AR600
2200mah Hyperion 3s and TP Lipos
D
Old Jun 17, 2011, 12:39 AM
Kaffine is offline
Find More Posts by Kaffine
If I duck, you RUN
Kaffine's Avatar
Australia, WA, Kallaroo
Joined Jan 2010
MSX maiden
Greetings fliers
excerpt from a PM to GrizzlyM
OK I dashed down to the park for a fly, 2 clicks of aileron not sure if I needed it as the wind had picked up and the MXS gets beaten about in the wind abit. flies like nothing else I've flown nice and stable on low rates and just wants to harrier at slow speed, had it stalled into the wind and it just stayed there, gave it some up and it went into hover, just my skills couldn't keep it there then OMG when the switch is flicked to high rates will snap roll with in its own length (whilst throwing the landing gear off), KE loops no probs seems to KE straight but again it was breezy so hard to tell. flats spins and almost KE spins (again skill issue). Can't wait for a calm day but at least on a breezy day 10+ knts you don't need the landing gear as it will harrier to stop on the ground
If you don't own one of these...THEN WHY NOT
well unless they're out of stock
Still grinnin
Craig
Kaffine is offline Find More Posts by Kaffine
Old Jun 17, 2011, 02:08 AM
cleansho93 is offline
Find More Posts by cleansho93
Joined Oct 2008
Where is the best place to buy the MXS V2 from? I am in the USA and would prefer a domestic retailer. Thanks!
cleansho93 is offline Find More Posts by cleansho93
Discussion What's a good all-in-one lipo battery analyzer? flynfish67 Batteries and Chargers 2 Mar 18, 2011 05:28 AM
Discussion Skywing 48" YAK 54 rmgmag 3D Foamies 4 Jan 17, 2011 04:26 AM
