Old Jun 20, 2011, 05:50 AM
Abib is offline
Find More Posts by Abib
Abib's Avatar
United States, MI, Dearborn
Joined Feb 2009
For the records: HobbyKing MX2 came with 70A ESC..
Abib is offline Find More Posts by Abib
Old Jun 21, 2011, 05:25 AM
Abib is offline
Abib's Avatar
Joined Feb 2009
Now on Sale in US..
http://www.hobbyking.com/hobbyking/s...dProduct=18596
Old Jun 21, 2011, 06:30 AM
TooSLow2Care is offline
Find More Posts by TooSLow2Care
insert witty phrase here
Joined Aug 2006
can someone provide a more detailed image of the tail gear and linkage? the image in the manual is too small for my eyes & my kit didn't arrive with any springs.
thank you,
Brian
TooSLow2Care is offline Find More Posts by TooSLow2Care
Old Jun 21, 2011, 08:42 AM
rmgmag is offline
Find More Posts by rmgmag
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
I just pulled the trigger on this one. For $158 shipped, how bad can it be?
rmgmag is offline Find More Posts by rmgmag
Old Jun 21, 2011, 11:01 AM
Abib is offline
Abib's Avatar
Joined Feb 2009
thank you,
Brian
I will try tonight..
There's no springs but wires, and in my case, i had to bend it..
Old Jun 21, 2011, 11:06 AM
bigwood212 is offline
Find More Posts by bigwood212
United States, AZ, Tucson
Joined Nov 2007
wow $158 shipped it could just be an empty airframe for all I care. I was waiting for it to hit usa warehouse im ordering now.
bigwood212 is offline Find More Posts by bigwood212
Old Jun 21, 2011, 11:10 AM
Joined Nov 2007
what size lipo are you going to use. One color says 3300mah the other 2200mah
Old Jun 21, 2011, 11:27 AM
rmgmag is offline
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
I've got a couple of 2650 mah 40C's that I'm using in my E-flite Carbon-Z, so I'll start with those. I also have a 3000mah 40C that I may try also.
Bob
Old Jun 21, 2011, 01:04 PM
Joined Aug 2006
That would be great!! I have some pre-bent 'Z' wires that are 3-4mm too long & I can't figure how to attach the control horns to the rudder.
Thank you for posting a picture if you're going to have time tonight. It will probably solve all of my issues & confusion.
Cheers,
Brian
Old Jun 21, 2011, 02:23 PM
Spouny is offline
Find More Posts by Spouny
Spouny's Avatar
Joined Jul 2007
thank you,
Brian
OK, but mine have springs...
Spouny is offline Find More Posts by Spouny
Old Jun 21, 2011, 02:45 PM
Luke Warmwater is offline
Find More Posts by Luke Warmwater
Joined May 2011
Quick tip...when I lost my springs in my first crash, I replaced them with springs from a cheap ball point pen. They work great!
Luke Warmwater is offline Find More Posts by Luke Warmwater
Old Jun 21, 2011, 02:52 PM
Joined May 2011
I'm looking for a pointer on battery size etc.
I am currently using Turnigy 2200mAh 40C Lipos, that fit nicely into the front compartment. However, every higher capacity battery I have looked at is longer....too long to mange to get the angle to slide it into the compartment. So, you guys who are using the higher capacity batteries....what batteries are they and how do you fit them in?
The reason I am looking for higher capacity batteries, is that I have put in a Hacker 30 motor and a 14 x 7 APC electric prop. This pulled 55amps at WOT when held on the ground, so the stock 45amp ESC has been replaced with a Turnigy Plush 60amp (peaks at 80amp). The performance is great...hover at between 1/2 and 3/4 stick and bags of power to pull out. I did need to put some upthrust by adding washers to the motor mount, but that allowed me to take some (a lot of) trim off the elevator and she behaves much nicer on landings now!
But...with that draw on a 2200mAh battery, flight times are woefully short...hence why I would like to know where to put a larger battery!
Thanks in advance.
Old Jun 21, 2011, 06:11 PM
Spouny is offline
Spouny's Avatar
Joined Jul 2007
My lipos are Nano-tech 3300 4S :
Tools used to widen the lipo's place. It is necessary to remove approximately 1 mm on each side, on the length of the compartment, it is necessary to get the access from both sides, so you'll have to remove the motor and it's mounting plate. I have glued the ESC on the top of the compartment, and I have widened it in a way that the battery goes in by rubbing, thus it remains in position without fixation and without risk of moving in flight. Fast and easy.
Old Jun 21, 2011, 06:21 PM
Joined May 2011
Thanks for that.
My issue wasn't the width or height of the compartment, but the length of the battery. With it being longer, I couldn't get the right angle to slide the battery in....
Old Jun 21, 2011, 09:10 PM
Joined Nov 2007
StarMax 3D MX2 (5 min 1 sec)
STARMAX MX2 MAIDEN FLIGHT (5 min 24 sec)
StarMax MX2 (5 min 21 sec)
StarMax MX2 (4 min 35 sec)
Starmax mx2 maiden (3 min 40 sec)
http://www.rcgroups.com/forums/showt...1423281&page=9
Starmax mx2 (4 min 58 sec)
Discussion Anyone tried the BlitzRCWorks MX2 Pro 3D? HallaBalla Foamies (Kits) 2 Mar 26, 2012 08:16 AM
Discussion 4 CH BlitzRCWorks 2.4GHz Giant Air Zermatt EC-135 jblackwell Coaxial Helicopters 9 Sep 07, 2010 08:37 AM
Sold Texas Pickup: BlitzRCWorks GIANT F-117 RX ready w/light, bomb drop, retracts: $140 Roswalt Aircraft - Electric - Jets (FS/W) 4 Jun 13, 2010 04:59 AM
Question mx2 or multiplex acromaster and st model mx2: Unboxing vid? build vid? y info? jakerevs 3D Foamies 2 Mar 27, 2010 02:56 PM
Question MX2 von Hype and ST-model MX2? Thomas*rc Electric Plane Talk 4 Nov 17, 2009 02:42 AM
