Old Aug 02, 2011, 11:31 AM
Bledi is offline
Find More Posts by Bledi
Bledi's Avatar
Joined Jul 2011
Bledi is offline Find More Posts by Bledi
Old Aug 02, 2011, 11:58 AM
miru is offline
Find More Posts by miru
Vista, CA
Joined Feb 2008
Thanks, Bledi, this will help to clear things up. I'll have to think this through and see where it can be added.
miru is offline Find More Posts by miru
Old Aug 02, 2011, 12:03 PM
Bledi is offline
Bledi's Avatar
Joined Jul 2011
You are the best
Tanks a lot, if you need help for a test, I am present !
Old Aug 02, 2011, 01:31 PM
Orphee is offline
Find More Posts by Orphee
Joined Jan 2011
Héhé i was right about mode 1 or 2, of course it change the stick to move
Orphee is offline Find More Posts by Orphee
Old Aug 02, 2011, 01:42 PM
Bledi is offline
Bledi's Avatar
Joined Jul 2011
Has we say in french : "dans le mille Emile"
Old Aug 02, 2011, 05:20 PM
MathiewH is offline
Find More Posts by MathiewH
Deutschland, BW, Karlsruhe
Joined Jul 2011
Hello,
...now the modified Drone is working PERFEKT.
My failure was, the switches for Land etc. was wrong programmed. I saw it in the Hypertext Terminal.
Now its the first flying Mod Drone in Germany!
Thanks a lot MIRU!!! very good job done.
Much greetings from Germany
Matthias
MathiewH is offline Find More Posts by MathiewH
Old Aug 02, 2011, 08:04 PM
miru is offline
Vista, CA
Joined Feb 2008
Need input: mode 1, 2, 3 and 4 transmitters
Thanks to Bledi, I know now that there are also mode 3 and 4 transmitters. It looks like what I thought was a mode 1 transmitter is actually a mode 3 transmitter.
There are two groups, mode 1-4 and mode 2-3, within which the stick channel assignements are consistent, just the position of the sticks is reversed. However the pairing of channels is different between the two groups, the mode 1-4 group puts throttle/aileron (GAZ/ROL in drone speak) on one stick and elevator/rudder (PTC/RUD) on the other, versus the group 2-3 has throttle/rudder (GAZ/RUD) on one and elevator/aileron (PTC/ROL) on the other.
I propose to change the mirumod such, that 'rx2atp.c can be parameterized for the mode of the TX (yet another macro in the 'sketch'). This would allow to make FTRIM/EMERGENCY tied to a horizontal movement of the throttle stick and to use the 'other' stick for the configuration.
What are your thoughts on that?
Old Aug 03, 2011, 02:19 AM
Bledi is offline
Bledi's Avatar
Joined Jul 2011
Thanks, it's the best solution for me of course
Old Aug 03, 2011, 03:32 AM
Orphee is offline
Joined Jan 2011
I agree, an option in the sketch like
#set your mode here
Mode 2
good idea
Old Aug 03, 2011, 05:13 AM
Bledi is offline
Bledi's Avatar
Joined Jul 2011
I just have make a test with the new firmware 1.7.4. No problem the mirumod still working fine
Old Aug 03, 2011, 09:55 AM
Candu1 is offline
Find More Posts by Candu1
Joined Jul 2011
Are you opening up another can of warms ? :-)
User will adopt to the settings they are confortable with. I don't think it matters that much since it would only be a one time change during the compiling and uploading the sketch.
On the othe hand, as long as you make mode 2 the default, I'd be happy! :-)
Candu1 is offline Find More Posts by Candu1
Old Aug 03, 2011, 05:05 PM
Totoff is offline
Find More Posts by Totoff
France, IdF, Châtillon
Joined Aug 2011
Hi all,
First of all I'd like to thanks Miru and all the participants for this awesome mod !
When configuring my channels with hyperterminal, I had a much larger range than expected with pulses from 900 to 2100...
I modify each channels on Tx to 85-90% to have pulses from 1100 to 1900.
Everything seems to be ok, including Flat trim & emergency reset, but I was wondering if it was the right way to do.
I was also wondering what could be the issue to have larger pulses.. Channels interactions ?
I also have a suggestion to Ufo doctor as if there is any update of the mod guide planned, I think it may be usefull to include the expected pulse min and max in the document.
As Bledi, I also tested quickly the mod with firmware 1.7.4 and everything seems just fine !
Once again, thanks !
Totoff
Totoff is offline Find More Posts by Totoff
Old Aug 03, 2011, 05:15 PM
miru is offline
Vista, CA
Joined Feb 2008
What kind of TX/RX are you using?
Old Aug 03, 2011, 05:24 PM
Totoff is offline
Joined Aug 2011
Sorry, I was pretty sure I mentionned it !
I'm using a Turnigy 9x Tx bound with A HK-TR6A-V2 Receiver.
I also have the Tx Off with no failsafe issue, but i understood that at this time that's a common problem for Turnigy 9x users.
Old Aug 03, 2011, 07:09 PM
Candu1 is offline
Joined Jul 2011
Wondering if there are improvements in video quality when using RC for control and wifi for video.
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 04:04 AM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 09:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 10:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 03:54 PM
