Old Aug 15, 2003, 05:41 PM
Brain_Washed is offline
Find More Posts by Brain_Washed
Tiger Moth fan
Brain_Washed's Avatar
Sumner, WA
Joined Jul 2003
Will a dual IPS-A 4.8V work with an Etec 1200 2S1P?
I went to my hobby shop to get a replacement dual IPS-A and I just realized that they gave me a 4.8V model. Damn.
Will this 4.8V motor work in my Tiger Moth that has a 2S1P Etec 1200 battery or do I need to go all the way back to the shop to get a 7.2v IPS motor? I told him it was going into a Moth.
I didn't even know that there was a 4.8v version...
Brain_Washed is offline Find More Posts by Brain_Washed
Old Aug 15, 2003, 05:50 PM
fwilly is offline
Find More Posts by fwilly
Pro Bro #495
fwilly's Avatar
Farmington NM
Joined Apr 2002
you could rewire the motors in series or use a small prop.
fwilly is offline Find More Posts by fwilly
Old Aug 15, 2003, 05:56 PM
Tiger Moth fan
Sumner, WA
Joined Jul 2003
What would I need to do to rewire them?
Bascialy if I plug this right into my exisiting setup the motor is going to burn out, right?
Old Aug 15, 2003, 06:14 PM
fwilly is offline
Pro Bro #495
fwilly's Avatar
Farmington NM
Joined Apr 2002
It will live a short life wired in parallell, unless you use a much smaller than recomended prop. To wire it in a series, connect one of the postive wires to one of the negative wires and connect the two remaining wires to the esc.
Old Aug 15, 2003, 06:15 PM
Tiger Moth fan
Sumner, WA
Joined Jul 2003
gotcha.
I think I'll just go back and get the rigth motor...
Yippee! Will the new Himax direct drive motors work with an Alfa P-47? Electricman Parkflyers 4 Dec 08, 2004 01:12 PM
Alert WILL A EPS-350C DX THE GEAR IS "c" work with an 11 x 8 prop for the SS Zachary Beginner Training Area (Aircraft-Electric) 0 Aug 07, 2004 02:56 PM
Will Hummingboard work with an EDF? Mesmer Micro Helis 6 Dec 09, 2003 10:01 PM
Can I Parallel an Etec 1200-2S (2S1P) with a Qualcomm 830? mrebman Batteries and Chargers 5 Aug 08, 2003 12:02 PM
Will a 6.5-4 prop work with a direct drive Permax 480? Ryan Nau Power Systems 2 Apr 29, 2001 11:43 AM
