Old Jan 30, 2013, 10:28 PM
AHMYOWN is offline
Find More Posts by AHMYOWN
Joined Jan 2013
Just purchased the 9104. it was previously flown and could have been crashed. I took it home and powered it up. at the slightest throttle up the heli immediately starts to rotate left and the tail rotor spins at maximum speed. Putting full left on the stick and adjusting the gyro full left only slows it down slightly but not enough to prevent the rotation. HELP!!!
AHMYOWN is offline Find More Posts by AHMYOWN
Old Jan 30, 2013, 11:08 PM
Ken59 is offline
Find More Posts by Ken59
LearningFast
United States, LA, Denham Springs
Joined Jan 2012
Did you charge up the battery fully? One of the indications is that the tail motor is the first to start loosing power and does what you described. Another is a weak tail motor. These fail quite often on these helis. I have been through quite a few of them.
Ken59 is offline Find More Posts by Ken59
Old Jan 31, 2013, 10:31 AM
Tumppi T is offline
Find More Posts by Tumppi T
Registered Crasher
Tumppi T's Avatar
Finland, Tuusula
Joined Mar 2012
Here is some pics of my DH 9104
http://www.rcgroups.com/forums/showt...4#post23990022
Tumppi T is offline Find More Posts by Tumppi T
Old Feb 01, 2013, 09:04 AM
timg734 is offline
Find More Posts by timg734
Joined Dec 2012
i just put a different fly bar on off of gt qs 8004 helicopter had to drill out the pin hole a little.i haven't had it out yet waiting for a few other parts to come in.i hope i didn't mess this up doing this dog bones are in a different angle so not sure about this when other parts come in and i try it i will update this item!i'am just trying to get rid of the metal flybar like on the 9118.
timg734 is offline Find More Posts by timg734
Old Feb 01, 2013, 12:55 PM
AHMYOWN is offline
Joined Jan 2013
I charged it fully. Same issue. just keeps rotating to the left. I hold it in my hand and the rear blades seem to be spinning at maximum speed. full right on the stick only slows the tail motor a bit but not enough to prevent the rotation.....any other suggestion?
Old Feb 01, 2013, 07:05 PM
Ken59 is offline
LearningFast
Joined Jan 2012
Well! Either the battery is defective and it cannot supply enough power to overcome the torque of the main blades, usually in flight this is what happens when it starts to get low, or the tail rotor motor is defective. Does it good altitude with the main?
Old Feb 04, 2013, 01:37 PM
jspcrepair is offline
Find More Posts by jspcrepair
Brakes? Who Needs Brakes?
United States, WV
Joined Jun 2012
After all my troubles with the 9104 and tail rotor and main motors.. I finally replaced the whole tail unit with one from the MJX F45.
I used the tube from the 9104, the rotor housing, fin, motor, and blade from the MJX.
I had to change the connector wires around though because the blade spun the wrong way.
I replaced the main motor with one for the MJX F45 and now... this thing flies like a Dream!
It no longer has the Left Spin issue and it even flies faster and much more stable.
jspcrepair is offline Find More Posts by jspcrepair
Old Feb 06, 2013, 06:20 PM
timg734 is offline
Joined Dec 2012
my 9117 tranmitter and pc board just came in i put everything together and cant get it to sink together iwnated to check the servo and see if i have pluged in in the right spot but all i can get is the lights to flash nonthing more any ideas
Old Feb 06, 2013, 07:46 PM
timg734 is offline
Joined Dec 2012
[QUOTE=timg734;24055852]my 9117 tranmitter and pc board just came in i put everything together and cant get it to sink together iwnated to check the servo and see if i have pluged in in the right spot but all i can get is the lights to flash nonthing more any ideas[/QUOTE
well i watched a youtube and got it to sink but now it only spin in circle and seperates the swashplate and the swashplate is one for a 9117 anyone have any ideas what i did wrong
Old Feb 06, 2013, 07:52 PM
Ken59 is offline
LearningFast
Joined Jan 2012
A video of the main rotating and the tail rotation would be nice. I do take it the main is spinning clockwise and the tail is spinning in the opposite direction?
Old Feb 07, 2013, 07:38 PM
timg734 is offline
Joined Dec 2012
yes the main blades spin clockwise and the tail spins counterclockwise i that is while looking at it from the blade side of the boom.it does get off the gbut it only spins around in circle
Old Feb 07, 2013, 08:29 PM
Ken59 is offline
LearningFast
Joined Jan 2012
Have you changed the rear rotor motor? I know they are weak and I have gone through a few of them. Earlier, jscrepair did some mod to the tail from the mjx f45 tail section and is very happy with it.
Old Feb 08, 2013, 06:08 PM
timg734 is offline
Joined Dec 2012
yes i changed the rear boom and motor to one from a 9101 and shortened boom to same length as the 9104 boom had to drill boom suport to mount the new assembly
Old Feb 08, 2013, 06:11 PM
timg734 is offline
Joined Dec 2012
i also chage flybar to one off of gtqs8400 but also changed it back but still does the same thing no change from that
Old Feb 08, 2013, 10:05 PM
Ken59 is offline
LearningFast
Joined Jan 2012
9101 tail???? Is that a typo? If not, that is a coaxial and there is no way that motor can keep up with the torque of the 9104 370 motor. A 9116 or 9118 series fixed pitch heli tail will do, as they are basically all the same. These are weak tails and don't last long. Look up the modifications of TrumpT. He used the tail from an MJX F45 and he says it worked out well and may last longer. I did quite a few mods on mine, but it is on the shelf for now until I finish my 450. I plan keeping the frame, but put in a brushless main and rear motors with a variable pitch on the rear just like my 450. The 9104 is the size of a 250.
Discussion Double Horse 9100 Series 3-channel Helis killbucket Mini Helis 1500 May 13, 2013 01:41 PM
Discussion New Double Horse 9100 3 Channel Co-Axial Helicopter w/ Built in Gyro chanerz Coaxial Helicopters 86 Apr 13, 2012 07:12 AM
New Product New Double Horse 9101 3 Channel Co-Axial Helicopter w/ Built in Gyro thercguy Coaxial Helicopters 40 Jan 11, 2012 05:24 PM
Sold 9089 Double Horse Shuttle Electric Heli w/Video DVR Senor Jack Aircraft - Electric - Helis (FS/W) 0 Apr 10, 2011 08:15 PM
Mini-Review Double Horse 9100 3-channel copter -Image Heavy! killbucket Electric Heli Talk 0 Jan 30, 2011 05:50 PM
