Old Apr 09, 2011, 02:28 PM
leadfeather is offline
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Contest
Mr. Lifter 2011; Walter Lafouine takes over heaviest lift!! .
Who's got the best copter? It really depends on what you consider the best.
Post your copter, it's performance for one or more of the categories below and the equipment you used and any other interesting details.
Also post your ideas for other categories.
Current top designs in each category below get bragging rights as well the right to the name Mr. Lifter.
Ia Mr. Lifter - Heavy Lifter, greatest payload including battery, dead man lift style, must clear at least 6 feet for at least 10 seconds with video.
1) Walter Lafouine's heavy lifting hexa copter, 12.1 kg!!
2) Killy's big hexa 7.81 kg!!
3) pipercubdude's quad 5.45 kg payload
4) Killy's quad lifting 4.69 kg
5) Redfox74's Y-6 lifting 3 kg
6) Warthox's Y6 lifting 2.32 kg
7) Tretch5000's Y6 lifting 1.886 kg
8) Warthox's hexa lifting other multicopters, 1.675 kg
9) Wayne Young's quad lifting 1.45 kg
Ib Mr. Lifter - Controlled Heavy Lifter, greatest payload including battery with a flying task. Task is 2 minutes of flying showing controlled flight. Demonstrate controlled forward and reverse flight, 360 degree turn left and right turn (pirouettes or circuits) at any point in the flight.
1) Killy's hexa does a flip while weighted with 5.29 kg!!
2) Warthox's Y6 lifting 2.32 kg
3) Jag Svensonn's quad with 1.7 kg payload
4) Warthox's hexa lifting other copters 1.675 kg
5) Warthox's quad lifting "idodized" salt. 1.239 kg
6) Wayne Young's quad lifting 1.225 kg
II Mr. Lifter - All Out Time Duration, longest time in a single flight. Video not required (but is OK), but at least an in flight photo and detailed description required to verify duration claim.
1) timnilson's tricopter, 28 min 30 sec
2) Tretch5000's Tricopter, 23 min 35 sec
3) Captaingeek's quad 10 min
4)
III Mr. Lifter - Most Efficient Duration , highest time in seconds divide by (Ah x number of cells) of your battery. Video not required (but is OK), but at least an in flight photo and detailed description required to verify duration claim. The larger this number is the better.
1) ben123's micro hexa 712.5 sec per Ah x #cell
2) Tretch5000's micro quad 472.3 sec per Ah x #cell
3)
Tretch5000's tricopter, 1415 sec / (2.500) Ah x 3s = 188.67
4)
IV Mr. Lifter - Most Weight Efficient, payload weight divide by copter weight, payload includes batteries.
1) Killy's quad , 4.1875:1
2) Walter Lafouine's strong hexa, 3.457:1
3) Killy's big hexa, 3.3234:1
4) pipercubdude's quad 2.4:1
5) Tretch5000's tricopter 1.9195
6) Warthox's Y6 lifting 1.7536
7) midnight999's hex 1.325:1
8) Wayne Young's quad 1.18:1
V Mr. Lifter - Most Durable, need video demonstrating durability
1) Tretch5000's tricopter
2) n3m1s1s's quad
3) Warthox's early quad
4) Killy's heavily loaded hex
VI a Mr. Lifter - Largest Copter by all up weight.
1) spitfire_Doug's 5 kg Tricopter
2) Eddie Weeks amazing 4.028 kg VTOL
3) Jago Svensonn's 3.0 kg Camera Quad
4) Pragamichele's really big tricopter, 1.52 kg
VI b Mr. Lifter - Largest Copter, by size, largest dimension between any two motor shafts.
1) Pragamichele's giant tricopter, 3.55 meters or 140"
2) pug398's 53.5" Quad
3) motorhead's Tricopter 41.5" between motor shafts.
4) Killy's big hexa 85 cm (33.5")
VII Mr. Lifter - Smallest Copter, lightest weight including battery.
1) ben123's little hexa; wow six motors and only 50 grams AUW!
2) JaggerMD's cool little quad 138 g
3) Tretch5000's Depron quad 148 g
4) 4) Kristjanes little quad, 196.5 g
5) nasgul's nice looking quad 257 grams
6) n3m1s1s very nice looking quad 285.1 g
7) Tretch5000's tricopter 236 g + battery
V111 Mr/. Lifter - Best Video , impressive, crazy, cool, funny who's got the best footage? Must be your own video, not something you found on youtube and must be about lifting. In order posted.
1) Pipercubdude's video of his quad lifting a Super Chipmunk, awesome!
2) n3m1s1's backyard flying with on board camera inset into the video
3) Jago Svensson's aerobatic water glass carrying video
4) n3m1s1s flying at the beach and night flying
5) Tretch5000's amazing tricks with his quad
6) Warthox's copter lifting copter video
7) Killy's hexa rolling with payload
8) pragamichele's quad flipping low to the ground; he's holding his Tx behind his back.
9) Rctestflight's quad pulling him on a skateboard
leadfeather is offline Find More Posts by leadfeather
Old Apr 09, 2011, 02:29 PM
Winging it >
Joined May 2006
Here is an example of an entry.
Tricopter weight = 380 grams
Max payload including battery = 386 grams
lift efficiency = 386/380 = 1.016
Duration 9min 11 sec, battery size 1100mAh 3s
Duration Efficiency = 551 sec / (1.1 Ah x 3s) = 167 sec per hA x s
Motors Turnigy 2730-1500
esc's Mystery 12A
GWS 8043 prop
Wii controls
little Tricopter lifting.wmv (3 min 11 sec)
Old Apr 09, 2011, 02:47 PM
milo12 is offline
Find More Posts by milo12
Joined Feb 2011
I'm all for some fun contests. To keep things real I think there needs to be rules associated with the heavy lift. It is easy to bounce an unflyable payload in the air for a few seconds. I think some kind of duration or distance needs to be defined before a lift is considered real. This will demonstrate full control of the vehicle and payload. Obviously some sort of video is needed for verification.
milo12 is offline Find More Posts by milo12
Old Apr 09, 2011, 02:59 PM
Woodchuck12 is offline
Find More Posts by Woodchuck12
What? I was too busy flying...
Woodchuck12's Avatar
Joined Jan 2011
For the lifts I think it would work to have a lift/ weight ratio. So if your copter weighs a pound/kilogram/grams, put that in a ratio with how much it lifts. I.E. the copter weighs 1 pound. It lifts 2 pounds. So the ratio would be 1:1.
Woodchuck12 is offline Find More Posts by Woodchuck12
Old Apr 09, 2011, 03:04 PM
Winging it >
Joined May 2006
Already got it...4th category.
Old Apr 09, 2011, 03:05 PM
Winging it >
Joined May 2006
Good point. How about a minimum duration of 30 seconds, payload and copter to stay above 6 feet for the duration.
Old Apr 09, 2011, 10:34 PM
jtprouty is offline
Find More Posts by jtprouty
Inherent Tinkerer
Wichita, Kansas, USA
Joined Jul 2003
Now it HAVE to fix my Quad!!!!
Jimmy
jtprouty is offline Find More Posts by jtprouty
Old Apr 10, 2011, 07:35 AM
Winging it >
Joined May 2006
Jimmy
Did you have a choice anyway?
Also, for this competition, anyone can make new entry's as often as they like. Made a new copter or improved on an existing entry...please feel free to post again.
I'm looking forward to seeing lots of different designs and also I'm looking forward to seeing if there are any trends that distinguish the winners.
For example, I have done some bench top testing on motors and props. One trend I have seen is that a lower kV motor when matched well with a propeller in general will require less power for the same thrust. At the same time, it seemed that the maximum thrust did not always get better with lower kV. Now I'd like to see if the bench testing has any bearing on what works in actual flight.
Old Apr 10, 2011, 07:50 AM
liteglow is offline
Find More Posts by liteglow
Joined May 2005
hmmm...
Guess 10-12kg is no problem.
But to risk all 4 of my batteries in one 30second try..... dont think so !
The such of AMP is so high that I fear the battery will suffer from this.
why not 10second and not 30 ?
liteglow is offline Find More Posts by liteglow
Old Apr 10, 2011, 07:55 AM
Winging it >
Joined May 2006
Originally Posted by liteglow View Post
hmmm...
10-12 kG would be very impressive.
OK, let's try 10 seconds to protect the equipment. I'll modify the first post.
Old Apr 10, 2011, 10:36 AM
liteglow is offline
Joined May 2005
Sorry I maybe got something wrong here
10-12kg is included the copter (3.4kg)
So I will try to lift 6-8kg payload
Dont know if it`s possible.
But last time I did the test I`m sure I got some more throttle to give.
The problem with FY90Q is that, after you reach full throttle, there is NO auto stabilization left !!!
Old Apr 10, 2011, 02:49 PM
pipercubdude is offline
Find More Posts by pipercubdude
Joined Jan 2010
im going to be shooting for the first category MR heavy lifter as soon as i get things squared away with the new frame
pipercubdude is offline Find More Posts by pipercubdude
Old Apr 10, 2011, 05:05 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi Gents,
To piggy back on Milo's suggestion and you are headed in the right direction, may I also suggest a few more rules. What is the point of lifting weight in a flying vehicle for 30 seconds and not doing any controlled flying? I suggest flying a set sized figure 8 course and altitudes to make it a more useful competition. The flying duration should be usable not 30 seconds, but more like 2 minutes, all documented in raw video verified for non-editing. Maybe others will have verification ideas to add too? And reqarding the duration efficiency competition...please don't make this another Mr. Holger sit motionless for 30 minutes and hover demo... A duration test being run on a continuous circuit with x minutes hover in between would be a much more operationally useful competition and information. FWIW
Cheers,
Jim
Vote for my Bro Joe every day in April here: Quadrocopter and Tricopter Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Apr 10, 2011, 05:48 PM
Winging it >
Joined May 2006
Originally Posted by jesolins View Post
Hi Gents,
Cheers,
Jim
How about two categories. Dead lift as already written plus ... heavy lift with a task as you have suggested.
Old Apr 10, 2011, 06:04 PM
jesolins is offline
Joined Feb 2007
There you go Not to offend anyone but even those human dead lift Gents have trouble navigating themselves around It would be a good comparison
Cheers,
Jim
Question I have an unbuilt Bud Nosen Mr. Mulligan, anyone built a scale one of these? Sackie Giant Scale Airplanes 30 Sep 09, 2012 07:38 AM
Help! Can anyone ID this antique twin ignition? spitfire1999 Vintage & Old-Timer Designs 7 Apr 07, 2011 06:37 PM
Discussion Can anyone help me with fy-90q lazyss350 Multirotor Talk 5 Mar 24, 2011 04:00 PM
Discussion Can anyone help me flashing turnigy esc to fast pwm using avrisp? jstnt Multirotor Talk 0 Mar 24, 2011 02:40 PM
Contest Heavy Lifter Contest Wingnut31 Foamies (Scratchbuilt) 32 Jan 07, 2008 09:55 PM
