Old Jan 21, 2013, 12:14 PM
timg734 is offline
Find More Posts by timg734
Joined Dec 2012
your right this is addicting i have only owned my dh9118 a few months.i didn't do the balde flip at first and couldn't get it to fly outside but i found the rcgroups form and did some reading the i did the lower blade flip changed balance bar and rear rotor and what a difference it made then my friend hank gave me this deal on a 9104 with parts can't wait to fix and fly it.
timg734 is offline Find More Posts by timg734
Old Jan 21, 2013, 12:15 PM
Ken59 is offline
Find More Posts by Ken59
LearningFast
United States, LA, Denham Springs
Joined Jan 2012
Yeah, I do like the charger, but do look up some reviews on all of them. Bang for buck, the ac680 is good.
Ken59 is offline Find More Posts by Ken59
Old Jan 21, 2013, 12:20 PM
Ken59 is offline
LearningFast
Joined Jan 2012
Oh, there is a world of difference in the 9104/9117 and the 9118. Coxial to fixed pitch is the next logical step. Look back in the forum and see the mods some have done to the 9104. The weak link is the tail motor which seem to burn out too quick. The Honey Bee direct drive tail is the best option for better control and it will last longer. I think I have gone as far as I can, but I did want to try to build a direct drive variable pitch as I did for my 450. I have to find a tail holder that fits the boom. Maybe when I finish the mods on my 450, I will try.
Old Jan 21, 2013, 12:34 PM
matiac is offline
Find More Posts by matiac
AMA 994002
matiac's Avatar
United States, RI, Westerly
Joined May 2012
Well, the 9104/9117 IS a 450 sized helicopter, yes? I thought about doing that sort of stuff too, but jeez, 'time yer done, only thing Double Horse on it will be the name on the canopy...
matiac is offline Find More Posts by matiac
Old Jan 21, 2013, 12:37 PM
Ken59 is offline
LearningFast
Joined Jan 2012
No, the 9104 is about the size of a 250. If you look back, I do have a picture of my two together.
Old Jan 23, 2013, 02:52 PM
SarjeNZ is offline
Find More Posts by SarjeNZ
New Zealand, Taranaki, New Plymouth
Joined Aug 2012
Hi
I'm new to the 9104. It flies really nicely except that the forward motion is poor, and the swash plate looks and acts average as well. I have seen comments about upgrading the swash plate, however I do not want to upgrade to a 4th channel yet. Do you have a recomendation for swash plate change(s) to help forward motion? or any other changes that may help?
Cheers
Peter
SarjeNZ is offline Find More Posts by SarjeNZ
Old Jan 23, 2013, 06:37 PM
Ken59 is offline
LearningFast
Joined Jan 2012
Welcome! I had the same problems with the 9104. Oh, mine is a monster now! I have do many mods as it is now a 5ch beast. To say it is a 9104 any longer is a stretch. I do have to replace the direct drive motor, and it is coming. The tail motors seem to burn out too quick, so I would order a few now if possible. They are pretty inexpensive. As far as increasing forward motion, make sure you have the servo push rod on the last hole in the servo arm. The 9104 is a bit tail heavy, also, so put some playdough or plumbers putty in the nose. You can check to see how much you need by lifting the heli by the flybar (with the flybar at a right angle to the heli) and then judge how much weight you need to get it right. This should help the forward motion a bit.
Old Jan 25, 2013, 04:25 PM
timg734 is offline
Joined Dec 2012
i have the swashplate for a 9117 for my conversion but i just ordered a metal upgrade parts combo for esky e030/e515 from ebay for the metal swashplate but not sure if it will even work anyone know if i made a mistake??it also say for esky big lama thanks for any info
Old Jan 26, 2013, 12:15 AM
lucky73129 is offline
Find More Posts by lucky73129
United States, OK, Oklahoma City
Joined Dec 2012
ok guys i have a problem with my 9104 it wont lift off the ground swapped batterys not it tested the motors and they are working like they should be ( the rear motor is kinda slow when you turn it left i think is that normal and would that cause the problem) so i would assume it would be the pcb correct? and if it is my chopper is 27mhz would i just need to order another pcb and hook it up and good to go or how do i get it to work because i want to fly it i have a few choppers but i love the look of the 9104
but a list of my birds are the 9104 9053 s031g s107g and getting the blade sr 120 and also may be getting the qs8006 but anyway i need advice on the pcb on what to do thanks
lucky73129 is offline Find More Posts by lucky73129
Old Jan 26, 2013, 08:42 PM
Ken59 is offline
LearningFast
Joined Jan 2012
If you have volt meter, I would measure the output of the pcb to the motor. You can see if the volts are correct and if so, not the pcb, but the motor. Some of them have been known to be bad.
Old Jan 27, 2013, 09:15 AM
Joined Dec 2012
what should the readings be?
Old Jan 27, 2013, 11:30 AM
Ken59 is offline
LearningFast
Joined Jan 2012
If you are still running the 7.4V lipo, it should be at least that. A fully charged 7.4v will actually be around 8.4. At full power, you should somewhere near that. Be careful, as the pins are close together on the pcb and you might short them! You can take the motor out and check the voltage at the motor. Up to you.
Old Jan 27, 2013, 07:26 PM
Joined Dec 2012
the battery i have in the dh is a li-on not a lipo but anyway i check the power in on the pcb or the plug on the motor on the pcb
Old Jan 27, 2013, 10:50 PM
Ken59 is offline
LearningFast
Joined Jan 2012
If you get everything working, look at the Genace 7.4 1300mah batteries. They work good in the 9104.
Old Jan 27, 2013, 11:11 PM
Ken59 is offline
LearningFast
Joined Jan 2012
Oh Ribble, put on a direct drive motor again, but it was for 11v so it could not keep up. So, after reading about a few putting 11v through the ek2-701 (normally 7.4vI), I gave it a try... for about 30 seconds, that is! Burnt it out so the 9104 is down for the count. I will revive it at a later day with complete brushless mod. I go the direct drive variable pitch built for the 450 and it works, but need a new esc (on order). I got the Flymentor complete adjusted out and is working well. I have a second ddvp built, but will have to either use a bushing on the 9104 boom or drill out the tail boom holder to 12 mm for the 450 boom and then just shorten it to length. I have an extra gyro to run the servo anyway. I guess I should call it a triple horse 9554 now??? I will try to post some pictures on the ddvp thread I created later this week.
Discussion Double Horse 9100 Series 3-channel Helis killbucket Mini Helis 1500 May 13, 2013 01:41 PM
Discussion New Double Horse 9100 3 Channel Co-Axial Helicopter w/ Built in Gyro chanerz Coaxial Helicopters 86 Apr 13, 2012 07:12 AM
New Product New Double Horse 9101 3 Channel Co-Axial Helicopter w/ Built in Gyro thercguy Coaxial Helicopters 40 Jan 11, 2012 05:24 PM
Sold 9089 Double Horse Shuttle Electric Heli w/Video DVR Senor Jack Aircraft - Electric - Helis (FS/W) 0 Apr 10, 2011 08:15 PM
Mini-Review Double Horse 9100 3-channel copter -Image Heavy! killbucket Electric Heli Talk 0 Jan 30, 2011 05:50 PM
