Old Apr 16, 2011, 09:31 AM
Enguneer is offline
Find More Posts by Enguneer
Heli of a man
Enguneer's Avatar
Joined Dec 2010
People have encountered a small problem with Hitec's Aurora 9 radio
The symptoms
Apparently, some users have found that on at least one stick, movement near the end of travel produces no corresponding movement of the servo. In effect, there is a "dead zone" there.
Now this isn't the first modern computerized radio that I've seen exhibit these symptoms. In fact there have been a number of folks reporting similar problems with the FlySky/Turnigy/iMax 9X radio and I've encountered exactly the same symptoms on one of these radios I had here.
It's not the end of the world of course and, in normal flying, it's most unlikely that anyone's going to notice if the last fraction of an inch of stick movement does nothing...
Unless, that is, it happens to be the lower part of your throttle stick that is affected (as it was on the 9X I encountered. It is actually very frustrating if the throttle servo doesn't track the first part of the stick movement precisely.
In the case of the Hitec, performing the built-in recalibration process doesn't seem to fix this problem -- and I think I know why.
What's the cause?
I'm speculating here, based on many years experience with microcontroller-based systems mind you...
At the heart of a modern computerized radio transmitter is a microcontroller -- a kind of "whole computer in a chip". This component does a huge amount of work but the first thing it does is convert the voltage which comes from your radio's stick units into a digital value.
To do this, a system called an Analog to Digital Converter (ADC) is used.
Most low-cost microcontrollers have 10-bit ADCs, which means that they have a maximum resolution of 1024 different values (hence the reason we've had 10-bit/1024 resolution in our computer radios for so many years.
In order to provide the maximum resolution for stick movement, it's important that the sticks are fed with a precise voltage and that the center position of the stick corresponds with exactly the mid-range of those 1024 steps that can be measured.
Now, if the potentiometer that measures the stick position (by returning a voltage) is not positioned so that the center-position is the mid-voltage then we have a potential problem.
In such a situation, it is possible that the voltage returned from the stick when it is moved to an extreme position, falls outside the maximum or minimum that the ADC can measure. In that case, the ADC simply returns a value of 0 or 1023 (depending on which end of the stick is affected).
In effect, the ADC can't report anything below 0 or anything above 1023 so when a misaligned stick tries to deliver a voltage outside that range, the value remains unchanged and therefore no servo movement is produced.
What's the fix?
The ideal fix is to move the potentiometer so that the stick center-position accurately represents the center-voltage. Unfortunately, the way most radios are designed, such tiny changes to the alignment of the stick and the pot are not possible.
Although some computer radios (like the Hitec Eclipse 7) are designed to allow easy centering of the potentiometers so as to avoid an endpoint dead-zone, it appears that some other radios (and that includes the A9) are not.
In fact, more often than not, these days the stick gimbal is keyed to the potentiometer shaft by a flat on that shaft so no change in the relationship of these two parts is possible. Also, the potentiometer itself mounts on the stick system such that it is keyed by a small metal tab on the body of the pot.
So, if a mechanical realignment of the parts isn't easy, what are the alternatives?
The pot could be replaced -- since it's likely that the one causing the issues is simply slightly out of spec. This will probably do the job, unless it's a design fault in the stick system alignment that's causing the problem.
Another possible solution is to add a small-value resistor in series with one of the pot-wires so as to slightly reduce the total voltage that appears across the pot and thus ensure that the stick movement doesn't result in values that exceed the ability of the ADC to track it.
In theory, this will also produce a small reduction of the total servo-throw on that channel but a recalibration of the transmitter and a small tweak to the EPA values should compensate for that.
Of course the best solution for most people would be to simply send the radio back under warranty -- and I recommend, wherever practical, that this is what people do. Fortunately for A9 owners, Hitec's after-sales support is the stuff that legends are made of so you'll be looked after -- once they figure out the cause and remedy.
However, if there are people out there who'd rather give this a go themselves then I'm happy to provide a blow-by-blow explanation of how to calculate the necessary resistor value and where to put it so as to eliminate an end-point dead-zone.
And remember, if you want a full RCModelReviews review of the A9, just let Hitec know ;-)
It's a bit of a shame that Hitec opted to use a cheaper microcontroller with just 10bits of resolution (1024 steps). If they'd gone for an 11-bit ADC they could have allowed for any pot misalignment and achieved almost twice the resolution (like the equivalent offerings from JR and Futaba) as well.
Still, it's worth remembering that the A9 is a very well-priced product and when establishing a competitive price-point in the market, some compromises must be made.
Enguneer is offline Find More Posts by Enguneer
Old Apr 16, 2011, 09:33 AM
Enguneer is offline
Heli of a man
Enguneer's Avatar
Joined Dec 2010
Just wanted to share this info that was sent to me..Hope This will help anybody having this issue..
Old Apr 16, 2011, 09:46 AM
Enguneer is offline
Heli of a man
Enguneer's Avatar
Joined Dec 2010
Did not recieve the fix suloutin video..
Old Apr 16, 2011, 09:55 AM
Dr. Evil is offline
Find More Posts by Dr. Evil
Just trying to fly...
Dr. Evil's Avatar
NC
Joined Jan 2011
Yeah, I've read this somewhere before and I am not sure when this was written but so far I've not come across anything wrong with mine....atleast not during my setup of the radio and to all the servos getting trimmed out. That said, it may be an issue already being taken care of as mine was purchase not too long ago....oh well, we'll see I guess.
Perhaps, I can post this question to Finless Bob as he did a full coverage of the Aurora 9.
Dr. Evil is offline Find More Posts by Dr. Evil
Old Apr 16, 2011, 10:00 AM
Enguneer is offline
Heli of a man
Enguneer's Avatar
Joined Dec 2010
Cool...Does not seem to be "to big of an issue', just enough to be aware that there might be a slight lack of performance..Not enough for any beginer out there to notice..As i'm sure an expert wrote this article..
This is the web site of the artical...http://www.rcmodelreviews.com/aurora9issues.shtml
Old Apr 16, 2011, 10:01 AM
Dr. Evil is offline
Dr. Evil's Avatar
NC
Joined Jan 2011
Service Bulletins from Hitec
#TX-20100520 Aurora 9 Transmitter - Using EPA and D/R Functions Create Dead Zone in Stick Travel
We have confirmed customer reports of a software bug involving the End Point Adjustment and Dual Rate functions. When both functions are at their highest settings, there is a significant dead zone at the stick endpoints. Until this issue is resolved in a future software update, it is advisable for customers to keep either the D/R or EPA setting at 125% or less and the other at 120% or less.
http://www.hitecrcd.com/support/serv...t20100520.html
....so I guess there may be an update to the software coming soon.
Old Apr 16, 2011, 10:08 AM
Enguneer is offline
Heli of a man
Enguneer's Avatar
Joined Dec 2010
Nice, Hope that works..Like i said It's not do or die situation, But for a expert it would be thorn in there thumb..lol
Old Apr 16, 2011, 10:16 AM
Dr. Evil is offline
Dr. Evil's Avatar
NC
Joined Jan 2011
Yeah, thanks for posting that. I just send a question to Finless, hopefully he can get back to me with an answer. But you may be right...I may never notice when I am flying.
Side note, about your new radio..I found this promo. Not sure if you know, thought you can use it to your advantage.
http://www.futaba-rc.com/promos/trad...011/index.html
Old Apr 16, 2011, 10:19 AM
Enguneer is offline
Heli of a man
Enguneer's Avatar
Joined Dec 2010
Yea I read that before, thanks 4 the reminder..I just love having the interWeb @ my fingertips ..hehe..
Old Apr 17, 2011, 11:37 AM
Dr. Evil is offline
Dr. Evil's Avatar
NC
Joined Jan 2011
answer back from Finless Bob
Originally Posted by Finless
I do not know when that will be fixed but it is a pretty rare bug. I do not know many heli setups that require you to
1) Jack up the EPA's past 100 although this in of itself does not cause the problem
2) Then with EPA past 100 set up a dual rate that is over 100% of EPA. Dual rates are usually used to reduce throw not increase throw.
So unless you need this kind of wacky setup, you will never see this bug.
If I hear it is fixed at some point I will post it here.
Bob
....Thought I share this with everyone cause Bob is very knowledgable!
For Sale hitec aurora 9, 3 optima 7, 3 optima 9, $500 thedood Aircraft - General - Radio Equipment (FS/W) 10 Apr 02, 2011 11:15 PM
Sold Hitec Aurora 9 w/optional Rxs panzercreation Aircraft - General - Radio Equipment (FS/W) 8 Mar 11, 2011 09:09 AM
Discussion How to wire 4S lipo to Hitec Optima Rx (Aurora 9)? Scott_S. Radios 4 Mar 10, 2011 02:42 PM
Sold Hitec Aurora 9 TX&RX +HPP-22 + Telemetry Pack sold joe1l Aircraft - General - Radio Equipment (FS/W) 2 Mar 07, 2011 04:09 AM
Discussion problem with my aurora 9 HITEC fred11 Radios 4 Jun 08, 2010 08:11 AM
