USA, NY, Medford
Joined Nov 2007
Joined Sep 2010
So when you hit the throttle the plane goes down and when you cut the throttle the tail falls back... If I was you I would try to change the motor angle just a little bit pointing up. Let us know if you change anything. Good luck |
Joined May 2011
Yes, you are right, it needs more up thrust!
Its balanced about right; the reason it pops up isn't because it is tail heavy, it is because it is trimmed to counter the excessive down thrust a bit.....so when the power is off, the elevator trim pops her up. I'm fairly confident I know what needs doing. I'm waiting for some larger props and then I'll take her out and trim her for a gliding....and then adjust the thrust accordingly. |
Joined Sep 2010
...also videos are welcome
| Thread Tools | |
| Discussion Anyone tried the BlitzRCWorks MX2 Pro 3D? | HallaBalla | Foamies (Kits) | 2 | Mar 26, 2012 08:16 AM |
| Discussion 4 CH BlitzRCWorks 2.4GHz Giant Air Zermatt EC-135 | jblackwell | Coaxial Helicopters | 9 | Sep 07, 2010 08:37 AM |
| Sold Texas Pickup: BlitzRCWorks GIANT F-117 RX ready w/light, bomb drop, retracts: $140 | Roswalt | Aircraft - Electric - Jets (FS/W) | 4 | Jun 13, 2010 04:59 AM |
| Question mx2 or multiplex acromaster and st model mx2: Unboxing vid? build vid? y info? | jakerevs | 3D Foamies | 2 | Mar 27, 2010 02:56 PM |
| Question MX2 von Hype and ST-model MX2? | Thomas*rc | Electric Plane Talk | 4 | Nov 17, 2009 02:42 AM |
