Old Aug 22, 2011, 02:34 PM
olaf.j is offline
Find More Posts by olaf.j
Joined Aug 2011
Originally Posted by UFO Doctor View Post
UFO Doctor’s pleasure was to write step-to-step tutorials. You will succeed with minimum skills in electronics and basic ability in soldering tiny components.
Great documentation - i think with such a step by step tutorial, it should also be possible for ME to do this mod
olaf.j is offline Find More Posts by olaf.j
Old Aug 22, 2011, 03:36 PM
Bill Bergman is offline
Find More Posts by Bill Bergman
Houston, Tx.
Joined Jan 2003
Originally Posted by Bill Bergman View Post
Anybody else have this problem?
Some times when turning with the aileron stick the motors shut down and the drone falls to the ground.
Is there an adjustable max tilt to shutdown parameter?
Bill Bergman is offline Find More Posts by Bill Bergman
Old Aug 22, 2011, 06:39 PM
Candu1 is offline
Find More Posts by Candu1
Joined Jul 2011
Miru created a great work in developing a steering for a Parrot Drone by standard remote control equipment. The present state of the art is a Plug-and Play unit (only 15 grams) with visual low battery alert.
However, some problems are persistent over the last 50 years:
Reading a tutorial: no problem, nice pictures, but I see much better solutions!
Understanding a tutorial: Why? I want to go to fly as soon as possible!
Following a tutorial: Why? I am so smart, I can miss a step.
In confidence, I let you know that I feel like you: I read the instructions given to a new electronic device not to the very end before running into severe problems, too.
But if you are more careful than UFO Doctor, please follow the links listed below:
Tutorial Miru Part 1_V8: Miru Mod Material, Cable Connections and Test-Setup
http://ufo-doctor.ch/descriptions/Pa...art%201_V8.pdf
Tutorial Miru Part 2_V4: Installation of the Miru Mod in drone and First Flight
http://ufo-doctor.ch/descriptions/Pa...art%202_V4.pdf
Tutorial Miru Part 3_V4: Selectable Configurations and Clamp for iPhone on TX
http://ufo-doctor.ch/descriptions/Pa...art%203_V4.pdf
Tutorial Miru Part 4_V8: Visible Low Battery Alert and Emergency Landing
http://ufo-doctor.ch/descriptions/Pa...art%204_V8.pdf
Tutorial Miru Part 5_V2: VLBA experiments with external LED and TX
http://ufo-doctor.ch/descriptions/Pa...art%205_V3.pdf
Have a lot of fun and nice flights!
Kind regards
UFO Doctor
I see you are updating your tutorial all the time. May be miru could make reference of the tutorial on the first page of this thread.
Thanks for the idea of using a 3V regulator as an option to turn on a RF transmitter. I'm still waiting for my transmitter to come. I'll have to measure its current draw before I can decide on which option to use.
In the mean time, I've connected two white high intensity (19,000mcd) LEDs that I have on hand and mounted them to the tail of my ardrone. I don't have a "feel" on luminous intensity measurement but all I know is this one is much brighter than the one rated at 8,000mcd above.
I ended up using a 50 ohm resister in series with two LEDs connected in parallel. This gives me a voltage of 3.1V across the LEDs as per the LED spec. The net current draw from pin9 is about 33mA, which is within the Arduino's 40mA.
Here's a head-on view (ah, tail-on view)... extremely bright.
And here is a side view:
Candu1 is offline Find More Posts by Candu1
Old Aug 22, 2011, 06:49 PM
Candu1 is offline
Joined Jul 2011
Oh yea, all the time until I tone down the tilt setting. Also, I find flying in FM2 mode lower your chance of getting flipped.
What I read so far from ardrone app developers is that tilt shut down setting is not accessible.
Old Aug 22, 2011, 07:00 PM
Houston, Tx.
Joined Jan 2003
Thanks for the reply !!!!!
The tilt setting in the drone or the arduino firmware?
Old Aug 22, 2011, 07:29 PM
Candu1 is offline
Joined Jul 2011
The tilt setting in the drone or the arduino?
May be I'm confused by the question. The tilt setting is end user (pilot) adjustable. On iDeveices, the user can make adjustment from the setup screen. On mirumod, it is preset by the user in the sketch. Starting in mirumod version 008, miru created 4 configurations predefined in the sketch that the user can select "on the fly" using the joysticks in the transmitter.
My understanding (miru can confirm) is that maximum tilt angle SHUT DOWN is not adjustable, even by app developers.
Old Aug 22, 2011, 07:43 PM
miru is offline
Find More Posts by miru
Vista, CA
Joined Feb 2008
Yes, that's my experience too. I think it is around 30 degrees.
miru is offline Find More Posts by miru
Old Aug 22, 2011, 07:45 PM
Houston, Tx.
Joined Jan 2003
Sorry, I haven't been very clear. I think you answered my question. I need to adjust the tilt sensitivy in the sketch. The drone app does not effect the drone when your not using the Iphone/pad, right? The other function of completely disabling max tilt/shut off would be excellent if it were available. Thanks again
Old Aug 22, 2011, 07:47 PM
miru is offline
Vista, CA
Joined Feb 2008
Originally Posted by Bledi View Post
Miru, your issu was not the good one. I had change the RX buffer to 160. And there is no change
That is strange... You'll have to wait until I get back home next weekend to see if I can setup one of the GPSs for 38400...
Houston, Tx.
Joined Jan 2003
I guess you could reduce travel on the transmitter's dual rate..
Old Aug 22, 2011, 10:31 PM
Candu1 is offline
Joined Jul 2011
Yes, that's exactly what I finally ended up doing after a some test flights with the different available configurations.
I now settled with the "Standard" configuration (cfg1) and have my dual rate switches on my tx set to 50% reduction for smooth flying. I can always flip the dual rate switches any time to have more aggressive control to overcome sudden change in wind conditions if necessary.
Old Aug 22, 2011, 11:15 PM
Houston, Tx.
Joined Jan 2003
Hopefully someday we'll be able to bypass the tilt limits so we can roll and loop....
Old Aug 23, 2011, 03:38 AM
klamath is offline
Find More Posts by klamath
Ita
Joined Oct 2006
Hi, there is any way to switch off the ultrasound sensor? In outdoor would be the best solution
klamath is offline Find More Posts by klamath
Old Aug 23, 2011, 06:19 AM
UFO Doctor is offline
Find More Posts by UFO Doctor
Schweiz, AG, Wettingen
Joined May 2010
High intensity LED for VLBA
Dear Candu1
Your LEDs are realy bright (in side view, too) and your circuit is optimal.
I have added some fotos to the summary of the 5 Miru Mod Tutorials to offer a better overview.
Kind regards
UFU Doctor
UFO Doctor is offline Find More Posts by UFO Doctor
Old Aug 23, 2011, 11:20 AM
Joined May 2010
Dear olaf.j
Thank you for your comment: You will come to success, but each step needs some time (you are here in the real, not in the virtual reality).
Please check if your have all new Miru material ready prior to start with your careful work.
Kind regards and good luck
UFO Doctor
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 04:04 AM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 09:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 10:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 03:54 PM
