wingnutzster I've seen the one,a while ago for a nav rally down in Parys.had lank engines problems the day,so unfortunately didn't get to see a display
sorry guys don't meant o hijack the thread ![]() http://www.rcgroups.com/forums/attac...mentid=4806271 |
Australia
Joined Jun 2007
Hi Guys,
I have only flown my Green MX2 a few times and am really enjoying it.......except....I am using a 4S 50C 3000mA batt and it goes flat in less than 5 mins during flight. I am not even flying on WOT or anything special, just doing normal circuits to get used to the plane. I checked current draw on WOT and it's drawing 62 Amps. Stock set-up. Is this normal? Maybe I'll just have to get a bigger capacity battery? Cheers all Si |
On a comic side note, has anyone ever used this method before?
(Question) How do you know what motor to use? How I decided on that motor,I took the KV rating multiplied it by the number of Lipo cells, divided by milliamps then took the prop size cut one blade off,measured the diameter and got the square root of the length of the field I'm flying at,glued the blade back on and divided it by pie R squared,got that Number and took a dump on it then used a temperature probe on the feces and if it was over 98° I went with a lower KV motor....
| Thread Tools | |
| Discussion Anyone tried the BlitzRCWorks MX2 Pro 3D? | HallaBalla | Foamies (Kits) | 2 | Mar 26, 2012 08:16 AM |
| Discussion 4 CH BlitzRCWorks 2.4GHz Giant Air Zermatt EC-135 | jblackwell | Coaxial Helicopters | 9 | Sep 07, 2010 08:37 AM |
| Sold Texas Pickup: BlitzRCWorks GIANT F-117 RX ready w/light, bomb drop, retracts: $140 | Roswalt | Aircraft - Electric - Jets (FS/W) | 4 | Jun 13, 2010 04:59 AM |
| Question mx2 or multiplex acromaster and st model mx2: Unboxing vid? build vid? y info? | jakerevs | 3D Foamies | 2 | Mar 27, 2010 02:56 PM |
| Question MX2 von Hype and ST-model MX2? | Thomas*rc | Electric Plane Talk | 4 | Nov 17, 2009 02:42 AM |
