Old Apr 14, 2011, 12:11 PM
snivilous is offline
Find More Posts by snivilous
High Altitude Specialist
snivilous's Avatar
Joined Jan 2010
UMX Sbach 342 BNF by E-Flite
http://www.horizonhobby.com/Products...#quickOverview
Looks sweet
UMX Sbach 342 BNF
Key Features
* Includes two sets of optional Side Force Generators
* Magnetic cowl hatch for easy access to the motor and battery compartment
* Equipped with a 180BL, 2500Kv brushless outrunner motor
* Includes Spektrum AR6400NBL DSM2 receiver/ESC unit and four AS2000L long-throw servos
* 2S 180mAh Li-Po battery and DC charger included
* Features an authentic paint scheme
* Tailwheel steering
Overview
The Sbach 342 is one of the most exciting full-scale aerobatic designs to come out of Germany since the first Extra. The brainchild of aerodynamic visionary, Horst Streicher, it's the first two-seat monoplane capable of truly holding its own in Unlimited-class competition. E-flite has captured the essence of the 342s incredible performance with this remarkably scale ultra micro that flies extreme aerobatics with the same sense of power and precision you would expect of a larger model.
Designed by world-class competitor Mike McConville, the E-flite UMX Sbach 342 BNF comes out of the box completely assembled and ready to be bound to any DSM2 or DSMX transmitter.
Needed to Complete
A 4+ channel DSM2/DSMX compatible transmitter that is capable of programming Dual Rates and Exponential
Specs
Wingspan: 17.0 in (432mm)
Overall Length: 16.6 in (422mm)
Wing Area: 65 sq in (4.2 sq dm)
Flying Weight: 1.95 oz (55g)
Motor Size: 180-size 2500Kv brushless outrunner
Radio: 4-channel with expo and dual rates
Servos: Four (4) S2000L long-throw servos (installed)
Trim Scheme Colors: Red, white, and black
Wing Loading: 4.2 oz/sq ft
Prop Size: 5 x 2.75
Recommended Battery: 2S 7.4V 180mAh Li-Po (included)
Flaps: No
Retracts: No
Approx. Flying Duration: 6 minutes
Charger: DC powered 2S LiPo charger (included)
Steering: Yes
Minimum Age Recommendation: 14 years
Experience Level: Intermediate
Recommended Environment: Outdoor
Assembly Time: Less than 1 Hour
Is Assembly Required: No
snivilous is offline Find More Posts by snivilous
Old Apr 14, 2011, 12:46 PM
Bob J is offline
Find More Posts by Bob J
Fond du Lac, WI
Joined Mar 2005
The Horizon web site says late June arrival.
Bob J is offline Find More Posts by Bob J
Old Apr 14, 2011, 08:54 PM
mmcconville is offline
Find More Posts by mmcconville
Horizon Employee
Joined Jan 2006
June arrival is correct. Were flying it here (at SEFF) right now.
mmcconville is offline Find More Posts by mmcconville
Old Apr 14, 2011, 09:12 PM
Bigugly is offline
Find More Posts by Bigugly
Mesquite Tx
Freaking sweet.
Bigugly is offline Find More Posts by Bigugly
Old Apr 14, 2011, 09:56 PM
Derek242 is offline
Find More Posts by Derek242
Derek242's Avatar
vancouver washington
Joined Apr 2010
how 3d capable is it?
Derek242 is offline Find More Posts by Derek242
Old Apr 14, 2011, 10:16 PM
Horizon Employee
Joined Jan 2006
Its not a 3D airplane. Hought power is very big, and with SFGs on it, strong KE is possible.....KE square loops, high alpha KE etc.
Old Apr 14, 2011, 10:17 PM
Horizon Employee
Joined Jan 2006
Also note, on the spec list, 55g is weight without battery not flying weight. I'm working to get it corrected.
Old Apr 14, 2011, 10:53 PM
KE Spin is offline
Find More Posts by KE Spin
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Saw flight video, looks interesting.
KE Spin is offline Find More Posts by KE Spin
Old Apr 15, 2011, 08:40 AM
tclaridge is offline
Find More Posts by tclaridge
United States, VA, Clifton
Joined Nov 2005
There are three other threads on this plane started. I recommend closing this redundant thread.
tclaridge is offline Find More Posts by tclaridge
Old Apr 15, 2011, 09:51 AM
aglenn is offline
Find More Posts by aglenn
aglenn's Avatar
Joined Aug 2004
After having seen this airplane fly on numerous occasions. The airplane is meant for IMAC style manuvers just like the UMX Beast was meant for. The airplane is very capable of high alpha knife edge.
Originally Posted by KE Spin View Post
Aw, c'mon Mike. How could you create something like that and NOT make it 3d??? So, what is meant in the overview where it is described as being capable of extreme aerobatics? My understanding is that 3d is technically described as post stall aerobatics....is the Sbach capable of post stall aerobatics?
Mike, I just checked (calculated) the wing loading based on the information listed in the specs I come up with 4.32 and looks like it doesn't include the battery weight either.
Published spec errors are a pet peave of mine. To me it can be something of a deal breaker to see errors like this as it makes me wonder what else might be incorrect or misleading.
On the other hand, the Sbach does look very interesting.
aglenn is offline Find More Posts by aglenn
Old Apr 15, 2011, 01:15 PM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Aglenn,
Thanks for providing that information. Is there a video somewhere?
Couldn't find the weight of the stock battery but have estimated it at around 11 grams (0.39 oz). Adding the battery weight to the listed weight of the airplane gives a AUW of 2.3oz and a resulting wing loading of approximately 5.2oz / sqft. For IMAC style flying this should about nail it.
For those thinking of mods and 3d flying an increase in wing area of around 25% would bring the wing loading back down to around 4oz/sqft. The lighter loading is better for 3d performance and will allow the plane to fly a little slower in an indoor venue but still be ok outdoors in light winds. I'm sure there is a brushless motor capable of hovering the 342....yeah baby...now we're talkin' :-)
Old Apr 15, 2011, 02:58 PM
creapyd is offline
Find More Posts by creapyd
Prefectionist
Joined Mar 2007
Soo, where's the 40" parkflyer version ;-)
creapyd is offline Find More Posts by creapyd
Old Apr 15, 2011, 03:54 PM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
There's a bunch of Sbach's out there (in all sizes and materials).
I'm thinking of the indoor season for this one at the end of the year....maybe the price will come down by then :-)
Old Apr 15, 2011, 05:02 PM
creapyd is offline
Prefectionist
Joined Mar 2007
But none made by Parkzone / E-flite. All the foam ones are profile or square bodied, and the wood ones are not parkflyers.
Old Apr 15, 2011, 05:12 PM
snivilous's Avatar
Joined Jan 2010
Yea, I'm not a fan of profile planes either. If this can (or be modded to) fly 3D indoors it'd be perfect for me.
New Product New E-flite UMX Sbach 342 LunaRendezvous Micro Ready-to-Fly 5686 Apr 23, 2016 11:08 PM
Sold E-Flite UMX Micro beast NIB (BNF model)+ 3 extra batteries $150 shipped. RCGill Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Apr 04, 2011 11:31 AM
Sold E-Flite UMX Micro beast NIB (BNF model) + 3 extra batteries $150 shipped RCGill Aircraft - Electric - Airplanes (FS/W) 3 Apr 04, 2011 11:30 AM
Sold E-flite UMX Beast BNF tdriedger Aircraft - Electric - Airplanes (FS/W) 2 Mar 29, 2011 02:23 PM
Sold UMX Extra 300 3D BNF by E-flite DuaneV Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Feb 19, 2011 10:28 AM
