Old Jul 16, 2012, 01:08 PM
WEREE is offline
Find More Posts by WEREE
WEREE's Avatar
United States, CA, Fremont
Joined Dec 2008
Does this Skylark 60A current sensor support LIPO 6-cell voltage?
I have a 6-cell T-Rex 450 FPV machine that could really use this light weight OSD but all the videos I've seen of this Skylark FPV are using 3s setups.
WEREE is offline Find More Posts by WEREE
Old Jul 17, 2012, 05:38 AM
skylarkfpv is offline
Find More Posts by skylarkfpv
Joined Apr 2011
You can try.
3S-6s should theoretically work with the system
skylarkfpv is offline Find More Posts by skylarkfpv
Old Jul 17, 2012, 04:44 PM
WEREE is offline
WEREE's Avatar
Joined Dec 2008
Originally Posted by skylarkfpv View Post
You can try.
Thanks Skylark. The Skylark store might have the incorrect information for the 60A current sensor because it shows 4s is the maximum voltage for this unit:
http://www.skylarkfpv.com/store/inde...&product_id=76
Or is this a different current sensor than the one that comes with the Tiny III? But the picture of the sensor looks just like the sensor in the Tiny III product photos.
Old Jul 17, 2012, 08:12 PM
Joined Apr 2011
Yes , they are the same one.
We recommend using 3s/4s battery in FPV flight
But in fact , it support 3s-6s battery
Old Jul 27, 2012, 10:24 PM
bstussie is offline
Find More Posts by bstussie
It's electric Boogie woogie
bstussie's Avatar
United States, NC, Rocky Mount
Joined Sep 2007
ok just purchased my 1st osd and need a little help
I purchased the HobbyKing Tiny OSD which I have read is just a re-branded Skylark OSD, I wanted to verify that my thoughts on how it should hook up are correct.
here is my setup
Immerson 600mw 5.8GHz Transmitter
Fatshark googles
Ready Made RMRC-420XVN Camera
the camera has 3 lines out for video which plug directly to my existing transmitter
Red - 5v
Black - GND
Yellow - Video
and of course 2 other cables black/Red for power
* From what I have read the red 5v line will go directly from cam to the transmitter
* the black line will get intercepted between the cam and transmitter and go to the GND on the OSD
* the yellow will get cut and go in on middle pin on OSD and then leave OSD and go to Transmitter?
i have made a really crappy picture to illustrate what I have in my head is right, let me know what you think
bstussie is offline Find More Posts by bstussie
Old Jul 28, 2012, 11:18 AM
Nobert is offline
Find More Posts by Nobert
Nobert's Avatar
Tucson Avra Valley, Arizona, United States
Joined Jul 2002
That will work.
Nobert is offline Find More Posts by Nobert
Old Jul 29, 2012, 07:55 AM
bstussie is offline
bstussie's Avatar
Joined Sep 2007
Originally Posted by Nobert View Post
That will work.
Old Aug 02, 2012, 12:03 AM
kismet is offline
Find More Posts by kismet
Joined Jan 2012
usb-ttl cable
I have a fieyu tech usb to ttl cable it is a four pin connection red, blk, wht, grn, is it possable to use this to connect to the tiny osd? I just order a hobby king tiny osd used on ebay and it has not arived yet and I can not seem to find a upclose view of the gps port on the board to see what the conection type is? I know the cable is cheap but with shipping and time I would much rather use what I have even if I have to build an adapter plug. also when connecting the board to configure it or update firmware should the board be powered up or is it powered via the usb? 5.5v ttl or 3v ttl?
any help would be great thanks
kismet is offline Find More Posts by kismet
Old Aug 05, 2012, 12:11 AM
teebok is offline
Find More Posts by teebok
teebok's Avatar
Pico Rivera, CA
Joined Apr 2004
here is a pic of the plug that goes in to the gps port.
teebok is offline Find More Posts by teebok
Old Aug 07, 2012, 08:18 PM
Joined Apr 2011
Red: VCC 5V
Black: GND
Orange: TX
White: RX
Old Aug 09, 2012, 07:20 AM
FPVAustralia is offline
Find More Posts by FPVAustralia
Joined Jul 2012
Great OSD, especially for small aircrafts.
FPVAustralia is offline Find More Posts by FPVAustralia
Reply With Quote  (Disabled)
Old Aug 09, 2012, 09:58 PM
Navigator53 is offline
Find More Posts by Navigator53
Navigator53's Avatar
United States, OR, Canby
Joined Oct 2009
Is "Landing Summary" a function of distance or speed?
I'm testing Trace II in my backyard and want to make sure it's enough space to trigger landing summary.
Does it take distance from take off point or speed to get a reading on the on screen display?
Thanks guys
Navigator53 is offline Find More Posts by Navigator53
Old Aug 09, 2012, 11:31 PM
Joined Apr 2011
It should be OK, please make sure that summary function is enabled by Configuration Tool
Old Aug 10, 2012, 12:26 AM
Joined Jul 2012
Seems that a corner chip broke on a crash landing and the OSD is getting really hot ever since. I will try to fix this but if anyone knows what might be solution please PM me.
Old Aug 10, 2012, 12:29 AM
Joined Oct 2009
Thanks Skylark!
I'm actually trying to turn off the landing summary as I'm using it with Naza/GPS and it's holding position so well the Trace II thinks it's landed
Skylark is a great OSD for actually telling me altitude, distance and way to home.
Just trying to save myself a trip to the field to test for "off" 'cause I won't have a pc out there so I wanted to confirm in my backyard
New Product NEW BSII OSD - Smallest OSD in the market fpvsystems FPV Talk 12 Jun 19, 2010 03:59 AM
Discussion DX6i full featured? benedium Radios 24 Feb 28, 2010 07:45 AM
Discussion Smallest 'Full House' EDF FlyAndy Electric Ducted Fan Jet Talk 6 May 13, 2009 11:08 PM
Discussion Larger full featured "Rookie"? hangglider Flying Wings 2 Jan 23, 2006 02:43 PM
"Gilligan's Island" hotwire foam cutter; easy yet full-featured vpatron Foamies (Kits) 19 Dec 19, 2005 10:43 PM
