Old May 13, 2011, 03:49 AM
jerano is offline
Find More Posts by jerano
Joined Feb 2011
After using a landing skid from a trex 600, I settled for something cheaper, more stable, and easier to see...
colored floorball balls
gives enough clearence for a lipo and is pretty light weight.
jerano is offline Find More Posts by jerano
Old May 13, 2011, 07:17 AM
Joecnc2006 is offline
Find More Posts by Joecnc2006
www.joescnc.com
Joecnc2006's Avatar
United States, TX, Marion
Joined Jun 2007
I just cut some for my new Quad, Uses 500 skids. Only had white material for testing, will re-cut in black.
Joecnc2006 is offline Find More Posts by Joecnc2006
Old Jul 07, 2011, 12:42 PM
crispycargo is offline
Find More Posts by crispycargo
Joined Oct 2008
Originally Posted by capt View Post
Good idea here.
My favorite and used by many others.
http://www.hobbyking.com/hobbyking/s...idProduct=9535
Does anyone know the dimensions of these landing skids? I have a Y6 that I need a good/light set of landing gear and this looks perfect, but it needs to be tall enough.
Any help?
Thanks.
crispycargo is offline Find More Posts by crispycargo
Old Jul 20, 2011, 03:48 AM
hamburger is offline
Find More Posts by hamburger
Hamburger
hamburger's Avatar
Joined Jan 2010
skid length: ~24cm
skid 2 skid: ~14,5cm
ground clearance: ~5cm
Hamburger
hamburger is offline Find More Posts by hamburger
Old Jul 20, 2011, 04:44 AM
Jake Bullit is offline
Find More Posts by Jake Bullit
Fly,crash,glue,repeat!
Jake Bullit's Avatar
Southport,N.W. England
Joined Nov 2007
I thought about trying these:
http://directdampers.co.uk/dampers.html
Anyone tried them,are they strong enough?
Jake Bullit is offline Find More Posts by Jake Bullit
Old Dec 17, 2011, 09:59 AM
drcigg is offline
Find More Posts by drcigg
drcigg's Avatar
United States, MN, Chaska
Joined Sep 2011
I am thinking about using either the T-rex landing gear or one of the two from hobby king listed here. My only concern is if my quadcopter will be tippy on landing and not enough clearance to mount the batter. The arms on my quad will be 15in long in and X config.
drcigg is offline Find More Posts by drcigg
Old Dec 17, 2011, 01:01 PM
imagebuff is offline
Find More Posts by imagebuff
imagebuff's Avatar
United States, TX, Tomball
Joined Jan 2011
I've experimented with countless landing gear for my Tri. Take a look because here is the best!
- Super durable - almost unbreakable
- Flexible enough to absorb hard landings
- Ultra lightweight
- Very cheap
- Height adjustable
Parts needed
- carbon fiber rod
- front steering plastic bushings
- wooden / plastic spheres for the end
- zip ties
These things are the bomb. They are super easy to build and work great. Can't recommend them enough.
imagebuff is offline Find More Posts by imagebuff
Old Dec 17, 2011, 02:34 PM
drcigg is offline
drcigg's Avatar
Joined Sep 2011
Cool I haven't seen that before. Can you post links on where I can buy the parts?
Old Dec 17, 2011, 04:24 PM
imagebuff's Avatar
Joined Jan 2011
I picked up these parts from the local hobby shop. I've attached a photo of the nylon bushing.
Old Dec 17, 2011, 05:29 PM
drcigg is offline
drcigg's Avatar
Joined Sep 2011
Ok I found that white piece. They call it a nose gear bearing.
http://miniglowplanes.com/index.php?...t_detail&p=621
Did you glue the carbon fiber rod into the hole? How does it stay in. It looks like you ziptied the rest in which looks slick.
Old Dec 17, 2011, 05:54 PM
imagebuff's Avatar
Joined Jan 2011
Actually the carbon fiber rod fits so snugly that no glue is required. The zip ties have to be really tight. They actually provide the flex in the gear that absorbs landings. They will be the only thing to break in a very bad accident. Can't get easier to replace than zip ties.
Old Dec 17, 2011, 06:18 PM
drcigg is offline
drcigg's Avatar
Joined Sep 2011
sweet. I will have to check to see if my local shop has those size carbon fiber rods in stock
Old Dec 17, 2011, 11:26 PM
Artie in Aus is offline
Find More Posts by Artie in Aus
Australia, NSW, Batemans Bay
Joined Feb 2011
Landing skids off heli's 700 for the Tri and 500 for the quad....so far seem indestructible...... but i'll keep tryin'
In both cases a nice bolt on no engineering fit....
Artie in Aus is offline Find More Posts by Artie in Aus
Old Dec 17, 2011, 11:43 PM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
Originally Posted by reverendrichie View Post
Here is a picture of my copters with landing gear. What I like about them is, they will take a licking and keep right on ticking. Great protection for the payload.
bad pic link
sirbow2 is offline Find More Posts by sirbow2
Old Dec 18, 2011, 12:02 AM
drcigg is offline
drcigg's Avatar
Joined Sep 2011
[QUOTE=Artie in Aus;20167494]Landing skids off heli's 700 for the Tri and 500 for the quad....so far seem indestructible...... but i'll keep tryin'
I didn't realize the landing skids had that much clearance underneath for the battery. Good to know.
Discussion good news, landing gears and main gears(compatible to Align450 XL) for try-out ELERC Mini Helis 32 Jan 29, 2007 09:53 AM
Sold 2 used pre-assembled E-sky CP2 Super Landing Gears (skids) in Black uabass Aircraft - Electric - Helis (FS/W) 1 Mar 13, 2006 02:27 PM
Logo Landing Skids Steph280 Electric Heli Talk 12 Mar 06, 2002 12:17 AM
Wanted - /30-sized heli landing skids... gstew Electric Heli Talk 3 Dec 29, 2001 05:08 AM
