I flew it today. I used two little quick ties to keep wings together. The plane flies perfect. The guys at the field asked it I hit the knife edge button. First flight did knife edge, knife edge loop, and knife edge spins. The spins went on and on and on. Crazy!
I did have an issue with my ESC, it keeps resetting. Im not sure what's wrong. I checked everything and it is programmed properly. it is an e-flite 40 amp. there is not much to programming it. I can't figure it out. it sees the motor would cut out every time I was pointed up at an angle getting ready to go inverted. Motor would stutter then cut out. pull throttle back down then resets. There is not a procedure for throttle range on this one, just lipo or nimh setting and brake. I shut brake off and have on lipo. It was default that way too. Weird... ESC manual http://www.e-fliterc.com/ProdInfo/Fi...rushlessV2.pdf |
| Thread Tools | |
| Discussion What's a good all-in-one lipo battery analyzer? | flynfish67 | Batteries and Chargers | 2 | Mar 18, 2011 05:28 AM |
| Discussion Skywing 48" YAK 54 | rmgmag | 3D Foamies | 4 | Jan 17, 2011 04:26 AM |
