Old Apr 11, 2011, 01:42 PM
diekmann is offline
Find More Posts by diekmann
high on flying since 2009
diekmann's Avatar
United States, MN, Barry
Joined Jul 2010
3s motor on 4s?
so here i have a graysonhobby 2217-06. http://www.graysonhobby.com/catalog/...ies-p-337.html it spins a 8x4 prop at 225w according to the specs. i like it on 3s but i think i'm going to upgrade. a bit more speed and trust is in mind, but without getting a new motor. so the product page says it can handle 4s but what prop will i have to use for best performance and how big of an esc will i need? thanks for the help peeps
-Diekmann-
diekmann is offline Find More Posts by diekmann
Old Apr 11, 2011, 02:08 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
a bit more speed and thrust is in mind, but without getting a new motor.
The Holy Grail.... something for nothing!
The 2217/6 is an excellent motor, but getting more speed AND more thrust means pushing a LOT more power into it.
To keep the amp/watts within sensible limits on 4s, you will need to drop down to a 6" prop (a 7x5 APC E draws almost exactly the same as an 8x4 GWS HD... so on 4s either will be too much for it).
It might cope with 250W-275W (20A on 4s?)... but I wouldn't like to see it pushed much more.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Apr 11, 2011, 02:12 PM
diekmann is offline
diekmann's Avatar
Joined Jul 2010
so the 6x4 apc i have for my microjet would do it on a 4s? only 20 amps too? hmmmm how about same speed but more thrust?
Old Apr 11, 2011, 04:24 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
For that you'd need larger diameter but less pitch (?7x3).
But I can't be sure that would get you any more thrust than an 8x4 on 3s.
Old Apr 11, 2011, 06:41 PM
Lardog is online now
Find More Posts by Lardog
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
I'd recommend keeping it on 3s and just changing the prop. Not sure what you are running that motor on, but I use it on Alfas with an 8x6 at around 450W and they flat out haul. It also will take a World Models Mini Midget Mustang beyond 100 mph.
Lardog is online now Find More Posts by Lardog
Old Apr 11, 2011, 08:36 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
What sort of 8x6 is that? I ran my A2217K-6T test motor with an amp hungry 8x8 APC E and at 11.2v still only drew 36.7A/397W.....I cannot see how, with just an 8x6, you are getting over 40A/450W?????
Old Apr 11, 2011, 09:36 PM
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
Just a normal APC E. I have the BP hobbies 2217-6 1500Kv, which is the same Suppo motor Grayson is selling. My #s are mostly consistent with what others at my field are getting as well.
http://www.rcgroups.com/forums/showp...71&postcount=3
My recorded numbers are attatched...
Old Apr 12, 2011, 10:53 PM
diekmann is offline
diekmann's Avatar
Joined Jul 2010
so would i get similar numbers with the thin electric 8x6? i can get a normal 9x6 and trim it down to 8x6 normal i spose but it'd be easier to just get the 8x6 thin. just gotta be sure i'd get the same performance
thanks
-Diekmann-
Old Apr 12, 2011, 11:16 PM
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
Definitely be easier to just buy an 8x6. Way too much hassle to cut and balance another prop. I'm guessing your LHS has them in stock.
And yes, I expect you would get similar results. Of course, your choice in battery will have an affect. As you can see, mine aren't the best.
Old Apr 12, 2011, 11:26 PM
diekmann is offline
diekmann's Avatar
Joined Jul 2010
i don't have a LHS, i live in the middle of absolute nowhere, my LHS is a almost 2 hr drive only complaint about where i live, plenty of space to fly tho i mostly order online,
lardog does your motor get hot with the 8x6? cause i wonder if i could thrown in a 8x7 in there and see if i be conservative maybe pull off even speedier? when i run it with the 8x4 it's almost colder than when it started so no probs with that prop
Old Apr 13, 2011, 03:39 AM
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
I'm sure mine doesn't get hot, but it's also hanging out in the wind. I don't think I'd want to go beyond the 8x6 though. You are already pushing a 250W motor beyond 400W.
Old Apr 13, 2011, 11:15 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
That BP version must be a bit higher Kv than the one I tested:
Old Apr 13, 2011, 11:21 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
thanks
-Diekmann-
The only 8x6 APC E prop is a thin electric.
There are 8x6 APC SF, 8x6 APC Sport... and maybe 8x6 APC Pylon... but there's only the one E -type.
Old Apr 13, 2011, 11:47 PM
diekmann is offline
diekmann's Avatar
Joined Jul 2010
ahh i see, and i understand the part about not pushing it that much, do you seriously get 100mph on your midget mustang though? i have a scratchbuilt wing that i'm putting it on so the motor is right out in the wind and it's a low drag airframe, i wonder if i could get some decent speed oh and what is the C discharge rating on your batteries?
thanks
-Diekmann-
Old Apr 13, 2011, 11:49 PM
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
Oh yeah!
Check em out...
http://www.planeadrenalinrc.com/Speed_Shop.php
Found Looking for Turnigy 3s and 4s 4000mAh! Rookie2008 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Mar 25, 2011 09:07 AM
Sold Lot of Lipo 6s,4s,3s,2s c2nv Aircraft - Electric - Batteries & Chargers (FS/W) 5 Mar 22, 2011 03:21 PM
For Sale 3S & 4S batteries Flying glass Aircraft - Electric - Batteries & Chargers (FS/W) 3 Mar 10, 2011 11:21 AM
Discussion Micro T stabilization: 3S/4S Low Cog Mount and Front Stabilizer Bar Mod EQMOD Micro Cars 2 Mar 07, 2011 08:54 PM
Discussion 4s on a 2-3s motor bob_loblaw Electric Plane Talk 8 Feb 13, 2010 10:45 AM
