Old Jun 12, 2011, 08:19 AM
Schrott is offline
Find More Posts by Schrott
Dolores, Colorado
Joined Dec 2007
sure you can steam it, water it etc. but what than, since it is a flat deck you have no way to klamp it or what ever to keep the desired shape till it is dry and can be glued down
Schrott is offline Find More Posts by Schrott
Reply With Quote  (Disabled)
Old Jun 12, 2011, 10:18 AM
obses4sail is offline
Find More Posts by obses4sail
obses4sail's Avatar
Visalia, CA
Joined Sep 2010
Clamp to a form until dry, won't be perfit, but closer to shape.
obses4sail is offline Find More Posts by obses4sail
Old Jun 13, 2011, 08:23 AM
Schrott is offline
Dolores, Colorado
Joined Dec 2007
hihihihi, the bent is minimal, just 2 or 3 mm, close to shape is as bad as straight, Wallnut is such a hard wood that if it does not fit perfectly, you will breake your fingers to make it fit, especialy since those planks are just 20cm long.
One other thing that I thought was interesting, the Gorilla Superglue desolves the material of the hull and it takes about a minute for the glue and the plastic to cure.
The birds eye is very hard,too. But now with the outer plank on I got something to push and clamp against, makes live so much easier.
Old Jun 24, 2011, 08:26 AM
Schrott is offline
Dolores, Colorado
Joined Dec 2007
I made some further progress on the deck planking, it is slow and tedious.
Old Jun 24, 2011, 06:50 PM
Pilatuspc12 is offline
Find More Posts by Pilatuspc12
Onward and upward.
Pilatuspc12's Avatar
United States, CO, Delta
Joined Oct 2006
That looks good.
Pilatuspc12 is offline Find More Posts by Pilatuspc12
Old Jul 20, 2011, 08:54 AM
Schrott is offline
Dolores, Colorado
Joined Dec 2007
some more progress with the deck 75% done.
Old Aug 07, 2011, 09:25 AM
Schrott is offline
Dolores, Colorado
Joined Dec 2007
It took a while, but finally I got the deck planked.
That birds eye stuff is hard to work with, but I am pleased with the result.
I sanded it first with 80, than 120 and last 240.
Next it will get one thin coat of varnish to protect it.
Than it will be time to finish the hull outside.
I ordert my masts from Ludwigs. They should be here some times next week.
And I ordert a bunch of winches, graupner winches, through a friend in Germany.
Old Aug 07, 2011, 09:45 PM
Schrott is offline
Dolores, Colorado
Joined Dec 2007
As expected, the first round of poli braught the grain of the woood out.
This is just a protectif, so the wood will not get soiled, when I finish the hull.
Old Aug 09, 2011, 01:00 PM
Onward and upward.
Joined Oct 2006
Wow,
that looks good, Guenther! I have to order some planking for my new boat.
Randy
Old Aug 09, 2011, 02:23 PM
Schrott is offline
Dolores, Colorado
Joined Dec 2007
How is your leg coming along Randy ?
Old Aug 09, 2011, 05:42 PM
Ed Crowell is offline
Find More Posts by Ed Crowell
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
The deck looks great. One of these days I will build a sailboat with a planked deck.
Ed
Ed Crowell is offline Find More Posts by Ed Crowell
Old Aug 10, 2011, 10:21 PM
Schrott is offline
Dolores, Colorado
Joined Dec 2007
Ed a wood deck is very rewarding, but it takes patience.
If you do it the first time use a wood that is easy to work, mahogany, maybe, its low tar, hard, but not to hard, or curly Maple, very beautifull wood and easy to work with.
Teak is a high tar would, it feels kinde waxy, beautifull, but if you steam it, the wax goes an it becomes brittle. Hard to glue to because of the tar.
The wood I used is a pain in the ....
It is extremly hard, especialy the birds eye, it breaks like glass if you cut it at the wrong spot, around the eyes it is realy britle and hard and in between softer like the curly.
It is a realy tough wood to work with.
If you finally get it done, it is a highly rewarding result.
I sanded the deck off again and tomorow morning, when it is cool I will give it one more coat.
And than it will be the hull.
Waiting for the masts.
Friday morning I will go to the lake, and sail the Fat Lady.
Old Aug 11, 2011, 12:00 PM
Onward and upward.
Joined Oct 2006
Good, I can hobble down to the basement now. Your deck looks beautiful. I think I'll use mahogany for the deck on my Canterbury J boat since it would be easier to install.
Old Aug 11, 2011, 11:23 PM
Schrott is offline
Dolores, Colorado
Joined Dec 2007
I am surprised your BOSS did not put you in the basement.
But good to hear your leg is coming along.
Have you started on your boat ?
Old Aug 12, 2011, 11:56 AM
Onward and upward.
Joined Oct 2006
Not yet, I have to wait for my stuff. I just got the sails today.
For Sale World Models Vodoo P51 Mustang bolarobric Aircraft - Electric - Airplanes (FS/W) 7 Nov 23, 2007 04:29 AM
Discussion The Top 6 Signs Your Child's Teacher Is Experiencing Burnout Don Sims Humor 0 May 27, 2003 04:50 PM
Strobe Lights from Child's Rubber Ball? Ray Manhart Parkflyers 3 Aug 22, 2002 07:46 PM
