Old Oct 16, 2011, 09:20 AM
ons_pk is offline
Find More Posts by ons_pk
Bristol, Great Britain (UK)
Originally Posted by miru View Post
Use SETUP mode and make sure the cyclic is working in LAND, FM1 and FM2! Most people check the sticks only in LAND. Sometimes the switch used to switch the flightmode also switches a curve...
I have tested in setup mode
Aileron and elevator about = +/- 1100 in FM1/FM1 mode
ons_pk is offline Find More Posts by ons_pk
Old Oct 16, 2011, 09:27 AM
miru is offline
Find More Posts by miru
Vista, CA
Joined Feb 2008
Does the selection of different configurations work?
miru is offline Find More Posts by miru
Old Oct 16, 2011, 09:54 AM
ons_pk is offline
What configurations? How can I change to different Config.
Old Oct 16, 2011, 10:06 AM
miru is offline
Vista, CA
Joined Feb 2008
Power up drone with mod. In LAND, push throttle all the way up. The Arduino LED should blink once per second to indicate it is using configuration 1. Hold the cyclic EAST, this should make it blink twice per second, South 3 and West 4. This would give an indication if the cyclic is interpreted right.
If you look in the 'sketch' there are 4 different drone configurations you can fly with. The selection is done with the procedure above. If you hold the cyclic and move the throttle stick down, it will remember that configuration and communicate it to the drone.
Old Oct 16, 2011, 11:32 AM
ons_pk is offline
I have followed the procedure.
When I push the throtle all the way up, Arduino LED Blinks once per sec.
When I push the Cyclic to either North, South, East or West, the LED blinks very fast.
NOt Like what I was expecting 1, 2, 3 or 4 time a sec.
Is there something wrong?
Old Oct 16, 2011, 11:41 AM
ons_pk is offline
I changed the FM to 1,
Now it Blinks 1, 2, 3 or 4 time a sec. Based on the Cyclic MOvements of N,S,E & W
But Still no Cyclic Controls.
Old Oct 16, 2011, 11:42 AM
techspy is offline
Find More Posts by techspy
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
You have your radio setup for airplane mode and not heli mode correct?
techspy is offline Find More Posts by techspy
Old Oct 16, 2011, 11:53 AM
ons_pk is offline
Drone Firmware 1.4.7
Radio 11X
Model type = Airplane
Aux1 = Flap
Norm = 100% Down
Mid = 0%
Land = 0%
Gear = (Land / FM)
Elev = 100%
Aile = 100%
Reverse SW----
Thro (Nor)
Aile (Rev)
Elev (Nor)
Rud (Rev)
Gear (Nor)
Flap (Aux1) (Rev)
No Cyclic control
Old Oct 16, 2011, 12:05 PM
techspy is offline
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Hmm, well I just set mine up yesterday and followed the instructions word for word and found out that even though I had the channels connected like I thought they should be, I had to use hyperterminal to verify that everything was setup correctly. Once I did that, it worked fine.
Not sure what is causing your problem but it may help if you video your hyperterminal session while you manipulate your sticks/switches and post it to youtube so we can take a look.
Old Oct 16, 2011, 12:13 PM
ons_pk is offline
Are you talking about the README.
I used UFO-DOC tutorial PDFs to setup mine.
Which doc did you use?
Old Oct 16, 2011, 01:06 PM
Candu1 is offline
Find More Posts by Candu1
Joined Jul 2011
Oh, yeah, I mean a switch to disconnect the power to the nano, then boot the drone. Cool, thanks for your development on this.
Would be interesting to know if you are able to get it to work by just disconnecting the V+ and leaving tx/rx/ground still connected. I tried that with an earlier version (both mirumod and ardrone firmware versions) and it didn't work for me. I was not able to establish wifi connection between the iTouch and the ardrone. All OK if I disconnect the plug from Arduino to ardrone. I didn't experiment further by disconnecting additional lines, one at a time to see which line my ardone doesn't like...
Candu1 is offline Find More Posts by Candu1
Old Oct 16, 2011, 01:13 PM
techspy is offline
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Yeah, the readme that is included in the code zip file.
Old Oct 16, 2011, 01:14 PM
techspy is offline
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
I will post if it works or not. I didn't get the plug to connect to the drone serial port but instead soldered directly to the pins. So, I would have to disconnect the 4 pins connected to the nano. Not impossible but I would like to find a simpler solution.
Old Oct 16, 2011, 01:16 PM
miru is offline
Vista, CA
Joined Feb 2008
And you keep the throttle all the way up while you are moving the cyclic?
Old Oct 16, 2011, 01:45 PM
ons_pk is offline
Hi
I tried to reload the rx2atp again I get the following errors.
Binary sketch size: 25716 bytes (of a 30720 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
any ideas. it looks greek to me
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 04:04 AM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 09:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 10:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 03:54 PM
