Old Jan 08, 2013, 08:35 PM
ysolomon is offline
Find More Posts by ysolomon
Another one on the way...
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
I'll tell you what, $319 for a tricycle retract for a 30lb plane including the struts and wheels is not bad at all...
ysolomon is offline Find More Posts by ysolomon
Old Jan 08, 2013, 08:57 PM
Dangaras is offline
Find More Posts by Dangaras
Dont be divided from the truth
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
Oh yeah! Specially with the wierd geometry...
Dangaras is offline Find More Posts by Dangaras
Old Jan 08, 2013, 09:03 PM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
See? Now you made me raise the F7F higher on my list of "to finish building..."
Old Jan 08, 2013, 09:06 PM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
Ha ha ha.... The only thing stopping me is my delivery is late...
Old Jan 15, 2013, 11:01 AM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
My Tigercat arrived and the only issue was the cheap Chinese masking tape holding the fuse parts ha lost its tack and allowed the nose door to slide around scratching the finish a bit, easy to fix. However, there was a ding in the fuse which looked like a hard hit that cracked through the glass skin finish and exposed the inner glass coat.
I contacted TBM and they were on it right away, amazing service! The scratches are easy to fix with some spit but the ding will take some work & here is my effort so far..
It took about three hours and some supplies from my LHS.
I got some light fiberglass cloth, 30 minute epoxy and paint. The big issue was the paint, I had to get Tamiya sea blue and Model Master gun metal but neither is a good match. Do you guys have any suggestions?
Looking at the outside of the fuse you can see the stress cracks radiating from the hole so I suspect it got hit hard right at that point some time during its life. I glass & epoxied the inside and used epoxy to fill the missing shell on the outside. Once he epoxy hardened it is sanded away to leave only epoxy in the crack area.
If you look at the pictures you can see the cracks and the poor colour match (kind of a green hue). Let me know if you guys have a better colour match.
Old Jan 15, 2013, 12:26 PM
egras14 is offline
Find More Posts by egras14
Pompano Hill Flyer
egras14's Avatar
United States, FL, Fort Lauderdale
Joined Apr 2003
If you have any small parts with those colors take them to Home Depot or Lowes paint dept. and ask them to match them for you. It will cost you about $8.00 for both samples.
Amos
egras14 is offline Find More Posts by egras14
Old Jan 15, 2013, 12:40 PM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
I have tried that in the past but never got a close enough match to be happy. Maybe this matte finish might be closer.....
Old Jan 26, 2013, 02:55 PM
Eddie P is offline
Find More Posts by Eddie P
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
Guys, those of you who have finished one of these - what sort of build time have you guys put into these? Is there a lot of engineering left to do?
Eddie P is offline Find More Posts by Eddie P
Old Jan 29, 2013, 01:36 PM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
Motor mount standoff dimension?
Earlier you posted that you used 40mm spacers to mount the motors. Was that dimension based on the back plate of the prop mount clearing the front of the cowl & by how much?
Thanx..
Old Jan 30, 2013, 01:57 AM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
It was, but I don't remember by how much...
Old Jan 30, 2013, 07:35 AM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
Ok, thanks..
Old Feb 14, 2013, 09:59 AM
mirored is offline
Find More Posts by mirored
Build, Fly, Maintain, Repeat..
mirored's Avatar
United States, VA, Chesapeake
Joined Nov 2008
I just ordered a shiny version and will be at my place next week. I am using this as a stepping stone to my other project I have on the boards, a Don Smith B24, 146" wingspan scratch built. It uses four DLE20 engines and all of the same servos. I will be continuing the break in of the four engines on this place while practicing and perfecting multi engine flying in preparation for the bomber maiden, probably sometime next year. This will be a very nice plane to do the testing, I really like the looks of it. Unfortunately it will take the front seat on building and move the bomber aside for a little while but I expect the assembly of this one to only take a week or two. Thanks for the thread here and all the information provided.
mirored is offline Find More Posts by mirored
Old Mar 14, 2013, 09:01 AM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
Any progress? Mine is still in the queue. All the parts are here but I have to get the other builds completed first. No room for multiple builds.
Old Mar 14, 2013, 10:46 PM
ysolomon is offline
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Neah... Started on a seagull T-6AM texan II and still working on the L39 for now. I believe I can get those two will fly this year.
Old Jun 04, 2013, 10:01 AM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
I have been steadily assembling my Tigercat and there are some serious issues with the fit..
The nacelles are an issue, the main tube was not aligned either in the main wing or the nacelles whichever it was, the nacelles would not sit flat against the inner main wing so there was lots of sanding and cursing and swearing.
I will have to paint the nacelles after I fill the joint and sand it smooth..
The horizontal stabs are the same issue, they don't sit flat against the fuse & needed severe attention... Moe filling & sanding & painting..
The M3 * 50mm screws used in the control horn assemblies are missing. I had to go get a whole set of extra strong horns, more hassles..
I am still undecided about the batteries, I am using 4 5 cell, 4000s 2 in series then those in parallel to make a 10 cell 8000 pack. Figuring out the CG and battery placement will be the next trick..
To their credit, the guys at TroyBuilt have been trying their best to help with solutions..
For Sale Big F7F tigercat - ESM WARBIRDS benjo Aircraft - Fuel - Airplanes (FS/W) 1 Mar 27, 2014 04:33 PM
Discussion Grumman F7F Tigercat (RBC kit) Build chinehamgeorge Electric Warbirds 30 Aug 10, 2011 07:30 AM
Discussion F7F Tigercat Build J Morgan Electric Warbirds 66 Sep 11, 2009 08:59 AM
Build Log B-25 Mitchell & F7F Tigercat Build philip noel Scale Kit/Scratch Built 163 Apr 09, 2008 06:56 AM
Bluecore F7F Tigercat Ready to fly!!! Bsouthwell Foamies (Kits) 20 Jun 30, 2002 02:52 AM
