Old Oct 14, 2012, 01:37 PM
u2builder is online now
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
How to connect Skylark Trace IV?
I am thinking of buying one but don't understand connection to camera and TX. I assume I run 12V power and ground to my 12V camera and TX from connections on OSD, correct?
Camin: Is this where the yellow signal wire from the camera connects?
Cbvsout: Is this where video output fromOSD connects to the yellow signal wire of the TX?
Audioout: What is this and does it connect to one of the audio channels of the TX?
u2builder is online now Find More Posts by u2builder
Old Oct 15, 2012, 09:26 AM
glmccready is online now
Find More Posts by glmccready
Gary
glmccready's Avatar
United States, MD, Salisbury
Joined Mar 2011
Correct
Camin = camera signal in
Cbvsout = must be Video out
Both must have a common ground
Audio out= ? No clue, audio doesn't need to be processed but the diagram in the manual shows three wires to the Tx?
http://www.skylarkfpv.com/u_file/pro...8575770679.pdf
glmccready is online now Find More Posts by glmccready
Old Oct 18, 2012, 05:31 AM
BondiRC is offline
Find More Posts by BondiRC
Joined Jun 2012
Hi,
I need some help with the tiny OSD ii,
I am trying to configure it on a of and can't get it to work.
I installed the USB connector to the GPS port, the of installs the driver and assigns a com port to it, but then when I run the config tool it fails to hardware detect, it comes up with a port 12 open error. I've tried to change ports manually and auto but no luck. I am baffled
Any one know what is going on??
John
BondiRC is offline Find More Posts by BondiRC
Old Oct 18, 2012, 05:33 AM
BondiRC is offline
Joined Jun 2012
Sorry I did not realise the spell-check error
Hi,
I am trying to configure it on a PC and can't get it to work.
I installed the USB connector to the GPS port, the PC installs the driver and assigns a com port to it, but then when I run the config tool it fails to hardware detect, it comes up with a port 12 open error. I've tried to change ports manually and auto but no luck. I am baffled
John
Old Oct 18, 2012, 09:13 AM
Gary
glmccready's Avatar
Joined Mar 2011
Bondrc: You might try to open up "device manager" and then plug it in to see which port actually is used. You can then change it and then try to connect. That is what i had to do.
Old Oct 30, 2012, 09:48 AM
Franck is offline
Find More Posts by Franck
-plancks only-
Franck's Avatar
The Netherlands, UT, Benschop
Joined Oct 2001
Tiny OSD 1 and RSSI, question
Hi Guys,
I am about to connect my Multiplex IPD DS Reciever to the Tiny OSD. I measured output on the SA676 chip and with TX on I have 1,45V and TX off 1.1V. Can I just connect this voltage (via wire/connector) to the OSD ?
Tnx a bunch!
Franck
Franck is offline Find More Posts by Franck
Old Nov 02, 2012, 03:11 AM
BondiRC is offline
Joined Jun 2012
Glmccready: thanks buddy, I figured it out. I had to muck about with the com port allocation in the device manager..
Old Nov 11, 2012, 11:03 AM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
I have just gotten a new Skylark III Tiny OSD. I don't have it hooked up yet because I am still awaiting some FPV gear but would like to get it "programmed".
What is the basic proceedure to configure the software and/or firmware?
Does the Skylark need to be powered up with 5V in order for it to be programmed, or is the USD connection all that is needed?
I have been to the Skylark website but am a little confused about what software goes with with the Tiny III. If this information is posted somewhere a link would be great, or if not, a brief explanation. Thanks.
Old Nov 11, 2012, 11:38 AM
Gary
glmccready's Avatar
Joined Mar 2011
I think you are good to go if you have version III. I can't recall but just try to plug in the USB and run the software. If it doesn't power then run a servo cable to the Rx for power (5v). Should be everything you might need on this page:
http://www.skylarkfpv.com/en/down.php
And here a a Google doc too:
https://docs.google.com/file/d/0B-tv...N1k/edit?pli=1
Old Nov 11, 2012, 01:20 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
When trying to connect it only lets me manually select the Com Port and there is only one choice (com port 4) and I get "open com port 12 err. As fa as I can tell com port 12 is not open. How do I connect. I tried two different computers (Vista and Win 7)
Old Nov 11, 2012, 03:20 PM
Assaf110 is offline
Find More Posts by Assaf110
Joined Jun 2011
you don't need 5v power, just plug in the USB port.
In order to solve your problem, right click the skylark app, then select properties .
Under the compatability tab, select to windows XP.
Run the program again and let it choose the com port automatically ,
Ask me how I know... (did it yesterday...).
Assaf110 is offline Find More Posts by Assaf110
Old Nov 11, 2012, 03:53 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Yep, finally worked. Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!
Old Nov 15, 2012, 10:03 AM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Hey guys, what "triggers" the final "flight summary" page?
Also, if Skylark is monitoring this thread, I would like to suggest that they update the Configuration Program to work with modern computers like Win 7 or 8 and not require the XP emulation mode. The screen doesn't really look right on my computer and is hard to navigate even in the XP mode.
Old Nov 15, 2012, 10:19 AM
Gary
glmccready's Avatar
Joined Mar 2011
u2: I think it triggers when you stop changing position. Mine seems to popup whenever I hover my quad, and it disappears again when I start traveling.
Old Nov 15, 2012, 11:07 AM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
OK, that does seem to be what is happening. And sometimes the "speed" sensing doesn't seem to be all that accurrate so even when I am going, which is always fairly slow, it pops up. The barometric altitude is pretty decent though which is the most important.
New Product NEW BSII OSD - Smallest OSD in the market fpvsystems FPV Talk 12 Jun 19, 2010 03:59 AM
Discussion DX6i full featured? benedium Radios 24 Feb 28, 2010 07:45 AM
Discussion Smallest 'Full House' EDF FlyAndy Electric Ducted Fan Jet Talk 6 May 13, 2009 11:08 PM
Discussion Larger full featured "Rookie"? hangglider Flying Wings 2 Jan 23, 2006 02:43 PM
"Gilligan's Island" hotwire foam cutter; easy yet full-featured vpatron Foamies (Kits) 19 Dec 19, 2005 10:43 PM
