Old Aug 20, 2011, 07:49 PM
PittSpecial is offline
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
Originally Posted by dragon444 View Post
I was lucky I had at least 10 high definition videos to analyze my takeoff and landings and I noticed the plane crabbing to the left and to the right on take off which rules out torque. I think the short fuselage is also hypersensitive with rudder.it's been cut back for its next test flight. but the sensitive down elevator after pullout even looked like a glitch. down elevator is now less as well waiting for test flight.
thank you for reading
Please share your videos with us as I am very interested in watching and comparing our results from today!
PittSpecial is offline Find More Posts by PittSpecial
Old Aug 20, 2011, 07:57 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Originally Posted by simano View Post
Overall I'm pleased with the results from this morning.
The plane flies very true and has some heft that helps during breezy conditions.
Some observations:
It tends to pitch down when throttle is increased in flight. Not much but enough to be noticed...
When cutting the throttle it glides very well...
The mtoro is pulling around 30 amps wide open...I'll go with a 9X4.7 next to getthat down some.
Gerry!
I have a Park Zone 480 in my drawer and very good condition and ...
Most importantly a quality E-Flite Park 480 Outrunner Brushless brand new in the box!!!
Motor Kv= 1020
Weight = 3.1oz.
Let me know if you are interested!!!
Old Aug 20, 2011, 08:31 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Update on Alternative Motor / ESC.
My Buddy, Gerry called to say that he appreciated the offer but, that he had a PITTs Special that had the lower 910Kv E-Flite 480 and he was going to remove it from the PITTs along with a 40-AMP ESC because he has not flown nor will he fly the PITTs for sometime.
http://www.horizonhobby.com/Products...rodID=EFLM1500
Also, he told me that he took off the N struts on the SUPER STEARMAN and will provide the same incident angle as that of the bottom wing for the Top wing. He suspects that the Negative incidence is making the model pitch down under high throttle.
More to come!
Carlos
Old Aug 20, 2011, 09:15 PM
wattman is offline
Find More Posts by wattman
wattman's Avatar
Evansville Dress Reg., Indiana, United States
Joined Jun 2004
I am really wondering what PittSpecial will think of flying the PKZ SE5a , because it flys like its fully loaded with fuel , bomb racks full and gun mags full also . Its a heavy plane like the Super Stearman .
I really really like my PKZ SE5a , but it does fly heavy .
wattman is offline Find More Posts by wattman
Old Aug 20, 2011, 10:16 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Really? You don't say?
I have seen the Park Zone S.E.5a fly at my club and can say that it is a very nice scale looks and it was flown scale like.
I am sure that the PARK ZONE S.E.5a does not pull 29 AMPs of Current when trying to fly....correct?
some people..
Old Aug 21, 2011, 06:08 AM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
No Motor Specifications listed for the RIMFIRE!
Guys,
I looked and looked and could not find any listed Motor Parameters for the recommended RIMFIRE motor that Great Planes recommends for this model. As a matter of fact if you look at the RIMFIRE site there is no motor parameters / specifications what so ever in order to estimate how many AMPs it will pull given a certain battery / propeller selection.
Here is the Tower Hobby Page showing the RIMFIRE:
http://www3.towerhobbies.com/cgi-bin...?&I=LXLWU0&P=M
The instruction manual does not show any motor parameters as well except general mounting methods etc...
http://manuals.hobbico.com/gpm/gpmg4590-4655-manual.pdf
Finally, the ELECTRIFLY page also does not have any motor parameters as well:
http://www.electrifly.com/motors/gpmg4505.html
Please, if anyone else has this model and measured the AMP draw assuming using the recommended RIMFIRE motor then, please share with us here....
Seems like the person who had posted earlier in this thread came back and edited his postings for some reason and left the thread?
Old Aug 21, 2011, 06:10 AM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
don't forget to use differential aileron.it makes the airplane more efficient you can use it on everything but especially biplanes
Good luck I'm gone
Yeah okay, so long
Old Aug 21, 2011, 10:14 AM
simano is offline
Find More Posts by simano
Jungmeister 55
simano's Avatar
Orlando Herndon, Florida, United States
Joined Sep 2002
Here are some changes I did on mine:
1) Replaced the motor with an E-Flite 950 KV 480. I had this motor in a retired Pitts Special so no cost added here. It will swing the same APC 10X7 slow flier prop I flew the Pitts with many times.
The current draw won't be more than 18 amps. with this setup and it will fly it with authority.
2) Unscrewed the "N" struts since I noticed they were pulling the top wing down some bowing it and adding unnecessary twist to the outboard section of the wings. I will add a small extension to them to be screwed back to the wings.
3) Added two washers to the two front strut top wing mount to remove the small amount of negative incidence present before.
With the 1500 mah 20 3S1P battery fully forward it balances on the spot recommended.
Will fly again Saturday so, I will report results...
Gerry.
simano is offline Find More Posts by simano
Old Aug 21, 2011, 09:49 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Gerry,
Wonderful news and glad you decided on changing out the motor to a more sensible Kv, lower than 1000 Kv to allow for additional Torque and the prize is that you will be able to use a larger propeller with respectable pitch for good airspeed. Great news on the C-of-G as well.
I believe that the lower Kv E-Flite 480 is rated at 910Kv.
I will be ready and willing to repeat any assistance next weekend!
Carlos
Old Aug 22, 2011, 03:58 PM
simano is offline
Jungmeister 55
simano's Avatar
Joined Sep 2002
Yes it is 910 KV..wow that's even better!!...
Old Aug 22, 2011, 04:00 PM
simano is offline
Jungmeister 55
simano's Avatar
Joined Sep 2002
Carlos, I'm actually considering flying tomorrow morning at Moonport since the forecast for the weekend is...hurricane for this area!!!..
I hope you can join in the morning!!!!
Gerry.
Old Aug 22, 2011, 06:44 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Gerry.
Hi Gerry,
This is to let you know that I received your Voice Mail saying that you are not being to be able to fly on Tuesday morning because of some family matter you need to take care of.
No problem Gerry, I had thought that Saturday would be ideal but, considering the dang Hurricane situation it may need to be before or after I guess.
Let me known if your plans change and can still make it on Tuesday or another day before Friday.
Regards,
Carlos
Old Aug 22, 2011, 07:49 PM
simano is offline
Jungmeister 55
simano's Avatar
Joined Sep 2002
Sure, let's talk about it at work tomorrow skybro...
Old Aug 22, 2011, 08:32 PM
bfaulguy is offline
Find More Posts by bfaulguy
United States, NJ
Joined Apr 2001
I was excited to see this at first, until I saw it was made of wood and not EPO.
bfaulguy is offline Find More Posts by bfaulguy
Old Aug 22, 2011, 08:46 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
It be hard pressed to find a Great Planes made of EPO Foam except just recently they did come out with this one made of foam and it supposed to be a mild Sport RC Airplane Flyer (Super Sportster): CHECK OUT THE VIDEO!!!
http://www3.towerhobbies.com/cgi-bin...&I=LXAVPG&P=ML
or
http://www.electrifly.com/largeelectrics/gpma6006.html
For Sale Midwest Super Stearman kit NIB 3dcraz Aircraft - Fuel - Airplanes (FS/W) 5 Jul 11, 2012 07:13 PM
Wanted Need GP Super Stearman Landing Gear Howard L Aircraft - Fuel - Airplanes (FS/W) 0 Mar 03, 2011 02:46 PM
For Sale Kyosho Super Stearman OS46AX, Brandie new motor Pilot44 Aircraft - Fuel - Airplanes (FS/W) 3 Jan 25, 2006 01:48 PM
For Sale Great Planes Super Stearman RTF "NEW" Rick Poire Aircraft - Fuel - Airplanes (FS/W) 0 Jun 29, 2005 02:28 PM
Great Planes Super Stearman RTF New Rick Poire Aircraft - Fuel - Airplanes (FS/W) 0 Apr 07, 2005 03:37 PM
