Old Aug 06, 2011, 03:09 AM
Dimateo is offline
Find More Posts by Dimateo
United States, NY, Yonkers
Joined May 2010
Originally Posted by Balr14 View Post
I'm constantly amazed at the extents some people will go to, to avoid 4 channels.
That's why I'm sticking with free flight helis.
Dimateo is offline Find More Posts by Dimateo
Old Aug 07, 2011, 01:22 PM
edwong3 is offline
Find More Posts by edwong3
edwong3's Avatar
Central Florida, USA
Joined Sep 2010
Which "free flight" helis do you fly, and where do you buy them?
Ed
edwong3 is offline Find More Posts by edwong3
Old Aug 07, 2011, 06:57 PM
Jburg is offline
Find More Posts by Jburg
Joined Aug 2011
whatz up 9104
Went out just now to play with the no fly 9104 and it will not even lift off 1/4 inch. Played with it for a few minutes and stopped to check the motor....very hot. You don't want to keep you finger on it at all. I'm guessing its shot?
Pulled it out of the bird and the main shaft spins freely, so I don't suspect any binding and the shaft is not bent. Guess I'll order a new motor. Is there any upgrade motor or just stick with OEM?
thanks for the help.
Jburg is offline Find More Posts by Jburg
Old Aug 07, 2011, 08:22 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
I'd say it's shot. ESky probably sells the best brushed motors. But honestly, none are very good. The larger the heli, the fewer the options, too.
Balr14 is offline Find More Posts by Balr14
Old Aug 13, 2011, 05:58 PM
onlymines is offline
Find More Posts by onlymines
Joined Aug 2011
Originally Posted by TeeJayBee View Post
LOL
Even I wasn't daft enough to start out with a 3ch (as I knew I needed to move on)
But if you like big and simple and can't make your mind up over 3 or 4 ch then take a look at this whopper
Loads of them dirt cheap on ebay
i bet that heli cant fly cause the blades are too short
onlymines is offline Find More Posts by onlymines
Old Aug 13, 2011, 06:07 PM
Joined Aug 2011
anyways anyone here have a DH 9104 and got it to hover nicely in the air without moving in any direction? just recently got mines and it keeps moving to the left so i did the paperclip mod and now it moves forward and i cant trim it to stop.
Old Aug 15, 2011, 01:34 PM
killbucket is offline
Find More Posts by killbucket
I'm FAMOUS
Joined Mar 2010
Move the servo arm on the servo, so it holds the swash lower in the back.
killbucket is offline Find More Posts by killbucket
Old Aug 22, 2011, 08:40 AM
Jburg is offline
Joined Aug 2011
Got my 9104 back in the air after replacing the main motor...thanks Balr14.
I don't really have any forward or reverse flight capability. I made the swash modification I found no the 9100 forum, it will hover OK. The servo moves the swash up and down, but still barely any forward/backward control. Any thoughts?
Old Aug 22, 2011, 11:30 AM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
You may be able to use a longer arm on the servo to provide more movement, or put a collar on the mainshaft that allows the swashplate to tilt, but not move up and down on the shaft. The problem really is in the design, so anything you do is likely to have some negative effects. A 4 channel heli would use a 90 swashplate and one servo for pitch (elevators) and another servo for roll (ailerons). This heli used one servo to provide both functions, so it employs a 120 swashplate, sort of splitting the difference between the two. 120 gives it more bias toward elevators than ailerons, but nothing close to what you would get with a conventional 90 swashplate. On top of that, it uses a 45 offest flybar and it's purpose is to damp movement authority. You can't have a heli without ailerons, so there's lots of design compromises at work here to compensate for that missing servo. If you want 4 channel performance, you need to buy a 4 channel heli.
Old Aug 22, 2011, 01:32 PM
Jburg is offline
Joined Aug 2011
Thanks for all your suggestions. I do now have a Blade 120 SR, just waiting for my DX7 to arrive. But, the 9104 is giving my thumbs something to do for now....even the the right thumb should not be controlling the rudder as with this 3 channel machine.
Old Aug 25, 2011, 05:31 AM
fly4fun6719 is offline
Find More Posts by fly4fun6719
Sydney Australia
Joined Jul 2008
Low main blade speed
I was wondering if somebody could give me some advice on a problem that has developed in my 9104. I have only had the heli for a bit over a week.
The main blade RPM is not high enough for lift off. I initially thought it was a battery problem and substuted a fresh lipo with the same result.I have put a wattsup watt meter inline with the battery and its only drawing 7 amps.This will intermittantly rise to 10 amps and main blade will increase in RPM.
I thought if there was any binding in the gearing that the current would be higher rather than lower than normal.
Has anybody struck this problem before and what was done to fix it? Any help would be greatly appreciated.
fly4fun6719 is offline Find More Posts by fly4fun6719
Old Aug 25, 2011, 08:07 AM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
What's your voltage before and after a flight attempt? If it's 8.2- 8.4v before and 7.2v or more after, the motor is probably bad. Heli is carrying a lot of weight with a lot of blade resistance, using a very poor motor.
Old Aug 25, 2011, 10:31 AM
Jburg is offline
Joined Aug 2011
I just experienced this issue and a new motor solved the problem.
Old Aug 25, 2011, 03:58 PM
Sydney Australia
Joined Jul 2008
Battery voltage remained around the 8volts during the tests.Would you still think it was a faulty motor.I thought the receiver/controller board may have been faulty.
Old Aug 25, 2011, 04:20 PM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
So, the battery is good. Could be the board, but those motors really are the first thing I'd suspect. There just aren't any brushed motors really suited to that size heli and amount of blade resistance. However, if you had a crash and did not kill the throttle before impact, or immediately upon impact, you can burn out FETs. It takes like 2 - 3 seconds.
Discussion Double Horse 9100 Series 3-channel Helis killbucket Mini Helis 1500 May 13, 2013 01:41 PM
Discussion New Double Horse 9100 3 Channel Co-Axial Helicopter w/ Built in Gyro chanerz Coaxial Helicopters 86 Apr 13, 2012 07:12 AM
New Product New Double Horse 9101 3 Channel Co-Axial Helicopter w/ Built in Gyro thercguy Coaxial Helicopters 40 Jan 11, 2012 05:24 PM
Sold 9089 Double Horse Shuttle Electric Heli w/Video DVR Senor Jack Aircraft - Electric - Helis (FS/W) 0 Apr 10, 2011 08:15 PM
Mini-Review Double Horse 9100 3-channel copter -Image Heavy! killbucket Electric Heli Talk 0 Jan 30, 2011 05:50 PM
