Old Aug 14, 2003, 05:55 PM
RCZohn is offline
Find More Posts by RCZohn
razor burn can be good
RCZohn's Avatar
aurora illinois
Joined Aug 2002
wing-e ready to cover>any mods b4 i do?
hi guys,
i'm ready to cover my wing-e but am wondering if there are any helpful modifications i should perform before i cover it
also wondering if wing e flyers are glueing or taping the winglets on or both?
anyone running lipo's in their wing-e?
if so what prop and gearing should i run on 2s pack?
thanks guys,
John
RCZohn is offline Find More Posts by RCZohn
Old Aug 14, 2003, 07:23 PM
10Thumbs is offline
Find More Posts by 10Thumbs
Motor Maniac
Orange County, CA
Joined Feb 2002
Build it stock. The only suggestion is in the prop, go with a 7x6 or 8x6 prop, not the 7x4. The 7x4 is just adequate and I wasn't happy with it. I've run NiMH and LiPo's (etec 700 2S), both work well, but the LiPo's have to be real close to the spur gear to get the CG right.
I used magnets to attach my winglets. I think Tres originated that. BEC uses a nylon bolt to attach his. I wouldn't use tape if I were you, it can be a real pain to get off the Solite when you need to remove it.
10Thumbs is offline Find More Posts by 10Thumbs
Old Aug 14, 2003, 09:49 PM
STL.SF is offline
Find More Posts by STL.SF
St Charles Flyer
St Charles, IL
Joined Sep 2002
Well I've just passed about 20 flights with my Wing-E. It is a good thing that is is a lot tougher than I ever expected. It had some rough times returning to Mother Earth when I first started out. I glued the winglets on and have never had them damaged in a crash. I was going to use magnets but getting into the air was more pressing.
My major problem was breaking the motor mounts. I've done about 3 repairs and 2 replacements. The last (and still holding) is where I replaced the balsa center with an equal amount of light plywood. I don't expect this to break.
I too run the 8x6 prop. I'm running the 370 maH NiMH and am planning on changing to the lipo's as I get about 5 min flights, too short.
Next step will make it come alive with a PJS300 brushless. I've seen that combination fly and it really works.
STL
STL.SF is offline Find More Posts by STL.SF
Old Aug 14, 2003, 10:34 PM
RCZohn is offline
RCZohn's Avatar
aurora illinois
Joined Aug 2002
thanks for the info guys
this forum is indespensible
Old Aug 15, 2003, 12:25 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
I put my winglets on with two 4-40 nylon screws each. Makes 'em easy to remove (though not as easy as with magnets) for packing flat. If you search the forum you might find a picture or two of that mod.
The only mods I would really recommend before covering are:
A little reinforcement of the elevons where the control horns go through. If I were to do another I'd cut some 1/2 inch or so triangles from 1/64 ply, drill 1/16 holes in the middle of them then put them over the holes whre the control horns go through.
Put one or two 1/4 inch wide strips of scrap across the top of the battery tray to act as braces (since the grain is going the wrong way on that part for best squeez/flex strength). These have to be far enough aft so as to not prevent the gearbox from going on the mount stick.
I fly mine with LiPolys exclusively now. On the PJS-300 powered one I use a two-cell pack of Etec 700s and the APC 7X6 SF. On the one that has a GWS drive the Kokam 1020s or ETec 1200s work well (though the 700s should be fine, too). Again, 7X5 or 7X6SF prop.
It's just that neither the 7X5SF or 7X6SF existed when the Wing-E was designed a year and a half ago.
On reinforcing the motor mount "stick": after Todd broke my PJS-300 powered one trying to hand catch it (!!) he suggested drilling through the center front to back and putting in a length of 0.080 carbon rod to reinforce the repair I had to do. Boy is it strong now! A 3/32 drill bit is close enough.
BEC is offline Find More Posts by BEC
Switchback any mods i should do? frmotorsports Parkflyers 16 Feb 17, 2005 10:18 AM
Help! Ready to cover wing, but concerned it's too flimsy. Thoughts? hifi heretic Electric Plane Talk 8 Dec 21, 2004 12:24 PM
Any1 make any mods on the GWS E-Starter Insaneflier Foamies (Kits) 0 Sep 21, 2003 09:35 PM
How to "Re-Cover" Wing-E Manchild Parkflyers 0 Nov 04, 2002 10:24 AM
