Old Apr 15, 2011, 04:16 AM
e_lm_70 is online now
Find More Posts by e_lm_70
Austria
Joined Jan 2004
HobbyKing Dolphin Micro Sport Glider EPO, 555mm (PNF)
Anybody got this already ?
It was looking interesting to me ... and I had to add in my order
I'm wandering how much windy weather it can handle and if it really glide ... looking for use in my "little garden" throwing out of the balcony ...
I will try with my 850 2S and 600 2S battery that I have at home ... in case I will order the 4$ 500 2S
Danke
e_lm_70
EDIT: My videos:
HobbyKing Dolphin Micro Sport Glider EPO, 555mm (PNF) - With 2S 360mAh 20C (3 min 20 sec)
HobbyKing Dolphin Micro Sport Glider EPO, 555mm (PNF) - With 2S 610mAh 20C (4 min 21 sec)
e_lm_70 is online now Find More Posts by e_lm_70
Old Apr 15, 2011, 04:52 AM
Austria
Joined Jan 2004
Here are a couple of battery that should fit easily in this bird, and the related discount code:
360mAh 2S 20C
http://www.hobbyking.com/buddy.asp?c...1-E8F217390628
With code only 2.37$ instead of 4.29$
610mAg 2S 20C
http://www.hobbyking.com/buddy.asp?c...D-86BDFD4A45D9
With code 3.65$ instead of 3.92$
Tchuss
e_lm_70
Old Apr 15, 2011, 04:44 PM
Schermvlieger is offline
Find More Posts by Schermvlieger
I love HAM
Joined Nov 2005
Looks like a smaller sized Easystar I wonder what necessitates the high downward angle of the prop?
[edit]
Hmm I am not so enthusiastic about the glue-on wings; would be nicer to be able to assemble them on the field for easier transportation to the park
[/edit]
Schermvlieger is offline Find More Posts by Schermvlieger
Old Apr 16, 2011, 11:24 PM
Cheetah401 is offline
Find More Posts by Cheetah401
Playtoy
Cheetah401's Avatar
Mtl, Canada
Joined Aug 2007
This might help ...
4Ch Micro Glider out of box (2 min 5 sec)
Micro 4Ch Glider Flight in 16MPH winds (2 min 23 sec)
4Ch Micro Glider Maiden Flight (3 min 9 sec)
Cheetah401 is offline Find More Posts by Cheetah401
Old Apr 17, 2011, 12:48 AM
Austria
Joined Jan 2004
Thanks Cheetah
Yes, the one in the videos is looking the old dolphin
the new one hqs mainly a different motor mount with an extreme inclination
if they change, i hope they change for improve
Anyhow is looking an interesting bird
Tchuss
e_lm_70
Old Apr 17, 2011, 12:55 AM
slyfoxflyer66 is offline
Find More Posts by slyfoxflyer66
You torquing to me?
slyfoxflyer66's Avatar
Vancouver, WA
Joined Mar 2010
I like how its called the dolphin and it has a picture of a whale on the tail.
slyfoxflyer66 is offline Find More Posts by slyfoxflyer66
Old Apr 17, 2011, 01:57 PM
specriv is offline
Find More Posts by specriv
United States, CA, Walnut Creek
Joined Mar 2005
http://www.rcgroups.com/forums/showthread.php?t=1355845
specriv is offline Find More Posts by specriv
Old Apr 18, 2011, 02:22 AM
Austria
Joined Jan 2004
Originally Posted by specriv View Post
The old model was looking very good ... wondering why they did change.
The motor mount now, is set up for a nose heavy CoG. And as well it will make it slower
The elevator is reduced in size (so that may make more difficult to make loops)
So, it is looking it has been trim for beginner
Anyhow ... soon I will get the v2 in my hands ... and I will see directly how this little bird can fly
Tchuss
e_lm_70
Old May 03, 2011, 08:03 AM
Austria
Joined Jan 2004
Got my Dolphin yesterday.
2 days ago here was +24 nice and sunny .. yesterday +15 ... today is snowing
Anyhow, I did put it together.
I think the tricky part is to select the right horn hole for the elevator, rudder and ailerons : my suggestion is lowest hole for elevator and rudder and most far hole for ailerons.
I did not put the landing gears ... they look useless to me. Planing to go for hand launch and landing in the grass.
I did also not glue the wings, they look very tight connected also without glue ... in case I can use a magnet ... I just glued the tail and the horns with the included glue ... that is looking doing his job ... but it needs 3/4 hours for dry ... not a fast CA foam glue. The advantage of not glue wings, is that in case of bad landing or crash, without the glue the eventual wing pop-out will help to mitigate the crash.
With my "heavy" battery 880mAh 2S ... RTF is 175g ... not really ultra light.
I test glide on the bedroom .. with landing on the bed ... and I found it apparently nose heavy (with motor off) ... actually general heavy ... my mini Bee, and my Fox Bat, can land in the bad from a hand launch simulation more soft ... anyhow ... the motor is with a 5x3 propeller is pushing really hard ... it has more then 1:1 thrust ration. So even if is nose heavy ... it should fly ok due to the motor location.
I did test the motor and is pulling 6amp ... so over 40watt power for 175g should be more then enough ... I did not check the RPM ... but for my HK anemometer it push 130km/h of wind behind ... so looking able to handle strong wing easily ...
I may order a 500/600 2S 30C lipo ... if I can found a good deal ... but first I want to see if I can fly with my old on.
Tchuss
e_lm_70
Old May 03, 2011, 10:56 AM
Austria
Joined Jan 2004
It did stop to snow here ... so I had to maiden this little bird and try.
So ... it fly nice and easy ... almost no need of any trim ... out of the flat set up.
In my configuration is a little pig ... not sure if with 500mAh is much better then with my heavy 880mAh ... it does need some speed for climbing ... and the elevator even in the most responsive position, is not as strong as I would wish.
Ailerons control are just fine ... I never use the rudder (I'm not used to it )
I would have expect a easy hand launch, but actually I almost crash it down on my 1st fly (I did on my second, but nothing happen ) ... on the 3rd fly I gave a better push , but still is the challenging point.
Landing also need some speed ... so without the landing gear, it must be controlled carefully .. better to be used on a little windy day (30/40km/h max)
Under no power, if lose speed ... it sink like a pig ... afraid to a stall I did not try any aerobatic figure so far.
It can gain quite some speed, and it does not glide in gentle mode ... so it is not a relaxing bird to fly.
But I think I did overestimate the thrust ... I don't think it has 1:1 ... but .. I will need to check in later flys.
Originally was bought for be flown out of the balcony and with a land in my "small" garden ... my mini Wing can do it ... but landing is never so soft ... I will may try with a 500mAh battery and with a keycam on it ...
Tchuss
e_lm_70
ps: All in all ... it is a decent bird ... cost ~65$ shipped ... maybe not for beginners ... but a little bird that can be kept in the car .. or used for advance the 4ch flying skills ... anyhow ... I think HK has better birds in this price segment then this one ... so ... I don't expect much popularity.
pps: Since I place an heavy battery on my Dolphin, the huge motor inclination did definitely help ... but ... it make the bird responding quite different then the birds that I was used so far .... biggest minus ... is the limited elevator ... I don't know why they made it smaller compared to the previous version
ppps: I did use my cheap 2.4G 4CH TX (a clone of the 23$ set also available in HK) ... ok ... it is ok for fly ... but ... really it is a different world compared to my FX-18 ... but I did not want to have a long RX wire hanging in this little bird ... anyhow ... maybe ... I will may have to use my FX-18 TX if I want to control it better
Old May 05, 2011, 02:38 AM
tymodel is offline
Find More Posts by tymodel
Jack Xie
tymodel's Avatar
China
Joined Nov 2009
try this 500mah battery..
tymodel is offline Find More Posts by tymodel
Old May 05, 2011, 03:02 AM
Austria
Joined Jan 2004
Which ?
Anyhow ... it does fly good also with 880 .. it is just a bit ugly since it is not possible to close the canopy ... in theory the foam could be cut ... but ...
Anyhow ... I did order already a 610mAh ... ...
If you click on this: http://www.hobbyking.com/buddy.asp?c...D-86BDFD4A45D9
There is also a little discount
Tchuss
e_lm_70
Old May 05, 2011, 05:54 AM
Austria
Joined Jan 2004
[edit]
[/edit]
I did not glue the wings of my dolphin.
But, it is not really suggest to assemble them on the field ... since you will need to reconnect the ailerons links that is a big pain
Actually it is so small that take no space also fully assembled.
I did not glue the wings, since it is not looking needed ... and it is not needed I can say.
Just it must be remember at every landing that the winds may have been moved a bit ... and need to be properly fitted, else the aileron links will gave a wrong trim
Tchuss
e_lm_70
ps: Probably this glider is better: http://www.hobbyking.com/hobbyking/s...dProduct=11306, cost only 2$ more ... it may glide ...since the dolphin is not really gliding ... but the Dolphin advantages are: Exposed outrun motor, always cooled by the air, and impossible to damage on bad landing or crash.
Still I think that lighter servo could have been used, and as well rudder servo is totally useless. More light would have make a better glider ... as well .. I think some extra CM in wing span would have not arm as well ...
Old May 05, 2011, 02:20 PM
Austria
Joined Jan 2004
I did made 2 more flight with my Dolphins ...
First I did try in the garden ... took off easy (I learn how to launch this bird) ... but ... my old LiPo since ages, after 1 minute of WOT was getting week ... I start to glide, reduce power ... lost altitude ... made a mistake due to poor view (my bird was behind a tree) ... so I ended it in quite heavy nose crash on the ground ... but ... good surprise .. the nose got bit twisted ... but it did not even break
SO, I made a little walk, and took the bird in an open space ... and I did enjoy some other 5 minutes of flight ... It can roll it ... but still I did not manage any loop ... anyhow ... maybe with a lighter battery.
I also discover why it is always looking a bit out of trim ... if trimmed for WOT is not ok in the glide ... and ... I discover that the motor mount has a bit inclination (not the vertical one that is by design) but it is not fully center ... it push a bit on the right ... it is looking there motor holder has missing some glue ... so I need to fix it.
I did start to play with rudder ... and is looking responsive also with the most far hole ... so I will keep as it it ... I think the main idea of this 4ch little bird is for experiment and improve the 4ch skills ... I'm good on navigate with only elevator and aileron ... but be able to mix ailerons and rudder ... it may bring to the next level of skills
Tchuss
e_lm_70
ps: All in all, I don't regret to have got this (it was sort of order filler for my Fox) ... it is a decent 4ch, enough fast for handle normal day moderate wind ... but mainly it is very durable.
pps: Possibly the only change that I will do is to make the elevator bigger, like it was in the original Dolphin ... as well ... when I will get a new 610mAh battery for replace my old 880 ... I think it should also improve quite a bit
Old May 06, 2011, 12:17 AM
tymodel is offline
Jack Xie
tymodel's Avatar
China
Joined Nov 2009
Originally Posted by e_lm_70 View Post
Which ?
Tchuss
e_lm_70
Oh, i forgot to post the link. This Battery:
http://www.easy-sky.net/productE.asp...&pros2=Battery
Discussion HobbyKing Fox EPO Glider 2.32M DougKierc Electric Sailplanes 2268 Jun 28, 2016 01:10 PM
New Product HobbyKing Minimoa 2mtr R/C Glider EPO w/ Motor, ESC, Servos Plug-n-Fly Bowerz Electric Sailplanes 8 Jul 29, 2015 09:28 AM
New Product Hobby King 2.3M EPO EP Ventus PNF Doubletap Electric Sailplanes 1 Apr 05, 2011 10:00 PM
For Sale Sky Rider EPO 2M FPV Glider Kit kevinlib Aircraft - Electric - Airplanes (FS/W) 2 Mar 08, 2011 03:57 PM
Discussion Hobbyking Fox EPO Glider silesia Electric Sailplanes 2 Nov 05, 2010 06:51 PM
