Old Oct 15, 2011, 04:00 PM
jungx148 is offline
Find More Posts by jungx148
Joined Oct 2011
Mr.MAPGPS, how did you save the raw navdata into txt file?
Originally Posted by MAPGPS View Post
Here is a dump of the raw navdata made by Shawn Fraser:
https://projects.ardrone.org/attachments/339/Flight.zip
You can convert the TXT file into Excel format for easy to read.
Could you kindly explain me how you were able to save the raw navadata into txt file?
jungx148 is offline Find More Posts by jungx148
Old Oct 15, 2011, 05:51 PM
techspy is offline
Find More Posts by techspy
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Hey Guys, If using a Nano, where does pin 2 on the drone connect on the Nano? It goes to the "RAW" pin on the mini but the Nano doesn't have one labeled that.
Thanks.
techspy is offline Find More Posts by techspy
Old Oct 15, 2011, 06:09 PM
miru is offline
Find More Posts by miru
Vista, CA
Joined Feb 2008
Thanks.
It goes to VIN.
miru is offline Find More Posts by miru
Old Oct 15, 2011, 06:10 PM
techspy is offline
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
cool, thanks
Old Oct 15, 2011, 07:59 PM
techspy is offline
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Sweet! Just got it working! Thanks for everyone that developed and worked on this and the instructions!
FYI, I am running the latest firmware on the drone (using android devices), using a Nano and a Futaba FASST radio system (using the Ornage RX from Hobbyking).
One question. I want to be able to flip a switch to go back and forth between the RX and wifi control. Can I just switch off the 12v out to the nano to disable the RX mod and allow wifi again?
Old Oct 15, 2011, 08:42 PM
miru is offline
Vista, CA
Joined Feb 2008
No, unless you can change the program that is uploaded to the drone. It has the hooks for it, but so far there was no need for switching back. Why would you want to go back to wifi?
Old Oct 15, 2011, 08:44 PM
techspy is offline
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Well, probably would not be too many times that I would want to go back to wifi but just in case. So even if the nano doesn't get any power from the drone, it will still prevent the wifi control from working?
Old Oct 15, 2011, 08:55 PM
miru is offline
Vista, CA
Joined Feb 2008
Yes, because if you remove power from the Arduino, the program on the drone is still running. This is why I said you would have to change the program that is running on the drone to cover that situation. It's not that hard, but it would have to be done.
Old Oct 15, 2011, 08:57 PM
techspy is offline
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
oh, I thought the program on the drone was uploaded each time you boot with the nano connected and was in non-persistent memory. I thought that if you boot the drone without the nano connected that wifi control was operable again.
Old Oct 15, 2011, 09:12 PM
miru is offline
Vista, CA
Joined Feb 2008
This is true, I thought you were talking about 'hot switching' between RC and iDev control. A 'cold switch', meaning if you cycle power and the Arduino does not get powered, works by design.
Old Oct 15, 2011, 09:14 PM
techspy is offline
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Oh, yeah, I mean a switch to disconnect the power to the nano, then boot the drone. Cool, thanks for your development on this.
Old Oct 15, 2011, 09:23 PM
miru is offline
Vista, CA
Joined Feb 2008
Just disconnect the plug from the Arduino to the drone and everything is back to 'normal' when you power up the drone. This is the beauty of Plug&Play.
Old Oct 15, 2011, 11:38 PM
mark_a_l is offline
Find More Posts by mark_a_l
Joined Sep 2011
But don't let the cable just dangle. It can cause the drone to act 'twitchy' if it is flopping around in front of the sensors.
mark_a_l is offline Find More Posts by mark_a_l
Old Oct 16, 2011, 07:07 AM
ons_pk is offline
Find More Posts by ons_pk
Bristol, Great Britain (UK)
No Response on Cyclic with 6xi and 11x Zero
I have installed the drs009.
Setup as per instructions.
But could not get the cyclic to work.
It takes-off and lands perfectly and Rudder is also working.
But the Right stick (Cyclic) is not working
Would be great if someone can help here.
my setp
Specktrum 6 ch receiver
6xi and 11x
both have same issue.
ons_pk is offline Find More Posts by ons_pk
Old Oct 16, 2011, 08:48 AM
miru is offline
Vista, CA
Joined Feb 2008
my setp
6xi and 11x
Use SETUP mode and make sure the cyclic is working in LAND, FM1 and FM2! Most people check the sticks only in LAND. Sometimes the switch used to switch the flightmode also switches a curve...
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 05:04 AM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 10:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 11:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 12:04 PM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 04:54 PM
