Old Apr 21, 2011, 07:24 PM
USA, CA, Fontana
Joined Mar 2005
Nice setup
Looks nice Lorenzo. Pretty clean. Something like mirus. But I like the idea of using all three pins on the connector (yellow, red and black). So only 2 connector is used for signals.
I have 6 connector being used on mine. But my main reason for that was to try out different rx and see how the drone behaves.
I got few different 2mm connectors coming in, as my original one that used got damaged. I broke of one of the pins. So, got some from tyco which are ribbon connector.
actionplus is offline Find More Posts by actionplus
Old Apr 21, 2011, 09:04 PM
Vista, CA
Joined Feb 2008
Please share the partnumber if you can find it.
Laurent, nice setup! Now, where is the GPS going to go?
miru
miru is offline Find More Posts by miru
Old Apr 21, 2011, 09:15 PM
USA, CA, Fontana
Joined Mar 2005
Sure will
Part number
I am getting a few from different ones from diff manufacturer.
I will take some pics of all of them.
I will need only one and one back up. I can send you one if you like.
Randy
Old Apr 22, 2011, 02:08 AM
MavLab coordinator
Joined Nov 2006
miru
GPS is going here
http://www.rcgroups.com/forums/showt...0#post18035414
Tanks for all the help
microuav
bartremes is offline Find More Posts by bartremes
Old Apr 22, 2011, 02:10 PM
United States, OH, Powell
Joined Dec 2006
Check power on the drone, maybe your battery is not charged?
I got my setup running today...after going over everything, I determined that the receiver was probably taking way more power than the Arduino could put out. I installed a BEC and went flying...This is a Futabea 8 ch look alike receiver..not sure about its spec...nothing wrong with the receiver except in this application.
Thanks for the help.
rjrobbin is offline Find More Posts by rjrobbin
Old Apr 22, 2011, 02:37 PM
Vista, CA
Joined Feb 2008
Rev 0.04 done
Here is the latest....
  • Moved all AT command generation to drone program
  • Drone program looks at NavData now and automatically resets the dreaded COM_WATCHDOG which seems to cause the loss of control when flying over grass
  • Drone program does not lock out iDev anymore, just intercepts the command port and takes out any PCMD/REF messages. This way you can watch the video and make setup changes. Just make sure you start your iDev application AFTER 'rx2atp' is running, otherwise you loose NavData on the iDev.
    There is a downside to this... the drone is not that responsive any more if video is on, unfortunately there is no way to turn it off without rebooting it
  • Added a 'soft' serial port for a GPS receiver. The port can handle 1200 ... 57600 baud. The data is parsed according to NMEA rules and sent to the drone program, which at this point does not do anything with it yet (my GPS receiver is in the mail...)
  • The drone program backpack became rather large, it is compressed now
  • Pruned the number of files in the zip file down to the essentials. All you really need is 'rx2atp.c' for the Arduino
Let me know what should be different
miru
Old Apr 22, 2011, 03:33 PM
France - Brest
Joined Oct 2007
good job miru, i will try this new version soon...
So, now, since navdata seems to be handle by the drone program, how is to get the pitch and roll in the arduino in order to control a pan&tilt for stabilized cam ?
Cheers.
Laurent
Lorenzo29 is offline Find More Posts by Lorenzo29
Old Apr 22, 2011, 03:46 PM
Vista, CA
Joined Feb 2008
Cheers.
Laurent
Still can't send more than 1 character at a time back to the Arduino (receiver problem with 16Mhz Arduino on 115200). I'll checlk again, since by now I know that little processor fairly well... What kind of actuators do you intend to use for the stabilization? If they are servos, what is the framerate and the resolution? Do you trust the drone's tilt angle measurements?
Old Apr 22, 2011, 04:09 PM
France - Brest
Joined Oct 2007
- actuators ?
servos
- framerate and resolution ?
well, no idea, i will use conventional servo like, Hitec HS56-HB
- Do you trust the drone's tilt angle measurements?
well, no idea, but if you think they are not reliable, i trust you and then forget this idea...
THX
Laurent
Old Apr 22, 2011, 08:11 PM
Joined Nov 2010
My test shows the Pitch/Roll tilt angle measurements from NavData is very stable and trusty, as it is a fusion result with multi-sensors.
MAPGPS is offline Find More Posts by MAPGPS
Old Apr 23, 2011, 07:50 PM
romantist
palomo's Avatar
Chicago
Joined Jul 2004
Greetings,
If any one is interested, I have a new Ar Drone main board and navigation board, asking for a very low price! Please send me a pm if interested Thanks
palomo is offline Find More Posts by palomo
Old Apr 24, 2011, 12:06 AM
Vista, CA
Joined Feb 2008
Under what circumstances did you get your data? What is your reference? The drone just sitting on the ground does not count. I don't trust the data, because by the time I get it, the drone SW has already acted upon it.
Old Apr 24, 2011, 12:40 AM
Joined Nov 2010
You are right. My testing is just on the ground and moved by hand, things may be changed during flying.
If you like the raw sensor data, you can get it with config:
general:navdata_demo=FALSE
Or even get it directly from /dev/ttyPA2
Old Apr 24, 2011, 01:10 AM
Vista, CA
Joined Feb 2008
That would be taking every other dataset away from program.elf, don't think that's good, because it halfs the update rate of program.elf, unless the port just gives current data to anybody reading, which is very unlikely if this is a Linux serial port... once you read it you got it, nobody else is going to get it.
Old Apr 24, 2011, 02:15 AM
MavLab coordinator
Joined Nov 2006
navdata for state
In the autonomous GPS flight we use the phi, theta and psi from the navdata to determan the state of the ar drone.
it is working fine during flight.
we use MAPGPS NAT solution to get navdata and implemented via following iptables rules:
iptables -t nat -A POSTROUTING -p UDP --sport 15554 -j SNAT --to 192.168.1.254:5554
iptables -t nat -A PREROUTING -p UDP -d 192.168.1.254 --dport 5554 -j DNAT --to 192.168.1.1:15554
microuav
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 113 May 13, 2011 02:26 PM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 09:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 10:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 03:54 PM
