Old Jun 07, 2011, 03:14 AM
Mejda is offline
Find More Posts by Mejda
Mejda
Joined Jun 2011
Originally Posted by Frank_fjs View Post
This is what I don't understand...
If you buy a single rotor helicopter, you obviously want to advance your skills and progress from the coaxial design. Fine. So why on earth would you get a 3 channel single rotor?
The 9100 and 9104 are the only two that are existence and there's a reason for that.
A 3 channel single rotor will be more difficult to fly than a 4 channel single rotor, a 4th channel adds much needed lateral movement.
How a 4 ch flybarless heli. They ought to be more fun flying outdoors on windy days.
Mejda is offline Find More Posts by Mejda
Old Jun 07, 2011, 08:29 AM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
There are several available. But, the difference between 4 and 6 channel flybarless helis is pretty small.
Balr14 is offline Find More Posts by Balr14
Old Jun 11, 2011, 12:04 PM
ItalianStallion is offline
Find More Posts by ItalianStallion
ItalianStallion's Avatar
Joined Jun 2011
anyone see this review before? the 9104 looks pretty rugged.
Double Horse DH 9104 Single Speed Crash Test Flug Test von Gobelus.de (9 min 7 sec)
ItalianStallion is offline Find More Posts by ItalianStallion
Old Jun 14, 2011, 04:58 AM
tony1983 is offline
Find More Posts by tony1983
Joined May 2011
http://www.360hobby.com/Double-Horse...Gyro-BLUE.html The 9104 here is only $69.99! i only paid $14 for shipping cost.
http://www.360hobby.com/Double-Horse...t-in-Gyro.html this is only $59.99 for 9101
tony1983 is offline Find More Posts by tony1983
Old Jul 12, 2011, 01:53 PM
oldsneakers is offline
Find More Posts by oldsneakers
oldsneakers's Avatar
United States, CT, Hamden
Joined Jul 2011
Battery life
Hey all,
First post here. My friend and I both bought 9104's and are having a blast with them. I was wondering about a replacement battery that would give more flight time without altering the flight characteristics much. Can anyone make a suggestion?
One thing we noticed on the 9104 is the difficulty going forward into the wind. The servo arm has 5 holes and the connecting rod from the swash plate was in the 4th hole. Moving it to the 5th hole seemed to give it a little more forward motion.
oldsneakers is offline Find More Posts by oldsneakers
Old Jul 12, 2011, 04:05 PM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Before going to a bigger battery, you should check the temperature of the motors. Remember too, a bigger battery means more weight, so the motor has to work harder. It may be better to simply get a second battery.
Old Jul 12, 2011, 04:45 PM
Joined Jul 2011
Ok, thanks Balr14. The battery in it seems to be kinda not made to be removed easily the way they used 2 sided tape on it. But I'm sure there's a way to make it more interchangeable.
Old Aug 04, 2011, 09:06 AM
Jburg is offline
Find More Posts by Jburg
Joined Aug 2011
Hi, I'm a nobee at this sport...ie the whole RC thing. I started out with a DH 9104 a week ago. Need a little help, just the other day the heli cannot get more than a foot off the ground. Not sure what is going on. The battery is fully charged and has an no load voltage of about 8 volts. I would hope the battery would last more than a week.
There is no damage to the machine, no serious crashes.
Jburg is offline Find More Posts by Jburg
Old Aug 04, 2011, 10:26 AM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
A fully charged lipo battery has nominally 4.2v per cell, or 8.4v for 2 cells. Considering the mass of that heli and the weak motor, 8.0v is very marginal.
Old Aug 04, 2011, 10:52 AM
Jburg is offline
Joined Aug 2011
I just check it again after a full recharge and I have 8.3 volts.
Is battery the only thing that could be at fault?
Old Aug 04, 2011, 11:52 AM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
8.3v is perfectly acceptable. Now, try to use it and take a reading right after. A bad battery may take a charge well enough, but can't hold it for long. I have two very expensive 3 cell batteries that charge to 12.58v and 12.65v, both quite acceptable. However, one drops to 11.65v and the other to 12.0v in about 30 seconds, which means they are complete crap.
Old Aug 05, 2011, 05:54 AM
Jburg is offline
Joined Aug 2011
I let the battery sit overnight and its still holding a charge, same 8.3volts. When I get home tonight I'll run the Heli for a minute and see what the voltage is. I don't want to spend to much on this Heli as it was just a trial machine to see if I want to get into this hobby. I'm thinking of moving to a decent TX, one of the Blade Heli's to go with it and a sim program.
Old Aug 05, 2011, 07:49 AM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
That will be a very good test. If the battery reads good after a test, then your problem is the motor.
Old Aug 05, 2011, 07:29 PM
Jburg is offline
Joined Aug 2011
Battery was still reading 8.3 volts when I got home this evening. I even checked with power on and the heli motor just slightly idling will no drop in voltage. But after playing with it for about 5 mins, ie letting it hover an inch off the driveway (best it can do) the voltage was down to 7.4 volts...with or without any load. Seems to only take an hour to charge back up. Any suggestions are appreciated.
Old Aug 05, 2011, 10:04 PM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
I'd say motor is shot or you have have too much friction somewhere. Pinion not too tight?
Discussion Double Horse 9100 Series 3-channel Helis killbucket Mini Helis 1500 May 13, 2013 01:41 PM
Discussion New Double Horse 9100 3 Channel Co-Axial Helicopter w/ Built in Gyro chanerz Coaxial Helicopters 86 Apr 13, 2012 07:12 AM
New Product New Double Horse 9101 3 Channel Co-Axial Helicopter w/ Built in Gyro thercguy Coaxial Helicopters 40 Jan 11, 2012 05:24 PM
Sold 9089 Double Horse Shuttle Electric Heli w/Video DVR Senor Jack Aircraft - Electric - Helis (FS/W) 0 Apr 10, 2011 08:15 PM
Mini-Review Double Horse 9100 3-channel copter -Image Heavy! killbucket Electric Heli Talk 0 Jan 30, 2011 05:50 PM
