Old Apr 12, 2011, 03:23 PM
martinwinlow is offline
Find More Posts by martinwinlow
Joined Apr 2011
PowerLab8 - Charge by Specified Ah?
Hi - Is it possible to program a PL8 to charge a cell by a certain amount of Ah and then terminate?
Regards, MW.
martinwinlow is offline Find More Posts by martinwinlow
Old Apr 12, 2011, 04:44 PM
SteveM732 is offline
Find More Posts by SteveM732
SteveM732's Avatar
United States, OR, Beaverton
Joined Feb 2008
Not that I know of. The closest thing you can do is set the termination voltage to a lower value so the pack is only charged to 90%, 80%, or whatever you desire. Mind sharing the application with us so we can think of another way to solve the problem or see if this would be a good feature to request?
SteveM732 is offline Find More Posts by SteveM732
Old Apr 13, 2011, 02:36 AM
Joined Apr 2011
Hi SteveM732 - I am using the PL8 to investigate some large format LiFePO4 cells (3.2V 160Ah) in my EV (evalbum.com/2092). I had driven my EV till my 'fuel meter' was saying it was getting empty and wondered how much more charge they had. So I used the PL8 to discharge the cell fully (down to 2.6V) at 20A rate and was surprised to find there was still 33Ah left. So now I need to charge it back up again to roughly where it was so I can use the main charger to charge the whole pack together again. Hence the need to put back the 33Ah only.
But I'll probably just charge the pack as is and then top the one cell up to the others.
If you can answer my other question tho (posted separately), that is a bit more serious as I can't get the cell to charge at all due to a "Safety Code 52 - Low volt (Replace bad pack)" error I'm getting. I assume there is a setting somewhere which I haven't done right... MW.
Old Apr 13, 2011, 08:56 AM
SteveM732's Avatar
Joined Feb 2008
What you could do is charge at a constant current and manually stop the charge when you reach 33Ah. If you can charge at 10A then check the charge amount at the 3 hour point then every few minutes as needed till it reaches 33Ah. Not ideal, but not too bad since you're only going to do this once.
Discussion AH-1 Cobra body for a Trex 450??? jimm1962 Electric Heli Talk 5 Mar 13, 2011 09:41 AM
Discussion Powerlab8 "cell no add up" message mumblety-peg FMA Direct 6 Dec 01, 2010 03:01 PM
Discussion Do Not Balance discharged LiPolys/ PowerLab8 monitoring/Thunder Power PP45 Charge#3 everydayflyer Batteries and Chargers 5 Apr 03, 2010 05:43 PM
Discussion how much time can dc 12v 7 ah charge ? chirnoubil Batteries and Chargers 11 Dec 08, 2008 05:55 PM
Question Discharge by removing specified amount of capacity Andy W Batteries and Chargers 13 Oct 31, 2006 11:36 AM
