Old Jul 13, 2012, 11:43 PM
Hexperience is offline
Find More Posts by Hexperience
devIAtion..one TX to bind them
Hexperience's Avatar
Canada, ON, Georgina
Joined Aug 2011
Hello all,
Picked up the Breitling version today, on a bit of an impulse buy. Threw it together in an hour and headed off to the field...
I have to say, this being my first "3D" plane, it was great! I know there are problems, landing gear issues, and a couple of minor things.
But this was a lot of fun to fly.... anyway, just wanted to say hello, I'll be reading over the thread for some tips.
Cheers
Hexperience is offline Find More Posts by Hexperience
Old Jul 13, 2012, 11:50 PM
Kawi is offline
Find More Posts by Kawi
\_(ツ)_/
Joined Sep 2011
Yeah it is fun. I really miss mine, it was cool how fast it was and how it would track across the sky in fast forward. It's a fun plane for sure.
Kawi is offline Find More Posts by Kawi
Old Jul 17, 2012, 06:10 AM
Joined Aug 2011
This plane is very durable! Wish I didn't have to know that...
I've put about 6 flights on it now and abot 50% of those ended in a very hard landing, with a kind of flat cart wheel.
At first I was a bit disappointed in the motor mount, it bacame loose after the first hard landing. Then I realized that if the foam around the mount hadn't given a bit, I'd be looking for a new motor right now....
My canopy blew off a couple times too.
All-in-all great $135 plane.... too bad mine was $260
"Support you local hobby shop"
Old Jul 18, 2012, 10:53 AM
LeTrucker67 is offline
Find More Posts by LeTrucker67
Joined Sep 2011
oh? What is it?!
LeTrucker67 is offline Find More Posts by LeTrucker67
Old Jul 18, 2012, 06:42 PM
Joined Aug 2011
Cool... Enjoy it.
Old Jul 31, 2012, 03:26 AM
Luke Warmwater is offline
Find More Posts by Luke Warmwater
Joined May 2011
Well....my MX2 has now been sold.....
I needed to make space in the hangar for the Sebart 342 30e that should be getting delivered this morning!
Luke Warmwater is offline Find More Posts by Luke Warmwater
Old Jul 31, 2012, 04:30 PM
Joined Sep 2011
finish ^^
Old Aug 05, 2012, 04:09 PM
dukepapas is offline
Find More Posts by dukepapas
Joined May 2010
hello to all!! i have mx from hobyking but im not hapy at all with this moter its a crap and dont have power with the original 3 Blade Prop. i try one apc 14x7 but its 0 power.
so i want another powerfull moter for scale use and not for 3d dont need crazy thrast but more power,what moter for hobbyking you suggest with original 3 Blade Propeler that he have?
dukepapas is offline Find More Posts by dukepapas
Old Aug 06, 2012, 04:55 AM
wizzard363 is offline
Find More Posts by wizzard363
flying or crashing into air?
wizzard363's Avatar
Australia, VIC, Langwarrin
Joined Feb 2011
There must be a problem with yours as mine from HK has heaps of power
Have you set the throttle range for the esc ?
What size battery are you running ?
wizzard363 is offline Find More Posts by wizzard363
Old Aug 06, 2012, 07:47 AM
Joined May 2010
i use 3000mah 4cell and cound only 360 wats with original prop i think we need 2x this power. i think we need this. 1-2-or 3
1.http://www.hobbyking.com/hobbyking/s...dproduct=19621
2.http://www.hobbyking.com/hobbyking/s...idproduct=8484
3.http://www.hobbyking.com/hobbyking/s...8486:confused:
Old Aug 06, 2012, 07:59 AM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
I use the NTM motor on my MX2, awesome thrust, point to the sky and open the throttle! I am running it on 14x8 apc and 4S 2200mAh and 2650mAh.
But the stock motor was pretty good, I only replaced because mine failed.
If you are only making 360 watts, something is wrong, should be a fair bit more then that. Like wizzard said, calibrate throttle. And check motor for bad bearings, loose wires etc.
All else fails, go the NTM motor you linked, I am running on stock (70A) ESC no probs, but using a separate UBEC as its not good running anything more then 3S on a linear BEC like im assuming the stock one is. And im using digital servos all round.
sammyc is offline Find More Posts by sammyc
Old Aug 07, 2012, 07:05 PM
AndyRo is offline
Find More Posts by AndyRo
AndyRo's Avatar
Romania, Neamt, Piatra Neamt
Joined Sep 2010
Here is o short video of my MX2. More to come.
HobbyKing MX2 EPO 1400mm (3 min 38 sec)
AndyRo is offline Find More Posts by AndyRo
Old Aug 08, 2012, 06:36 AM
Joined Aug 2011
Hey all.
Just as an update, the KMP Breitling version that I bought (was a gift actually, I wasn't going to get it because of the price, but my mom said "just get it, I'll buy it for you"). Anyway, here's the link, but just wanted to point out that the specs on the page were wrong. Mine came with a 42-50 motor and 70amp esc. Will report back with watts when I get a flight in. I've installed the FrSky FAS-100 amp meter so I'll be able to see the watts in flight.
Speaking of that, there's not alot of room in there for electronics is there....
http://www.kmp.ca/product_info.php?products_id=281
Old Aug 08, 2012, 09:13 AM
Jstjern is offline
Find More Posts by Jstjern
Suomi, Espoo
Joined Sep 2011
3d version
You've got the 3D version. The motor draws about 65A with a fresh 4s battery and stock prop: around 900 W. Enjoy!
Jstjern is offline Find More Posts by Jstjern
Old Aug 09, 2012, 12:12 AM
Cubcrazy is online now
Find More Posts by Cubcrazy
Scale Foam Flyer
Cubcrazy's Avatar
United States, AR, Cabot
Joined Oct 2007
Paint
I have heard that the finish on this plane flakes off easily. Has anyone tried spraying it with a Polycrylic or similar product to protect the finish? I am thinking that some satin Polycrylic spray would do well and look good. Thoughts?
-Cub
Cubcrazy is online now Find More Posts by Cubcrazy
Latest blog entry: Warning!! Graphic images of...
Discussion Anyone tried the BlitzRCWorks MX2 Pro 3D? HallaBalla Foamies (Kits) 2 Mar 26, 2012 08:16 AM
Discussion 4 CH BlitzRCWorks 2.4GHz Giant Air Zermatt EC-135 jblackwell Coaxial Helicopters 9 Sep 07, 2010 08:37 AM
Sold Texas Pickup: BlitzRCWorks GIANT F-117 RX ready w/light, bomb drop, retracts: $140 Roswalt Aircraft - Electric - Jets (FS/W) 4 Jun 13, 2010 04:59 AM
Question mx2 or multiplex acromaster and st model mx2: Unboxing vid? build vid? y info? jakerevs 3D Foamies 2 Mar 27, 2010 02:56 PM
Question MX2 von Hype and ST-model MX2? Thomas*rc Electric Plane Talk 4 Nov 17, 2009 02:42 AM
