Old Apr 19, 2011, 12:04 AM
Razors edge 29 is online now
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
True
A guy in my club has the beast and it's a great plane BUT the prop system/hub sucks as on his anyways (if I remember correctly) he can only use stock props
How do you guys get around that?
Originally Posted by turboparker View Post
RE,
Same prop as the Beast. Which means a 5030 will be a close match, and a 5043 will turn it into a rocket.
Joel
Razors edge 29 is online now Find More Posts by Razors edge 29
Old Apr 19, 2011, 12:15 AM
RemE is offline
Find More Posts by RemE
Tweaker
RemE's Avatar
Corona Del Mar
Joined Sep 2005
The stock motor hub system is actually excellent for GWS props, it's a straight swap out.
RE, good price on the MM 13/6/9T Competition Special motor, no joy there. I got mine from Bob Selman Designs. You can only special order, and they are $91 a pop, plus shipping, such a deal. Plus it takes weeks for delivery.
But I can't wait to see 190g of thrust in action
RemE is offline Find More Posts by RemE
Old Apr 19, 2011, 12:34 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
90 a pop?
Wow pricy for sure lol
It's a direct swap?
His has some weird prop adapted that only uses Parkzone props, or am I way off base?
I thought that I remembered it having no exposed motor shaft but the tip of that shaft was inside the bell which is where the prop adapter was attached to.
Maybe i was drunk that day lol
I tried a new 2-3 S small bL motor today that is 3000 KV; larger than AP05 and it was disappointing to say the least.
Website claims it can handle 3S with 7.4 prop; well it can barely handle 6.3.prop on 2S
Plus the prop adapter sucks and is too lose on GWS props 6.3 and the like.
Dissapointing
Old Apr 19, 2011, 12:48 AM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
RE,
It's a direct swap. The Beast's stock prop has a 4mm center hole, just like the GWS props. The 5030 is a perfect fit. Due to the 5043's thicker hub, you have to shave a bit off the inside of the spinner to get a good fit. That's it. I have two Beasts - one optimized for short-field flying, and the other optimized for unlimited aerobatics. The short-field ship has a 5030, and the unlimited ship has the 5043. Of course, even the short-field ship would be considered unlimited - just not as spectacularly unlimited as the one with the 5043.
Joel
turboparker is offline Find More Posts by turboparker
Old Apr 19, 2011, 02:07 AM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
Babbley do ya reckon it will do rolling harriers and hover ?
Kris... is offline Find More Posts by Kris...
Old Apr 19, 2011, 05:52 AM
minirips2 is offline
Find More Posts by minirips2
Chicago Northwest subs
Joined Jan 2007
Originally Posted by RCBABBEL View Post
OK mini,
Looking over your King of the Beasts thread:
http://www.rcgroups.com/forums/showp...8&postcount=37
and the Mighty Midget specs:
http://www.microbrushless.com/productsG3f3p.htm
This looks like sweet, simple, drop-in, insane, KICS type stuff.
The kind of stuff that unlimited 1000' loops are made of.
3-1 power to weight stuff.
Looks like the motor fit was simple in the Beast mount.
Any problems that come to mind with this set-up besides being power hungry??
rc
Short flight times and need for throttle management are the only drawbacks. Personally, I prefer short flights, within reason. The only thing that keeps the MM motor from being plug 'n' play is the need to solder a compatable three pin connector on the motor leads. Weight is slightly increased, but not by much.
MR2
minirips2 is offline Find More Posts by minirips2
Old Apr 19, 2011, 06:00 AM
Joined Jan 2007
Originally Posted by Razors edge 29 View Post
90 a pop?
Yes, it's pricey. If you wanted to drop a Roush crate motor in your 'Stang, you'd be paying a pretty penny for the privilege. You would be grinning from ear to ear until you ran out of rubber or gas, however. Same thing here. The Mighty Midget motors are very powerful and extremely efficient at the same time. The workmanship and engineering are exquisite.
MR2
Old Apr 19, 2011, 07:54 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
I am getting the sense that theyre indeed great motors.
Old Apr 19, 2011, 09:10 AM
natss is offline
Find More Posts by natss
Registered American Veteran
natss's Avatar
Tulsa, Oklahoma
Joined Aug 2010
Any pics of the new board? Once again, this will change EVERYTHING we know about micro planes. HH does listen to us and now has the footprint to make many kick ass planes !!!!
natss is offline Find More Posts by natss
Old Apr 19, 2011, 10:21 AM
MikeRx is online now
Find More Posts by MikeRx
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
3 cells?
Ok, she can take the amps, but how about VOLTS??
I have a 120mah 3s pack and some 4.5x3" props...
So now that the servos are removed, the "brick" will be $20-30 less??
Wishful thinking, but Id like to hear about the limitations of the esc/bec concerning 3 cells.
MikeRx is online now Find More Posts by MikeRx
Old Apr 19, 2011, 04:36 PM
RemE is offline
Tweaker
RemE's Avatar
Corona Del Mar
Joined Sep 2005
Still on the lookout for the new receiver manual.
For Wholesale Trains Buyers Club Members, the Sbach is now up for preorder... $144 and I'm now on the list for mid June.
Sadly, in dog years, this will be a long 14 months!
Old Apr 19, 2011, 06:15 PM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
You did remember to add a couple of things to the order for the over $150.00 free shipping right?? I just about forgot but was able to go back and add a spinner and battery cover..
livonia bob is offline Find More Posts by livonia bob
Old Apr 19, 2011, 06:24 PM
RemE is offline
Tweaker
RemE's Avatar
Corona Del Mar
Joined Sep 2005
Yup, I added a spare long throw servo
Old Apr 19, 2011, 07:10 PM
RCBABBEL is online now
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Appreciate the reminder.
Two pre-orders in.
Let the races begin!
S
M
E
D
A
Y
rc
RCBABBEL is online now Find More Posts by RCBABBEL
Old Apr 19, 2011, 07:17 PM
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Probably not for anyone that uses a Tx tent!!!
rc
Discussion NEW!!! E-Flite UMX Extra 300 3D BNF!!!!! DFflyer 3D Foamies 748 Mar 01, 2013 08:12 AM
Discussion Sbach 342 Full fuse Free Plans bbjsw10 Foamies (Scratchbuilt) 142 Apr 07, 2012 03:48 PM
Yippee! e-foamy sbach 342 maiden larsy87 3D Foamies 26 Nov 01, 2010 11:25 PM
