Old Apr 10, 2011, 06:04 PM
justlarry2010 is offline
Find More Posts by justlarry2010
Joined Apr 2011
turnigy 9x v tail and elevon settings
Hi folks,
I am new to this site and thought it would be a good place to get some help. I have the turnigy 9x v2. As you have probably heard the manual sucks! It tells you what things are for but not how to use them. I have been trying to set up a delta with elevons and a v tail glider. both use 2 servos. I am at the point of pulling my hair out, but I don't have that much to begin with! I have the radio already set up for my boom 3d and it is working great. Have improved my flying greatly compared to using my older radios.
I would really appreciate any detailed info to set these aircraft up. I am assuming the radio is working ok. I have even considered adding a electronic mixer from turnigy to keep me from going insane.
PLEASE HELP, Larry
justlarry2010 is offline Find More Posts by justlarry2010
Old Apr 10, 2011, 07:40 PM
John Kim is offline
Find More Posts by John Kim
Panorama City, CA
Joined Sep 2004
Did you reach V-tail program? Then enter value for each tail.
You must remember to press Menue key momentarily to memorize value entered. This is unique feature of 9X. If you fail this procedure, no value will be stored and program will not work.
Same for elevon.
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Old Apr 18, 2011, 05:17 PM
Joined Apr 2011
thanks that really helped.
Old Aug 25, 2011, 06:46 AM
Skypodx is offline
Find More Posts by Skypodx
Joined Apr 2011
Im running mode 2 setup. Which ports do I connect my two aileron servos to?
Skypodx is offline Find More Posts by Skypodx
Old Aug 25, 2011, 01:20 PM
John Kim is offline
Panorama City, CA
Joined Sep 2004
Two aileron servos on left and right wing are connected to ch1 and ch6.
Then, activate flaperon program and enter proper value for each servo.
Value can be either positive or negative value depending on direction you desire.
Old Aug 25, 2011, 04:10 PM
Skypodx is offline
Joined Apr 2011
Thanks for the fast reply How is this combined with v-tail programming? Does the servos still connect to channel 1 and 6? I have a Jet with two servos. One for each ailerom.
Old Aug 26, 2011, 03:37 PM
John Kim is offline
Panorama City, CA
Joined Sep 2004
V-tail servos are connected to ch4 rudder and ch2 elevator.
Then, activate V-tail program and enter proper value for each servo. Direction of servo depends on postive or negative values. Be sure to press Menue button before exiting V-tail program window. If not,
values entered will not be memorized and program will not start. You need do it over.
Old Aug 27, 2011, 04:43 PM
Skypodx is offline
Joined Apr 2011
Thanks! That really helped me out
Old Oct 26, 2011, 07:59 PM
vdubbub86 is offline
Find More Posts by vdubbub86
Joined Oct 2011
Hello, I had something else to add.. how do you set up an elevator when u have v-tails activated? ??
vdubbub86 is offline Find More Posts by vdubbub86
Old Oct 27, 2011, 11:58 AM
John Kim is offline
Panorama City, CA
Joined Sep 2004
V-tail functions both as rudder and elevator. Elevator function is already incorporated in V-tail program.
In V-tail mode, both tail pieces will move in same direction, up and down, when you move elevator stick.
When you move rudder stick, two tail pieces will move in opposite direction, left and right.
Old Oct 27, 2011, 02:02 PM
Joined Oct 2011
So am I suppose to use Y connectors off of channel 2 and 4??
Old Oct 27, 2011, 03:06 PM
PaulB is offline
Find More Posts by PaulB
Mike's Ma Maaaaaaaaan
Paderborn DE
No, each tail plane has 1 servo connected to it. Move the elevator stick and they move together, move the rudder stick and they move in opposite directions.
PaulB is offline Find More Posts by PaulB
Old Oct 27, 2011, 03:42 PM
Joined Oct 2011
http://www.youtube.com/watch?feature...&v=HDcJijeHG2k
This here is what I want to do...
Sold 2 HK 8-10A ESC, 2 Turnigy C1818 motors, Gws V-tail SlowBro Aircraft - Electric - Power Systems (FS/W) 8 Mar 31, 2011 04:34 PM
Discussion TEST: Turnigy Nanotechs v Turnigy Std. v LM Tipples Wayne Giles Batteries and Chargers 44 Mar 22, 2011 02:05 AM
Discussion Turnigy 9x Copter 450x settings? roundthebend Radios 9 Dec 09, 2010 12:05 PM
Question How to program the Turnigy 9X settings for a specific model? djacob7 Radios 1 Sep 05, 2010 07:26 AM
Help! Turnigy 9x settings IGnition Radios 3 Jul 16, 2009 05:55 PM
