OK, got over the frustration and continued the build. Got all the servos (except steering) in place and connected. Finally got the courage to open up a front battery hatch. Considering the retracted nose wheel, and the relatively narrow fuse, it will only fit one 6S battery there. I plan on putting two 6S 8000mAh batteries, one in the front hatch, and one right behind it, upright, in the compartment in front of the wing.
The trick to open the hatch--I connected the Dremel 225 extension shaft (easier to navigate) and drilled small holes from the INSIDE of the plane right near the formers. Then, I "connected the dots" with a disk. Pretty accurate... I replaced the flimsy wing mounting screws provided with the kit with strong, stainless steel screws.
Joined Jan 2009
Sorry I didn't reply sooner...I'm subscribed to this thread but maybe the notifications went in my junk mail! |
Joined Aug 2009
Hi all,
sorry for not responding for a while... Luckily I found some free time to do another few little things on my Tigercat: 1. Cut off the excessive fiberglass edges from the cowlings (will paint the inside in a gray color later on) Looking better now ? Yes, much better ! 2. Worked on the wing's connection to the fuselage. I am going to use 4 screws (M4x55 on the back, M4x75 front) and drilled the holes. To prevent the wings structure beeing bruised while tightening the screws I inserted some small brass tubes and glued them into the holes by CA. 3. Made some small plywood boards to reinforce the screws contact face. Now that's all for the moment. Hoping to make further progress soon... Regards Robert |
Joined Jan 2009
Hi All
I'm very happy this thread has resumed. I've just started to build one of these (the shiny one). Before I start a build I like to walk through the entire manual and mentally relate the instruction steps to the actual parts. This also gives me a chance to inspect everything. One question is, where do all the wing servo extensions and main retract wires (using electric retracts) route into the fuse? I don't see any covered openings for cut out on the underside of the main wing panel as I would expect. Am I being completely dense here, or do I just need to read more carefully. I have to say, I've built quite a few large ARFS (top flite, hangar 9, black horse) and I think these are the worst instructions I've ever seen for a model this involved. Very terse.. I'll post pictures once I make some progress. Thanks |
Easiest method for cables is to have them exit the top surface of the wing. That way, you can bolt the wing to the fuse and THEN connect everything up via the opening at the rear of the wing saddle. No need to worry about making connections while balancing a heavy wing, and trying to tuck everything in before bolting down.
| Thread Tools | |
| Discussion Grumman F7F Tigercat (RBC kit) Build | chinehamgeorge | Electric Warbirds | 30 | Aug 10, 2011 07:30 AM |
| For Sale Big F7F tigercat - ESM WARBIRDS | benjo | Aircraft - Fuel - Airplanes (FS/W) | 0 | Aug 23, 2010 04:32 AM |
| Discussion F7F Tigercat Build | J Morgan | Electric Warbirds | 66 | Sep 11, 2009 08:59 AM |
| Build Log B-25 Mitchell & F7F Tigercat Build | philip noel | Scale Electric Planes | 163 | Apr 09, 2008 06:56 AM |
| Bluecore F7F Tigercat Ready to fly!!! | Bsouthwell | Foamies (Kits) | 20 | Jun 30, 2002 02:52 AM |
