BluBeam antenna system from Video Aerial Systems
Today I officially launch the BluBeam antenna line of products available from Video Aerial Systems. The BluBeams are sold as a direct fit circularly polarized replacement for your stock whip antennas.
If you haven't tried circular polarization yet, you need to try it. Once you go circular, you will never go back to linear polarization. Circular polarization is a must for 5.8GHz. Benefits: Extended range Exceptional video clarity No more video drop outs Reduction in multipath interference No weakening of your signal in a turn Better video clarity when flying behind trees and around objects Long Range upgrade Upgrade to a long range system by using a 7.5dbic helical on your RX. This will effectively double your range or more. Upgrade to a very long range system by using a CP Dual Quad (coming soon) or a 9.5 dbic helical to your RX. This effectively triples your range or more. Do not fly a long range BluBeam antenna system without a long range radio (LRS) or you are likely to fly out of your radio range!! Trust me, I've done this many times now... Customer support forum: http://fpvlab.com/forums/forumdispla...Aerial-Systems Testimonials (all of these were homebrews, not built by me, but through my tutorials): 2km on only 10mW: http://www.rcgroups.com/forums/showp...0&postcount=38 Coyote 64 will never go back to linear antennas (post 17): http://fpvlab.com/forums/showthread....ull=1#post4524 Markus does 6km on 200mW (and is sold hook line and sinker): http://www.rcgroups.com/forums/showthread.php?t=1420894 DerekS tried going back to linear and immediately went back to a circular system (post 22): http://fpvlab.com/forums/showthread....=5181#post5181 Performance videos: Can your Omnis go 1.6 miles?
Where to buy these: - You can buy these directly from me here: Video Aerial Systems - ReadymadeRC will have some in stock soon - Or you can have Markus123456 build you a set (I am not affiliated at all with him, but his work is incredible) - Alternately, build your own. The tutorials are in my blog! -Alex |
I'm sold out, that's why... I didn't anticipate 910 being this popular. It might be a while before they are back in stock as I need to get the parts which take a week or two. I can make two bottom feed units with a short extension. This is actually a better option than the BluBeams as it gives a little separation. Email or PM me if you are interested. I will give you the same price as the BluBeams.
The other issue with 900 MHz is the antennas are a bit large. They are 6" in diameter. 1280MHz is about half the size of a softball (4" in diameter and 2" tall) 2.4GHz is about the size of a golf ball. 5.8GHz is about as large as a big marble -Alex |
Latest blog entry: Project Covert Ops: Long range ground...
Sadly, I am. OMM thinks it's an issue that the antenna is causing the video sync to saturate. I am investigating this. All I know is that it is a problem with the VRX. Every other RX unit works except early versions of the Airwave 5.8GHz RX module.
On the bright side, the Junk 1.2 GHz RX's do incredibly well with these. It puts them on par with the Lawmate's! The problem with the cheap digital ones is that their filtration was poor, but their sensitivity is good. With CP, the filtration issue is significantly reduced. -Alex |
2.4GHz helical is fairly small. Only about 6" long or so. I test every antenna I build for SWR. This is the way I ensure quality. If it doesn't hit spec, I don't sell it. That simple. -Alex |
The skew-planar wheel and cloverleaf antennas have an extension cable on them and allow them to be moved away from the VTX and other objects. Electrically, they are identical. The only difference is the construction. The 90 degree connector will NOT be an option for BluBeams. That will put the TX case right in the path of the radiated pattern, thus harming the signal. I can make you a bottom feed SPW or CL with a 90 degree feed and a short 2" run of stiff coaxial cable if you like. That is how I am making the bottom feed antennas. -Alex |
| Thread Tools | |
| Discussion XEN 2.4G High Power 500mW Audio Video TX and RX Systems- Any reviews? | scrtsqrl | Video Piloting (FPV/RPV) | 11 | Apr 23, 2011 08:39 AM |
| Yippee! New FPV vendor - Video Aerial Systems | IBCrazy | Other Websites | 14 | Mar 27, 2011 10:30 PM |
| Video Phase 3 U-2 "Dragon Lady" Aerial video | Alrus1 | Electric Plane Talk | 0 | Mar 17, 2011 12:08 AM |
| Discussion Range Video Aerial Video System | wile_e_coyote | Aerial Photography | 15 | Nov 30, 2006 11:27 AM |
