Old Apr 16, 2011, 07:52 AM
hamburger is offline
Find More Posts by hamburger
Hamburger
hamburger's Avatar
Joined Jan 2010
Show us your Landing gears and skids setups..
Hi,
following the collection of TRI yaw setups I wanted to compile a list of multi copter landing gears and skids and other solutions.
So far, a wide collection does exist scattered around different threads in the form of photos.
If you are interested or are tired of your intial foam cussions, let us compile a selection of ideas. If possible, add description of copter including size and weight and photos plus designs.
Hamburger
hamburger is offline Find More Posts by hamburger
Old Apr 16, 2011, 07:58 AM
Hamburger
hamburger's Avatar
Joined Jan 2010
TRI - 22 cm M2M with funcopter landing gear
My smallest TRI is 22 cm motor 2 motor, weight is 260 gramm without battery.
For landing gear I use a complete funcopter assembly. It has a wide base of 16cm between skids and the landing strus are quite flexible.
Here's some photos.
Hamburger
Old Apr 16, 2011, 09:10 AM
capt is offline
Find More Posts by capt
capt's Avatar
Nevada, USA
Joined Sep 2007
Good idea here.
My favorite and used by many others.
http://www.hobbyking.com/hobbyking/s...idProduct=9535
capt is offline Find More Posts by capt
Old Apr 16, 2011, 09:41 AM
arch001 is offline
Find More Posts by arch001
Stockholm, Sweden
arch001's Avatar
Joined Oct 2010
I use these on my 1.5 Kg Y6-copter: Reinforced Plastic Undercarriage (Pair)
They are dirt cheap, about 15 cm high, and are very durable.
Description:
I would prefer even more height since I have mounted the gopro below the chassi so I'm considering these: MK FlexLander XL
Description:
At 44,95 they are a bit pricy though so I might not get them.
arch001 is offline Find More Posts by arch001
Old Apr 16, 2011, 10:19 AM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Here is a picture of my copters with landing gear. What I like about them is, they will take a licking and keep right on ticking. Great protection for the payload.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Apr 16, 2011, 10:20 AM
leadfeather is offline
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
cheap, ugly and functional
Pool noodle slices taped to the arm. Very light and cheap. They provide great protection for the copter and are very durable, practically indestructible.
leadfeather is offline Find More Posts by leadfeather
Old Apr 16, 2011, 12:34 PM
Hamburger
hamburger's Avatar
Joined Jan 2010
TRI - 50 cm M2M - tt balls on cf rods with rubber dampeners
on my TRI 60 with 50cm front motor 2 motor and a little longer tail I use tt balls glued to cf tubes (4mm). These are removable and glide into larger cf tubes (6mm in 8mm) which are again glued to large cf plates. These plates are helt in place with two sided self adhesive dampening material and your cable binders.
The rods can move freely in the large tubes. Movement is dampened with rubber rings form prop savers. This has proved itself quite effective - after some not so gentle earth contact the rubber bands have been pushed down some on the rods, thus have absorbed some of the excessive energy.
So far this is the best I have got working for a copter this size. Next step may be to glue LEDs to the inside of the tt balls for orientation and effect.
Hamburger
Old Apr 16, 2011, 12:47 PM
GorillaBob is offline
Find More Posts by GorillaBob
Re-Kitting Expert :o
Bullhead City, Arizona
Joined Jan 2005
My Tri Gear
My first pair for my Tri:
GorillaBob is offline Find More Posts by GorillaBob
Old Apr 16, 2011, 03:01 PM
Viktor50 is offline
Find More Posts by Viktor50
Viktor50's Avatar
Russia
Joined May 2010
Quad Flyer (0 min 31 sec)
Viktor50 is offline Find More Posts by Viktor50
Old Apr 16, 2011, 04:20 PM
quadslo is offline
Find More Posts by quadslo
Slovenia
Joined Feb 2011
I use this type
quadslo is offline Find More Posts by quadslo
Old Apr 17, 2011, 02:35 AM
Hamburger
hamburger's Avatar
Joined Jan 2010
Originally Posted by quadslo View Post
I use this type
quadslo,
I always wondered how does this gear behave in heavy ground (like high grass in parks)? Does it get stuck if you touch ground with a little too high speed? How does it behave if you still have some sideways velocity upon landing?
thanks, Hamburger
Old Apr 19, 2011, 02:49 PM
carl1864 is offline
Find More Posts by carl1864
Joined Jan 2010
Great idea for a thread, just like your Yaw control thread. Its good to have specific ideas and choices all in one place, rather than scattered all over.
I think a thread for tricopter camera mounts, and jello dampening systems would be a great one as well. I could definitely use a little help in that department currently.
Anyways, here is my quick, simple, cheap landing gear. Its just some sheet aluminum, cut with tin snips into 1/2" strips, and bent into shape with some sheet metal pliers (and careful measuring to make them all identical). They are taped in place very tightly with some strong strapping tape.
They feel very solid to me, the tape holds them stronger than you would think with no slop, and they seem capable of witstanding rough landings. I'm sure a all out crash would bend them, but they could easily be replaced cheap, or bent back.
carl1864 is offline Find More Posts by carl1864
Old Apr 19, 2011, 03:57 PM
Hamburger
hamburger's Avatar
Joined Jan 2010
I did not start the yaw thread, thread starter was RCG user 'tram'. I concur, I found it quite helpful also. That triggered the idea for this thread. glad you like it. Just go ahead and start other specific threads, sounds good to me.
Hamburger
Old Apr 19, 2011, 04:04 PM
iacei is offline
Find More Posts by iacei
Luxembourg
Joined May 2009
My contribution.
Cheaper? ....U won t find :O)
Durable? Hell Yeah.
Just buy the biggest Zip ties you can.
7 USD for 20
iacei is offline Find More Posts by iacei
Old May 13, 2011, 03:42 AM
jhsa is online now
Find More Posts by jhsa
Flying a Chipmunk in Portugal
jhsa's Avatar
NRW, Germany
Joined Sep 2010
I've been working on this one..
Before with fixed landing gear (Picture), and on the video with retractable landing gear. It is just an experiment. I don't know how it will behave on not so soft landings but I've tried to put the load on the copter arms as much as I could and not on the servo. Moving sideways could be a problem though.We will see. I will put some protections on the first few flights. I think it will be lighter than the former setup.
Joo
Tricopter Landing Gear Test (0 min 37 sec)
jhsa is online now Find More Posts by jhsa
Discussion good news, landing gears and main gears(compatible to Align450 XL) for try-out ELERC Mini Helis 32 Jan 29, 2007 09:53 AM
Sold 2 used pre-assembled E-sky CP2 Super Landing Gears (skids) in Black uabass Aircraft - Electric - Helis (FS/W) 1 Mar 13, 2006 02:27 PM
Logo Landing Skids Steph280 Electric Heli Talk 12 Mar 06, 2002 12:17 AM
Wanted - /30-sized heli landing skids... gstew Electric Heli Talk 3 Dec 29, 2001 05:08 AM
