Apr 12, 2011, 11:28 PM
United States, CA, Arcadia
Joined Nov 2003
Build Log - Simple Twin-Boom Pusher
This will be my first build log with RCGroups. I want to share a very successful design I have that is very cheap, quick, easy, and fun, based on my "So" series.
Here are some details:
Main Construction Materials: Dollar-Tree foam board (black, 2 pieces 20x30"), 2" wide clear packing tape, hot glue, 5mm carbon tube (spar)
Wingspan: 30"
Airfoil: 10% KFm3
Target RTF Weight: 16-18 oz
Power: Turnigy C2409-1600, Turnigy 3S1800 20C
Controls: throttle, elevator, aileron (single)
So let's get going!
First, the wing. Cut from foam board (I'll just call it FB from now on) a piece that is 30" long by 9". By the way, have you ever found a perfectly straight sheet? It seems they all have a little warp to them, but the warps mostly disappear when I make wings. You will also need a strip of foam board measuring 30" by 1.75". This strip is the intermediary piece of the KFm3 airfoil. The 6" and 3" pieces will be folded, so don't cut all the way through.
