Old Feb 06, 2012, 06:35 PM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
Originally Posted by dkrhardy View Post
Sammy .... the measurement is the number supplied by the builder/manufacturer. The only possible issue is to whether to do it right side up or inverted. Numbers are the same. Does that help?
Don
Cool, cheers I was running about 110mm right side up, it flew fine for what I noticed. When I get new motor (hopefully early next week) I'll have to calculate battery location to get correct CG again.
sammyc is offline Find More Posts by sammyc
Old Feb 07, 2012, 08:51 AM
Waterbird is offline
Find More Posts by Waterbird
Waterbird's Avatar
Annapolis, Maryland, USA
Joined Mar 2005
RE. BALANCING UPSIDE DOWN OR RIGHTSIDE UP:
I ALWAYS balance low wing monoplanes upside down. I have a COG balancing tool sold by Great Planes that specifies this: Balance high wing monoplanes rightside up; balance low wing monoplanes inverted.
What about those with sort of "mid-fuse wing" positions? Well, my 3D Hobby Shop Edge 54 looks like that, and it seems to balance about the same either inverted or right side up.
But for the MX, there's no question: inverted only.
Waterbird is offline Find More Posts by Waterbird
Old Feb 07, 2012, 03:44 PM
dkrhardy is offline
Find More Posts by dkrhardy
United States, FL, The Villages
Joined Oct 2010
Thanks! I have that same balancing "machine" and there was no way it was going to fit under the landing gear to check balance at the wing root. So, I'll do it inverted. I'd classify this MX2 as a mid wing, since the wings go into the fuselage rather than attach squarely to the bottom. But, The darned manuals were not specific. Thanks again.
Don
dkrhardy is offline Find More Posts by dkrhardy
Old Feb 07, 2012, 10:57 PM
dkrhardy is offline
Joined Oct 2010
OK folks .... I enlisted the talents of my DW (Darling Wife) to assist me with the ESC programming. The menu shows a SINGLE music note and then the tone sequence. It plays several notes. I could not get to a point where it played ONE stinking note. That is where my confusion occurred. As an air traffic controller for ALL of my life, right is right, wrong is wrong, white is white, etc, etc, etc. So when they show ONE note, I'm looking for one note ... no variable. She simply said "they mean music"! huh? Several notes? Why do they show one? Soooo, with her thinking, it was done. Dang, will I be this way the rest of my life? I've also figured out the DX8 ... they have the graph display for no stinking reason. You just enter the %'s for your DR and expo and that graph is there for OOH AHH effect. Means nothing! So, you pay for the thing that they think is impressive. That and 30 model capacity. OK, OK, you also get timers and warning stuff too.
I am having an issue with the springs on the tail wheel. I bought a 200 piece kit so I have springs coming out of my ..... and I have used soft ones and stiff (!) ones and none of them allow the wheel to turn with the rudder. This time I am well and truly stumped. Plane will fly soon, even if I have to go back to those tail rods.
Don
Old Feb 08, 2012, 01:45 AM
Ben D Wing is online now
Find More Posts by Ben D Wing
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Don, I bought a couple of really cheap retractable ball point pens, stripped 'em down and used the springs within. They had to shortened somewhat and have loops bent on either end, but that's no biggie and they work perfectly well.
Ben D Wing is online now Find More Posts by Ben D Wing
Old Feb 08, 2012, 08:14 AM
dkrhardy is offline
Joined Oct 2010
Ben,
Those are the same type I tried the 1st time and they didn't work. On my plane the one side of the spring just stretches when the rudder is turned and the wheel doesn't turn. This is with the tail in the air and there is no load on that wheel. Maybe I have them too strong and they won't let the thing turn. Gotta play with it I guess. Lord knows I have lots of springs to choose from!
Old Feb 08, 2012, 11:10 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
Hi guys, can someone please measure the dimensions of the canopy and the dimensions of the cowling for me.
Thanks!
msev is offline Find More Posts by msev
Old Feb 08, 2012, 06:28 PM
dkrhardy is offline
Joined Oct 2010
OK, with 200 springs to play with I think I've got the right ones on it. Tail wheel turns with the rudder, just not as much. I presume that when the plane is moving it will be better. Maiden tomorrow, if the wind permits! I have the low rate waaaay down, I think I used 50% and high is about 80%. Expo is 30% for both. My servos seem more than capable and center/re-center perfectly. No noise nor "flutter". Anyone know which plane on Real Flight 6 mimics the MX2?
msev - that is gonna be hard to do. They both have lots of curves and tapers. What are you trying to do?
Don
Old Feb 08, 2012, 08:19 PM
sammyc is offline
sammyc's Avatar
Joined Nov 2011
My new motor has arrived ill be putting it back together tonight after work
Old Feb 08, 2012, 09:31 PM
dkrhardy is offline
Joined Oct 2010
Sammy - I went back to the end of december and only found a mention of your motor problem. What happened and what did you get to replace it? Just in case mine goes bad!
Don
Old Feb 08, 2012, 10:57 PM
sammyc is offline
sammyc's Avatar
Joined Nov 2011
Don
Motor bell separated from inner coil during a throttle runup on ground (luckily), spat that with prop a good 30m
I did have the motor apart a few flights before, so I think a circlip failed. I wouldn't worry too much about yours. Ill take some pics of the damage (to motor only - phew) and upload them tonight, its a bit impressive. I got a NTM motor from HK, I think I have link shown on my post a while back? I can post link up later too just forgot the size numbers.
Old Feb 09, 2012, 05:32 AM
sammyc is offline
sammyc's Avatar
Joined Nov 2011
Here's what happened to stock motor. You can't see it in the photo, but the red end cap and black outer tube are now oval (ish)
I have my new motor in, a bit of modding the original motor bracket, but all good
Motor weights (old school inaccurate scales, should be close):
-stock (as is seen in photo below, all mounting hardware included) 225g
-NTM prop drive 42-48 and accessories 275g
I have installed D-MG16 servos for the elev and rudder, wow they are a lot faster than stock servos! The servo tray needed the cutouts very slightly extended, which ruins one of the screw holes, but I just drove one with a larger head in and its fine.
Very much looking forward to remaiden, saturday hopefully!
Old Feb 09, 2012, 07:02 AM
dkrhardy is offline
Joined Oct 2010
Thanks Sammy.
That is very impressive as damage goes! The new motor looks nice and with the mount set it is very affordable, good and good. You're lucky you got the servos, they are now on backorder. GL on Saturday. If the wind stays as light as the weather guessers say, AND if my mentor can go .... maiden today.
Don
Old Feb 09, 2012, 09:11 AM
doc993 is offline
Find More Posts by doc993
doc993's Avatar
United States, WI, Stoddard
Joined Dec 2009
Hi All I fly g5.5 and use the carbon z yak , the Gp extra 300,the cap electric 3d, If you can fly these you can fly about any thing.Then just for kicks try and fly the Bugatti r 100 ,and the pond racer.
doc993 is offline Find More Posts by doc993
Old Feb 09, 2012, 12:57 PM
Flyboy.123 is offline
Find More Posts by Flyboy.123
Kick tires & light fires
United States, OK, Oklahoma City
Joined Feb 2012
Horizontal Stabilizer
I personally love this plane, minus one thing. At hi speeds my horizontal stab. flutters violently. In fact it broke my tail wheel in mid flight last time i flew. Anyone else having this issue? I made a slit down the middle of the stab, inserted a reinforcing dowel in the slit and poked through the fuselage to the other side of the stab. I then epoxied that in and painted a thin layer of some epoxy on the underside of the stab to let it harden and hopefully stiffen the stab. up. The next time I flew at high speed, it fluttered, the tail wheel broke off and now i am at this point. One thing I learned is this foam is tough to with stand the force from these flutters!
One more thing, I am going to replace the stock servos with new ones. Any suggestions? I saw some suggestions on another page from hobby king but they are back ordered and I want to fly sooner.
Flyboy.123 is offline Find More Posts by Flyboy.123
Discussion Anyone tried the BlitzRCWorks MX2 Pro 3D? HallaBalla Foamies (Kits) 2 Mar 26, 2012 08:16 AM
Discussion 4 CH BlitzRCWorks 2.4GHz Giant Air Zermatt EC-135 jblackwell Coaxial Helicopters 9 Sep 07, 2010 08:37 AM
Sold Texas Pickup: BlitzRCWorks GIANT F-117 RX ready w/light, bomb drop, retracts: $140 Roswalt Aircraft - Electric - Jets (FS/W) 4 Jun 13, 2010 04:59 AM
Question mx2 or multiplex acromaster and st model mx2: Unboxing vid? build vid? y info? jakerevs 3D Foamies 2 Mar 27, 2010 02:56 PM
Question MX2 von Hype and ST-model MX2? Thomas*rc Electric Plane Talk 4 Nov 17, 2009 02:42 AM
