Old May 14, 2011, 06:44 PM
Mikey-flies is offline
Find More Posts by Mikey-flies
Alberta, Canada
Joined Sep 2001
Yikes... something appears to be off there for sure.
Mikey-flies is offline Find More Posts by Mikey-flies
Old May 14, 2011, 08:26 PM
Flying-Monkey is offline
Find More Posts by Flying-Monkey
Did you get it on video?
Flying-Monkey's Avatar
United States, FL, Ponce De Leon
Joined Nov 2005
I'll say thanks Sentry for saving me a hundred dollars.
If only the speed, altitude, and heading were correct, it would be a perfect item...
Flying-Monkey is offline Find More Posts by Flying-Monkey
Old May 16, 2011, 08:21 AM
skylarkfpv is offline
Find More Posts by skylarkfpv
Joined Apr 2011
Originally Posted by SENTRY 62 View Post
I had a few issues (not related to the OSD) for the 1st review... as you can see (LOL)
Not to be dismayed - I was finally able to give it a good thrashing
On "the other site" there is discussion on improvements. The only real issue I have is flickering with the battery data - maybe I have a faulty current sensor although it does appear to be accurate, it shouldn't be flickering. The demo videos from Skylark do not flicker. I rarely post over here anymore (in this section) but felt the need to support Skylark since I was one of the 1st with the OSD in the air. You guys know where to find me for my future test flights w/ Skylark. Happy flying,
Sentry
Hi SENTRY,
We hard analyzed your post videos, the current sensor is OK.
The battery data flickering occurs because of a firmware bug in NTSC mode, now we have fixed it.
A USB update cable will be posted out to you.
You can upgrade new verision firmware and configure display mode via the cable
We apologize for the inconvenience. Thank you for your understanding and cooperation.
Best regards,
Skylark FPV Service Center
skylarkfpv is offline Find More Posts by skylarkfpv
Old May 16, 2011, 09:26 AM
Joined Nov 2005
Skylark, what do you plan to do to fix the large problem with the altitude setting. It's useless to even have on the screen, because of how inaccurate it is.
Old May 21, 2011, 04:56 PM
tuppertn is offline
Find More Posts by tuppertn
Postcards From The Purple Edge
tuppertn's Avatar
United States, OK, Sand Springs
Joined May 2007
Mine arrived today. Ordered on 24 April and shipped via registered airmail for $6. 27 days from China to Rhode Island.
I'll try to get it hooked up tonight so maybe I can do some testing tomorrow afternoon. I'll let you guys know if mine has the same issues as Sentry's.
kendall
EDIT: They did send me the free USB cable even though I ordered before that was announced.
tuppertn is offline Find More Posts by tuppertn
Old May 21, 2011, 05:38 PM
tuppertn is offline
tuppertn's Avatar
Joined May 2007
I untwisted the GPS wire, put 7 wraps on a 10mm torroid next to the GPS board and retwisted. Not sure if it will matter.
kendall
Old May 22, 2011, 12:40 PM
SENTRY 62 is offline
Find More Posts by SENTRY 62
I LIKE WAFFLES....
SENTRY 62's Avatar
Powder Springs, GA
Joined Sep 2010
^^ I don't have any torriods on my plane - haven't needed any so far. Please post your flight video if you can so I can compare.
As soon as I get the update cable I will reload the software. Skylark are you going to post the instructions for firmware update on the site or are they included with the cable?
Below, I will do a quick review just to recap action items.
ISSUES:
1) when I power the motor, the km/h data moves from 0 even when the plane is not moving - is this expected?
2) the altitude and distance to/from home seems to drift even with multiple sats locked (altitude seems to drift more than the distance)
3) battery data flickering (this is corrected with new firmware update - I will post new results after testing)
FEATURES I WOULD LIKE TO SEE:
1) a downloadable firmware that includes artificial horizon
* this should be optional as I don't like artificial horizon on clear days
* or maybe a single download, but allows a MENU to select options like (metric/imperial/horizon on/horizon off, etc)
2) Imperial data vs Metric
3) RSSI displayed in values from 0% - 100%
4) ability to turn OSD on/off via the radio would be nice
When I reload my firmware I will do more test flights and will post here an on FPVLAB
SENTRY 62 is offline Find More Posts by SENTRY 62
Old May 22, 2011, 07:40 PM
Joined Nov 2005
Sentry, have you had any better results from the GPS?
In your video, it seemed very unreliable.
Old May 22, 2011, 08:19 PM
I LIKE WAFFLES....
SENTRY 62's Avatar
Powder Springs, GA
Joined Sep 2010
I haven't flown in a while - once I get the cable and new firmware I'll go at it again. I love the innovation of this OSD and the weight/size and easy of installation. Of course when you buy a new release it will have it's issues - but Skylark seems to be very busy going over the code and I predict that it will only get better and better.
Old May 22, 2011, 08:34 PM
Joined Nov 2005
I want one, but I'll wait for the better one....
Old May 23, 2011, 03:41 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Based on what info / sensors ?
renatoa is online now Find More Posts by renatoa
Old May 23, 2011, 03:44 AM
BlueAngel2000 is offline
Find More Posts by BlueAngel2000
Flying like an Angel.
BlueAngel2000's Avatar
Austria
Joined Sep 2007
throttle based like the speed value.
Just kidding.
Does not know how he could suggest this. :?
For such a simple and small OSD, we don't want addon sensors.
For such type of applications we have Eagle Tree or Dragon OSD, .....
BlueAngel2000 is offline Find More Posts by BlueAngel2000
Old May 23, 2011, 09:43 PM
I LIKE WAFFLES....
SENTRY 62's Avatar
Powder Springs, GA
Joined Sep 2010
SKYLARK...
I received the USB cable for the firmware update. Please post the instructions or add them to your website. I'd like to test the improvements this weekend.
* I also sent you a private message
Old May 26, 2011, 10:04 PM
Joined Apr 2011
Skylark Tiny OSD Upgrade
SKYLARK...
Sorry for the late reply.
How to upgrade the firmware, please refer to the instruction
http://www.skylarkfpv.com/intl/en-us/tiny_upgrade
Old May 26, 2011, 10:24 PM
Joined Apr 2011
If the OSD support artificial horizon, you have to expand a attitude sensor .
You can set other features by Skylark Configuration Software
New Product NEW BSII OSD - Smallest OSD in the market fpvsystems FPV Talk 12 Jun 19, 2010 03:59 AM
Discussion DX6i full featured? benedium Radios 24 Feb 28, 2010 07:45 AM
Discussion Smallest 'Full House' EDF FlyAndy Electric Ducted Fan Jet Talk 6 May 13, 2009 11:08 PM
Discussion Larger full featured "Rookie"? hangglider Flying Wings 2 Jan 23, 2006 02:43 PM
"Gilligan's Island" hotwire foam cutter; easy yet full-featured vpatron Foamies (Kits) 19 Dec 19, 2005 10:43 PM
